[MOAB-dev] ghost/halo elements
Grindeanu, Iulian R. iulian at mcs.anl.gov
Mon Oct 29 16:31:48 CDT 2018
Sorry, I still don't know what is wrong.
What kind of tag is it? is it fixed length, does it have a default value?
How was this tag created/set ?
the sizes of the buffers sent seem to be small, is this a small test mesh? how is this partitioned?
Can you replicate the bug in a way I can run on my machine? I mean, I do have an old version of esmf. I assume this is on newer code. Or can you replicate on smaller number of tasks (maybe 2?)
Iulian
From: Ryan O'Kuinghttons <ryan.okuinghttons at noaa.gov>
Sent: Monday, October 29, 2018 4:10:16 PM
To: Grindeanu, Iulian R.; Vijay S. Mahadevan
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] ghost/halo elements
   0  ParallelComm(0.03 s) Entering exchange_tags
   3  ParallelComm(0.03 s) Entering exchange_tags
   1  ParallelComm(0.03 s) Entering exchange_tags
   2  ParallelComm(0.03 s) Entering exchange_tags
   3  ParallelComm(0.03 s) Irecv, 1<-3, buffer ptr = 0x13a5a20, tag=7,
size=1024, incoming=1
   1  ParallelComm(0.03 s) Irecv, 0<-1, buffer ptr = 0x1115b30, tag=7,
   0  ParallelComm(0.03 s) Irecv, 1<-0, buffer ptr = 0x11cc7e0, tag=7,
   1  ParallelComm(0.03 s) Irecv, 2<-1, buffer ptr = 0x17a4330, tag=7,
size=1024, incoming=2
   0  ParallelComm(0.03 s) Irecv, 2<-0, buffer ptr = 0x11cdf60, tag=7,
   0  ParallelComm(0.03 s) Irecv, 3<-0, buffer ptr = 0xb4b9e0, tag=7,
size=1024, incoming=3
   3  ParallelComm(0.03 s) Irecv, 2<-3, buffer ptr = 0x13a6360, tag=7,
   3  ParallelComm(0.03 s) Irecv, 0<-3, buffer ptr = 0xd23290, tag=7,
   1  ParallelComm(0.03 s) Irecv, 3<-1, buffer ptr = 0x11135a0, tag=7,
   2  ParallelComm(0.03 s) Irecv, 0<-2, buffer ptr = 0x16505f0, tag=7,
   2  ParallelComm(0.03 s) Irecv, 1<-2, buffer ptr = 0x2362770, tag=7,
   2  ParallelComm(0.03 s) Irecv, 3<-2, buffer ptr = 0x1651720, tag=7,
   1  ParallelComm(0.03 s) Packing tag "elem_coords"(0.03 s)
   0  ParallelComm(0.03 s) Packing tag "elem_coords"(0.03 s)
   3  ParallelComm(0.03 s) Packing tag "elem_coords"(0.03 s)
   2  ParallelComm(0.03 s) Packing tag "elem_coords"(0.03 s)
   1  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 1->0,
buffer ptr = 0x17a5500, tag=7, size=83
   0  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 0->1,
buffer ptr = 0x11ceee0, tag=7, size=83
   3  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 3->1,
buffer ptr = 0x1a27200, tag=7, size=83
   2  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 2->0,
buffer ptr = 0x2363980, tag=7, size=107
   0  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 0->2,
buffer ptr = 0xb4a0d0, tag=7, size=83
   3  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 3->2,
buffer ptr = 0xd22a20, tag=7, size=131
   1  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 1->2,
buffer ptr = 0x1114230, tag=7, size=107
   2  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 2->1,
buffer ptr = 0x1652330, tag=7, size=107
   1  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 1->3,
buffer ptr = 0x11163b0, tag=7, size=107
   0  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 0->3,
buffer ptr = 0xb4bdf0, tag=7, size=59
   3  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 3->0,
buffer ptr = 0xd22610, tag=7, size=59
   0  ParallelComm(0.03 s) Unpacking tag elem_coords
   1  ParallelComm(0.03 s) Unpacking tag elem_coords
   3  ParallelComm(0.03 s) Unpacking tag elem_coords
   2  ParallelComm(0.03 s) Done packing tags.(0.03 s) Isend, 2->3,
buffer ptr = 0x1652bd0, tag=7, size=107
   2  ParallelComm(0.03 s) Unpacking tag elem_coords
[3]MOAB ERROR: --------------------- Error Message
[0]MOAB ERROR: --------------------- Error Message
[0]MOAB ERROR: Failed to recv-unpack-tag message!
