[MOAB-dev] ghost/halo elements
Ryan O'Kuinghttons ryan.okuinghttons at noaa.gov
Mon Oct 29 15:44:01 CDT 2018
Hi Iulian, thanks for responding :)
So I did get the exchange_tags call to work for all but one of our tags.
However, when I add the last tag to the vector that is passed into
exchange_tags I get the following segfault:
[3]MOAB ERROR: --------------------- Error Message
[3]MOAB ERROR: Failed to recv-unpack-tag message!
[3]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
terminate called after throwing an instance of 'int'
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
[0]MOAB ERROR: --------------------- Error Message
[0]MOAB ERROR: Failed to recv-unpack-tag message!
[1]MOAB ERROR: --------------------- Error Message
[2]MOAB ERROR: --------------------- Error Message
[2]MOAB ERROR: Failed to recv-unpack-tag message!
[2]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
[0]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
[1]MOAB ERROR: Failed to recv-unpack-tag message!
[1]MOAB ERROR: exchange_tags() line 7414 in ParallelComm.cpp
Do you have any ideas what I could be doing wrong?
Ryan
On 10/29/18 12:52, Grindeanu, Iulian R. wrote:
> Hi Ryan,
> Sorry for missing the messages, my mistake;
> If you have your tags defined on your entities, you will need to call the "exchange_tags" method, after your ghost method;
> (call this one:
> ErrorCode ParallelComm::exchange_tags(const std::vector<Tag> &src_tags,
>                                          const std::vector<Tag> &dst_tags,
>                                          const Range &entities_in)
> usually, source and dest tags are the same lists)
> the augment method is  for "membership" to specific moab sets (material, boundary conditions, partition );
>   Entities (cells, usually), do not have a tag defined on them that would signal they are part of those sets, this is why we had to transfer that information in a different way.
> What is exactly your use case? Do you need to transfer information about a set or about a tag ?
> Iulian
> From: Vijay S. Mahadevan <vijay.m at gmail.com>
> Sent: Monday, October 29, 2018 1:05:53 PM
> To: Ryan OKuinghttons - NOAA Affiliate
> Cc: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] ghost/halo elements
> Hi Ryan,
> The method `augment_default_sets_with_ghosts` [1] in ParallelComm
> enables this for some of the default tags. We haven't exposed this as
> a very general mechanism as the user could define the tag data layout
> in many possible ways and it would be difficult to cover all use cases
> from a library standpoint. Remember that for custom defined Tags, you
> can also use exchange_tag/reduce_tags in ParallelComm to get the data
> that you need on shared entities. If exchange_tags does not suit your
> needs, you can see if you can adapt augment_default_sets_with_ghosts
> method for your use case. Let me know if that helps.
> Vijay
> [1] http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a76dced0b6dbe2fb99340945c7ca3c0f2
> On Mon, Oct 29, 2018 at 1:49 PM Ryan O'Kuinghttons
> <ryan.okuinghttons at noaa.gov> wrote:
>> Hi Iulian, Vijay,
>> We have a set of custom tags that we use in ESMF, would it be possible
>> to transfer these as well?
>> Ryan
>> On 10/29/18 10:54, Vijay S. Mahadevan wrote:
>>> The default set of tags do get transferred. These would be the
>>> MATERIAL_SET, DIRICHLET/NEUMANN sets etc.
>>> Iulian, did we add a separate method to transfer these to the ghosted
>>> entities ? I vaguely remember something like that.
>>> Vijay
>>> On Mon, Oct 29, 2018 at 12:42 PM Ryan O'Kuinghttons
>>>> Hi Vijay,
>>>> I ran into another issue with the call to exchange_ghost_cells, but this
>>>> is probably just a misunderstanding on my part. I find that the tag
>>>> information that is part of the mesh before the the call does not
>>>> transfer to the newly created faces. Is there some way to ask moab to
>>>> transfer tags when creating ghost entities? (FWIW, I could not find this
>>>> in the example you sent me) Thanks,
>>>> Ryan
>>>> On 10/26/18 07:36, Ryan O'Kuinghttons wrote:
>>>>> Hi Vijay,
>>>>> I resolved the issue with not getting any shared, owned entities back
>>>>> by using the other version of resolve_shared_ents, as demonstrated in
>>>>> the example you indicated. I created a Range containing all elements
>>>>> (faces for moab), and used that as input.
