[MOAB-dev] get_adjacencies after exchange_ghost_cells
Ryan O'Kuinghttons ryan.okuinghttons at noaa.gov
Mon Nov 19 13:53:29 CST 2018
Hi Iulian, I'm seeing an issue with calling get_adjacencies after the
exchange_ghost_cells/tag_exchange call. For some reason, the Range of
adjacencies contains elements without tags. Is there something special
that needs to be done in this case?
Also, I am still calling resolve_shared_ents twice, once in
MBMesh_addelements and then again in the ghost exchange routine, because
without that second call the adjacencies don't seem to include ghosted
elements at all..
The reproducer is updated on the moab4 branch if you want to try it again:
esmf/src/Infrastructure/Mesh/tests/ESMC_MeshMOABGhostUTest.C
Ryan O'Kuinghttons
NESII/NOAA/Earth System Research Laboratory
https://www.esrl.noaa.gov/gsd/nesii/