[1]MOAB ERROR: --------------------- Error Message
[1]MOAB ERROR: Failed to recv-unpack-tag message!
[3]MOAB ERROR: Failed to recv-unpack-tag message!
[3]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
[0]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
[1]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
[2]MOAB ERROR: --------------------- Error Message
[2]MOAB ERROR: Failed to recv-unpack-tag message!
[2]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
terminate called after throwing an instance of 'int'
Program received signal SIGABRT: Process abort signal.
On 10/29/18 15:02, Grindeanu, Iulian R. wrote:
> Hi Ryan,
> I don't know what could be wrong; can you set verbosity level in your code?
> I mean, can you use something like
> pcomm->set_debug_verbosity(4)
> before calling exchange tags? And send me the output?
> I don't think MB_ALREADY_ALLOCATED is a problem in this case; I could be wrong
> Iulian
> Sent: Monday, October 29, 2018 3:44:01 PM
> Hi Iulian, thanks for responding :)
> So I did get the exchange_tags call to work for all but one of our tags.
> However, when I add the last tag to the vector that is passed into
> exchange_tags I get the following segfault:
> Backtrace for this error:
> Do you have any ideas what I could be doing wrong?
> Ryan
> On 10/29/18 12:52, Grindeanu, Iulian R. wrote:
>> Hi Ryan,
>> Sorry for missing the messages, my mistake;
>> If you have your tags defined on your entities, you will need to call the "exchange_tags" method, after your ghost method;
>> (call this one:
>> ErrorCode ParallelComm::exchange_tags(const std::vector<Tag> &src_tags,
>>                                           const std::vector<Tag> &dst_tags,
>>                                           const Range &entities_in)
>> usually, source and dest tags are the same lists)
>> the augment method is  for "membership" to specific moab sets (material, boundary conditions, partition );
>>    Entities (cells, usually), do not have a tag defined on them that would signal they are part of those sets, this is why we had to transfer that information in a different way.
>> What is exactly your use case? Do you need to transfer information about a set or about a tag ?
>> Iulian
>> From: Vijay S. Mahadevan <vijay.m at gmail.com>
>> Sent: Monday, October 29, 2018 1:05:53 PM
>> To: Ryan OKuinghttons - NOAA Affiliate
>> Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
>> Hi Ryan,
>> The method `augment_default_sets_with_ghosts` [1] in ParallelComm
>> enables this for some of the default tags. We haven't exposed this as
>> a very general mechanism as the user could define the tag data layout
>> in many possible ways and it would be difficult to cover all use cases
>> from a library standpoint. Remember that for custom defined Tags, you
>> can also use exchange_tag/reduce_tags in ParallelComm to get the data
>> that you need on shared entities. If exchange_tags does not suit your
>> needs, you can see if you can adapt augment_default_sets_with_ghosts
>> method for your use case. Let me know if that helps.
>> Vijay
>> [1] http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a76dced0b6dbe2fb99340945c7ca3c0f2
>> On Mon, Oct 29, 2018 at 1:49 PM Ryan O'Kuinghttons
>> <ryan.okuinghttons at noaa.gov> wrote:
>>> Hi Iulian, Vijay,
>>> We have a set of custom tags that we use in ESMF, would it be possible
>>> to transfer these as well?
>>> Ryan
>>> On 10/29/18 10:54, Vijay S. Mahadevan wrote:
>>>> The default set of tags do get transferred. These would be the
>>>> MATERIAL_SET, DIRICHLET/NEUMANN sets etc.