>>>>>     Range range_ent;
>>>>> merr=mb->get_entities_by_dimension(0,this->sdim,range_ent);
>>>>>     MBMESH_CHECK_ERR(merr, localrc);
>>>>>     merr = pcomm->resolve_shared_ents(0, range_ent, this->sdim, 1);
>>>>> The first version of the interface (which does not use a Range input)
>>>>> does not work for me:
>>>>>     merr = pcomm->resolve_shared_ents(0, this->sdim, 1);
>>>>> Otherwise, everything else seems to be resolved with this issue,
>>>>> thanks again for all of your help!!
>>>>> Ryan
>>>>> On 10/25/18 15:13, Vijay S. Mahadevan wrote:
>>>>>> Ryan, I don't see anything obviously wrong in the code below. Does
>>>>>> your shared_ents not have any entities after parallel resolve ? If you
>>>>>> can replicate your issue in a small standalone test, we should be able
>>>>>> to quickly find out what's going wrong.
>>>>>> Look at the test_reduce_tag_explicit_dest routine in
>>>>>> test/parallel/parallel_unit_tests.cpp:1617. It has the workflow where
>>>>>> you create a mesh in memory, resolve shared entities, get shared
>>>>>> entities and even set/reduce tag data.
>>>>>> Vijay
>>>>>> On Thu, Oct 25, 2018 at 4:25 PM Ryan O'Kuinghttons
>>>>>>> OK, that allows the resolve_shared_ents routine to complete without
>>>>>>> error, but I still don't get any shared, owned entities back from the
>>>>>>> get_shared_entities/filter_pstatus calls:
>>>>>>>       Range shared_ents;
>>>>>>>       // Get entities shared with all other processors
>>>>>>>       merr = pcomm->get_shared_entities(-1, shared_ents);
>>>>>>>       // Filter shared entities with not not_owned, which means owned
>>>>>>>       Range owned_entities;
>>>>>>>       merr = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED,
>>>>>>> PSTATUS_NOT, -1, &owned_entities);
>>>>>>>       unsigned int nums[4] = {0}; // to store the owned entities per
>>>>>>> dimension
>>>>>>>       for (int i = 0; i < 4; i++)
>>>>>>>         nums[i] = (int)owned_entities.num_of_dimension(i);
>>>>>>>       vector<int> rbuf(nprocs*4, 0);
>>>>>>>       MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, mpi_comm);
>>>>>>>       // Print the stats gathered:
>>>>>>>       if (0 == rank) {
>>>>>>>         for (int i = 0; i < nprocs; i++)
>>>>>>>           cout << " Shared, owned entities on proc " << i << ": " <<
>>>>>>> rbuf[4*i] << " verts, " <<
>>>>>>>               rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces,
>>>>>>> rbuf[4*i + 3] << " elements" << endl;
>>>>>>> OUTPUT:
>>>>>>>      Shared, owned entities on proc 0: 0 verts, 0 edges, 0 faces, 0
>>>>>>> elements
>>>>>>>      Shared, owned entities on proc 1: 0 verts, 0 edges, 0 faces, 0
>>>>>>> elements
>>>>>>>      Shared, owned entities on proc 2: 0 verts, 0 edges, 0 faces, 0
>>>>>>> elements
>>>>>>>      Shared, owned entities on proc 3: 0 verts, 0 edges, 0 faces, 0
>>>>>>> elements
>>>>>>> Note: I also tried changing the -1 to 2 in the
>>>>>>> get_shared_entities/filter_pstatus calls to only retrieve elements.