>>>> Iulian, did we add a separate method to transfer these to the ghosted
>>>> entities ? I vaguely remember something like that.
>>>> Vijay
>>>> On Mon, Oct 29, 2018 at 12:42 PM Ryan O'Kuinghttons
>>>>> Hi Vijay,
>>>>> I ran into another issue with the call to exchange_ghost_cells, but this
>>>>> is probably just a misunderstanding on my part. I find that the tag
>>>>> information that is part of the mesh before the the call does not
>>>>> transfer to the newly created faces. Is there some way to ask moab to
>>>>> transfer tags when creating ghost entities? (FWIW, I could not find this
>>>>> in the example you sent me) Thanks,
>>>>> Ryan
>>>>> On 10/26/18 07:36, Ryan O'Kuinghttons wrote:
>>>>>> Hi Vijay,
>>>>>> I resolved the issue with not getting any shared, owned entities back
>>>>>> by using the other version of resolve_shared_ents, as demonstrated in
>>>>>> the example you indicated. I created a Range containing all elements
>>>>>> (faces for moab), and used that as input.
>>>>>>      Range range_ent;
>>>>>> merr=mb->get_entities_by_dimension(0,this->sdim,range_ent);
>>>>>>      MBMESH_CHECK_ERR(merr, localrc);
>>>>>>      merr = pcomm->resolve_shared_ents(0, range_ent, this->sdim, 1);
>>>>>> The first version of the interface (which does not use a Range input)
>>>>>> does not work for me:
>>>>>>      merr = pcomm->resolve_shared_ents(0, this->sdim, 1);
>>>>>> Otherwise, everything else seems to be resolved with this issue,
>>>>>> thanks again for all of your help!!
>>>>>> Ryan
>>>>>> On 10/25/18 15:13, Vijay S. Mahadevan wrote:
>>>>>>> Ryan, I don't see anything obviously wrong in the code below. Does
>>>>>>> your shared_ents not have any entities after parallel resolve ? If you
>>>>>>> can replicate your issue in a small standalone test, we should be able
>>>>>>> to quickly find out what's going wrong.
>>>>>>> Look at the test_reduce_tag_explicit_dest routine in
>>>>>>> test/parallel/parallel_unit_tests.cpp:1617. It has the workflow where
>>>>>>> you create a mesh in memory, resolve shared entities, get shared
>>>>>>> entities and even set/reduce tag data.
>>>>>>> Vijay
>>>>>>> On Thu, Oct 25, 2018 at 4:25 PM Ryan O'Kuinghttons
>>>>>>>> OK, that allows the resolve_shared_ents routine to complete without
>>>>>>>> error, but I still don't get any shared, owned entities back from the
>>>>>>>> get_shared_entities/filter_pstatus calls:
>>>>>>>>        Range shared_ents;
>>>>>>>>        // Get entities shared with all other processors
>>>>>>>>        merr = pcomm->get_shared_entities(-1, shared_ents);
>>>>>>>>        // Filter shared entities with not not_owned, which means owned
>>>>>>>>        Range owned_entities;
>>>>>>>>        merr = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED,
>>>>>>>> PSTATUS_NOT, -1, &owned_entities);
>>>>>>>>        unsigned int nums[4] = {0}; // to store the owned entities per
>>>>>>>> dimension
>>>>>>>>        for (int i = 0; i < 4; i++)
>>>>>>>>          nums[i] = (int)owned_entities.num_of_dimension(i);
>>>>>>>>        vector<int> rbuf(nprocs*4, 0);
>>>>>>>>        MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, mpi_comm);
>>>>>>>>        // Print the stats gathered:
>>>>>>>>        if (0 == rank) {
>>>>>>>>          for (int i = 0; i < nprocs; i++)
>>>>>>>>            cout << " Shared, owned entities on proc " << i << ": " <<
>>>>>>>> rbuf[4*i] << " verts, " <<
>>>>>>>>                rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces,
>>>>>>>> rbuf[4*i + 3] << " elements" << endl;
>>>>>>>> OUTPUT:
>>>>>>>>       Shared, owned entities on proc 0: 0 verts, 0 edges, 0 faces, 0
>>>>>>>> elements
>>>>>>>>       Shared, owned entities on proc 1: 0 verts, 0 edges, 0 faces, 0
>>>>>>>> elements
>>>>>>>>       Shared, owned entities on proc 2: 0 verts, 0 edges, 0 faces, 0
>>>>>>>> elements
>>>>>>>>       Shared, owned entities on proc 3: 0 verts, 0 edges, 0 faces, 0
>>>>>>>> elements
>>>>>>>> Note: I also tried changing the -1 to 2 in the
>>>>>>>> get_shared_entities/filter_pstatus calls to only retrieve elements.
>>>>>>>> On 10/25/18 13:57, Vijay S. Mahadevan wrote:
>>>>>>>>> No problem. Can you try 1 for the last argument to look for edges as
>>>>>>>>> the shared_dim.
>>>>>>>>> Vijay
>>>>>>>>> On Thu, Oct 25, 2018 at 3:41 PM Ryan O'Kuinghttons
>>>>>>>>>> OK, thanks again for that explanation, I never would have been
>>>>>>>>>> able to figure out that this_set was the root set. I apologize for
>>>>>>>>>> all the dumb questions, hopefully they are all getting me closer
>>>>>>>>>> to self sufficiency..
>>>>>>>>>> I'm getting an error that doesn't make sense to me. I specifying
>>>>>>>>>> the resolve_dim and shared_dim in the call:
>>>>>>>>>>        // Get the ParallelComm instance
>>>>>>>>>>        ParallelComm* pcomm = new ParallelComm(mb, mpi_comm);
>>>>>>>>>>        int nprocs = pcomm->proc_config().proc_size();
>>>>>>>>>>        int rank = pcomm->proc_config().proc_rank();
>>>>>>>>>>        // get the root set handle
>>>>>>>>>>        EntityHandle root_set = mb->get_root_set();
>>>>>>>>>>        merr = pcomm->resolve_shared_ents(root_set, 2, -1);
>>>>>>>>>> but I'm getting this message:
>>>>>>>>>> [0]MOAB ERROR: Unable to guess shared_dim or resolve_dim!
>>>>>>>>>> what am i missing?
>>>>>>>>>> On 10/25/18 12:51, Vijay S. Mahadevan wrote:
>>>>>>>>>> It is your root set or fileset if you added entities to it. You
>>>>>>>>>> can get the root set handle from Core object.
>>>>>>>>>> Vijay
>>>>>>>>>> On Thu, Oct 25, 2018, 14:38 Ryan O'Kuinghttons
>>>>>>>>>>> Thanks again, Vijay. However, I still don't understand what this_set
>>>>>>>>>>> should be, is it an output maybe?
>>>>>>>>>>> Ryan
>>>>>>>>>>> On 10/25/18 12:27, Vijay S. Mahadevan wrote:
>>>>>>>>>>>> You can try either the first or the second variant instead [1] with
>>>>>>>>>>>> following arguments.
>>>>>>>>>>>> ErrorCode moab::ParallelComm::resolve_shared_ents(EntityHandle
>>>>>>>>>>>> this_set,
>>>>>>>>>>>> int resolve_dim = 2,
>>>>>>>>>>>> int shared_dim = -1,
>>>>>>>>>>>> const Tag * id_tag = 0
>>>>>>>>>>>> That should resolve 2-dim entities with shared edges across
>>>>>>>>>>>> partitions. You can leave id_tag pointer as zero since the
>>>>>>>>>>>> default is
>>>>>>>>>>>> GLOBAL_ID.
>>>>>>>>>>>>> This brings up a more general question I've had about the moab
>>>>>>>>>>>> documentation for a while. In the doc for this routine, it only
>>>>>>>>>>>> lists 2
>>>>>>>>>>>> parameters, proc_ents and shared_dim, even though in the function
>>>>>>>>>>>> signature above it clearly shows more. I've had trouble
>>>>>>>>>>>> understanding
>>>>>>>>>>>> which parameters are relevant in the past, or what they do
>>>>>>>>>>>> because I'm
>>>>>>>>>>>> not quite sure how to read the documentation.
>>>>>>>>>>>> This is an oversight. We will go through and rectify some of the
>>>>>>>>>>>> inconsistencies in the documentation. We are preparing for an
>>>>>>>>>>>> upcoming
>>>>>>>>>>>> release and I'll make sure that routines in Core/ParallelComm have
>>>>>>>>>>>> updated documentation that match the interfaces. Meanwhile, if you
>>>>>>>>>>>> have questions, feel free to shoot an email to the list.
>>>>>>>>>>>> Hope that helps.
>>>>>>>>>>>> Vijay
>>>>>>>>>>>> [1]
>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a29a3b834b3fc3b4ddb3a5d8a78a37c8a
>>>>>>>>>>>> On Thu, Oct 25, 2018 at 1:58 PM Ryan O'Kuinghttons
>>>>>>>>>>>>> Hi Vijay,
>>>>>>>>>>>>> Thanks again for that explanation.
>>>>>>>>>>>>> ESMF does use unique global ids for the vertices and set them
>>>>>>>>>>>>> to the
>>>>>>>>>>>>> GLOBAL_ID in the moab mesh. So I think we are good there.
>>>>>>>>>>>>> I can't quite figure out how to use resolve_shared_entities
>>>>>>>>>>>>> though.
>>>>>>>>>>>>> There are three versions of the call in the documentation, and
>>>>>>>>>>>>> I assume
>>>>>>>>>>>>> that I should use the first and pass in a Range containing all
>>>>>>>>>>>>> entities
>>>>>>>>>>>>> for proc_ents:
>>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a59e35d9906f2e33fe010138a144a5cb6
>>>>>>>>>>>>> However, I'm not sure what the this_set EntityHandle should be.
>>>>>>>>>>>>> lists 2
>>>>>>>>>>>>> understanding
>>>>>>>>>>>>> because I'm
>>>>>>>>>>>>> Any example or explanation you give me for
>>>>>>>>>>>>> resolve_shared_entities is
>>>>>>>>>>>>> much appreciated!
>>>>>>>>>>>>> Ryan
>>>>>>>>>>>>> On 10/25/18 09:40, Vijay S. Mahadevan wrote:
>>>>>>>>>>>>>> Hi Ryan,
>>>>>>>>>>>>>> Glad the example helped.
>>>>>>>>>>>>>>> The example shows the ghost exchange happening between shared
>>>>>>>>>>>>>>> owned
>>>>>>>>>>>>>> entities. In my experiments I've been unable to make the ghost
>>>>>>>>>>>>>> exchange
>>>>>>>>>>>>>> work, and I think that might be because my entities are not
>>>>>>>>>>>>>> shared.
>>>>>>>>>>>>>> You need to call resolve_shared_entities on the entities prior to
>>>>>>>>>>>>>> doing ghost exchange. When we load the mesh from file, this
>>>>>>>>>>>>>> happens
>>>>>>>>>>>>>> automatically based on the read options but if you are forming
>>>>>>>>>>>>>> a mesh
>>>>>>>>>>>>>> in memory, you need to make sure that the shared vertices have
>>>>>>>>>>>>>> the
>>>>>>>>>>>>>> same GLOBAL_ID numbering consistently across processes. That
>>>>>>>>>>>>>> is shared
>>>>>>>>>>>>>> vertices are unique. Once that is set, shared entities
>>>>>>>>>>>>>> resolution will
>>>>>>>>>>>>>> work correctly out of the box and you will have shared
>>>>>>>>>>>>>> edges/entities
>>>>>>>>>>>>>> query working correctly. A call to get ghosted layers once
>>>>>>>>>>>>>> this is
>>>>>>>>>>>>>> done would be the way to go.
>>>>>>>>>>>>>> I assume ESMF has a unique global numbering for the vertices ?
>>>>>>>>>>>>>> Use
>>>>>>>>>>>>>> that to set the GLOBAL_ID tag. Let us know if you are still
>>>>>>>>>>>>>> having
>>>>>>>>>>>>>> issues.
>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>> On Thu, Oct 25, 2018 at 11:17 AM Ryan O'Kuinghttons
>>>>>>>>>>>>>>> Hi Vijay,
>>>>>>>>>>>>>>> I've had some time to play with this now, and I have another
>>>>>>>>>>>>>>> question.
>>>>>>>>>>>>>>> Thank you for sending along the example code, it has been
>>>>>>>>>>>>>>> extremely
>>>>>>>>>>>>>>> helpful.
>>>>>>>>>>>>>>> owned
>>>>>>>>>>>>>>> ghost exchange
>>>>>>>>>>>>>>> shared. The
>>>>>>>>>>>>>>> situation I have is entities that are owned wholly on a single
>>>>>>>>>>>>>>> processor, which need to be communicated to other processors
>>>>>>>>>>>>>>> which
>>>>>>>>>>>>>>> require them as part of a halo region for mesh based
>>>>>>>>>>>>>>> computation. In
>>>>>>>>>>>>>>> this situation would I need to "share" my entities across the
>>>>>>>>>>>>>>> whole
>>>>>>>>>>>>>>> processor space, before requesting a ghost exchange? I'm not
>>>>>>>>>>>>>>> even really
>>>>>>>>>>>>>>> sure what shared entities mean, is there a good place to look
>>>>>>>>>>>>>>> in the
>>>>>>>>>>>>>>> documentation to learn more about the terminology? Thanks,
>>>>>>>>>>>>>>> Ryan
>>>>>>>>>>>>>>> On 10/8/18 12:17, Vijay S. Mahadevan wrote:
>>>>>>>>>>>>>>>> Ryan,
>>>>>>>>>>>>>>>> You need to use the ParallelComm object in MOAB to call
>>>>>>>>>>>>>>>> exchange_ghost_cells [1] with appropriate levels of ghost
>>>>>>>>>>>>>>>> layers for
>>>>>>>>>>>>>>>> your mesh. This needs to be done after the mesh is loaded,
>>>>>>>>>>>>>>>> or you can
>>>>>>>>>>>>>>>> pass this information also as part of the options when
>>>>>>>>>>>>>>>> loading a file
>>>>>>>>>>>>>>>> and MOAB will internally load the file with ghosted layers.
>>>>>>>>>>>>>>>> Here's an
>>>>>>>>>>>>>>>> example [2].
>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>> [1]
>>>>>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a55dfa308f56fd368319bfb4244428878
>>>>>>>>>>>>>>>> [2]
>>>>>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/HelloParMOAB_8cpp-example.html
>>>>>>>>>>>>>>>> On Mon, Oct 8, 2018 at 1:23 PM Ryan O'Kuinghttons
>>>>>>>>>>>>>>>>> Hi, I am wondering if there is a way to create ghost
>>>>>>>>>>>>>>>>> elements in MOAB.
>>>>>>>>>>>>>>>>> By this I mean a list of copies of elements surrounding a
>>>>>>>>>>>>>>>>> specific MOAB
>>>>>>>>>>>>>>>>> element, ghost elements may exist on a different processor
>>>>>>>>>>>>>>>>> than the
>>>>>>>>>>>>>>>>> source element. I see a ghost_elems class in the appData
>>>>>>>>>>>>>>>>> namespace, but
>>>>>>>>>>>>>>>>> there is not much documentation on how to use it.. Thank you,
>>>>>>>>>>>>>>>>> Ryan O'Kuinghttons
>>>>>>>>>>>>>>>>> Cherokee Nation Management and Consulting
>>>>>>>>>>>>>>>>> NESII/NOAA/Earth System Research Laboratory
>>>>>>>>>>>>>>>>> https://www.esrl.noaa.gov/gsd/nesii/