>>>>>>> On 10/25/18 13:57, Vijay S. Mahadevan wrote:
>>>>>>>> No problem. Can you try 1 for the last argument to look for edges as
>>>>>>>> the shared_dim.
>>>>>>>> Vijay
>>>>>>>> On Thu, Oct 25, 2018 at 3:41 PM Ryan O'Kuinghttons
>>>>>>>>> OK, thanks again for that explanation, I never would have been
>>>>>>>>> able to figure out that this_set was the root set. I apologize for
>>>>>>>>> all the dumb questions, hopefully they are all getting me closer
>>>>>>>>> to self sufficiency..
>>>>>>>>> I'm getting an error that doesn't make sense to me. I specifying
>>>>>>>>> the resolve_dim and shared_dim in the call:
>>>>>>>>>       // Get the ParallelComm instance
>>>>>>>>>       ParallelComm* pcomm = new ParallelComm(mb, mpi_comm);
>>>>>>>>>       int nprocs = pcomm->proc_config().proc_size();
>>>>>>>>>       int rank = pcomm->proc_config().proc_rank();
>>>>>>>>>       // get the root set handle
>>>>>>>>>       EntityHandle root_set = mb->get_root_set();
>>>>>>>>>       merr = pcomm->resolve_shared_ents(root_set, 2, -1);
>>>>>>>>> but I'm getting this message:
>>>>>>>>> [0]MOAB ERROR: Unable to guess shared_dim or resolve_dim!
>>>>>>>>> what am i missing?
>>>>>>>>> On 10/25/18 12:51, Vijay S. Mahadevan wrote:
>>>>>>>>> It is your root set or fileset if you added entities to it. You
>>>>>>>>> can get the root set handle from Core object.
>>>>>>>>> Vijay
>>>>>>>>> On Thu, Oct 25, 2018, 14:38 Ryan O'Kuinghttons
>>>>>>>>>> Thanks again, Vijay. However, I still don't understand what this_set
>>>>>>>>>> should be, is it an output maybe?
>>>>>>>>>> Ryan
>>>>>>>>>> On 10/25/18 12:27, Vijay S. Mahadevan wrote:
>>>>>>>>>>> You can try either the first or the second variant instead [1] with
>>>>>>>>>>> following arguments.
>>>>>>>>>>> ErrorCode moab::ParallelComm::resolve_shared_ents(EntityHandle
>>>>>>>>>>> this_set,
>>>>>>>>>>> int resolve_dim = 2,
>>>>>>>>>>> int shared_dim = -1,
>>>>>>>>>>> const Tag * id_tag = 0
>>>>>>>>>>> That should resolve 2-dim entities with shared edges across
>>>>>>>>>>> partitions. You can leave id_tag pointer as zero since the
>>>>>>>>>>> default is
>>>>>>>>>>> GLOBAL_ID.
>>>>>>>>>>>> This brings up a more general question I've had about the moab
>>>>>>>>>>> documentation for a while. In the doc for this routine, it only
>>>>>>>>>>> lists 2
>>>>>>>>>>> parameters, proc_ents and shared_dim, even though in the function
>>>>>>>>>>> signature above it clearly shows more. I've had trouble
>>>>>>>>>>> understanding
>>>>>>>>>>> which parameters are relevant in the past, or what they do
>>>>>>>>>>> because I'm
>>>>>>>>>>> not quite sure how to read the documentation.
>>>>>>>>>>> This is an oversight. We will go through and rectify some of the
>>>>>>>>>>> inconsistencies in the documentation. We are preparing for an
>>>>>>>>>>> upcoming
>>>>>>>>>>> release and I'll make sure that routines in Core/ParallelComm have
>>>>>>>>>>> updated documentation that match the interfaces. Meanwhile, if you
>>>>>>>>>>> have questions, feel free to shoot an email to the list.
>>>>>>>>>>> Hope that helps.
>>>>>>>>>>> Vijay
>>>>>>>>>>> [1]
>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a29a3b834b3fc3b4ddb3a5d8a78a37c8a
>>>>>>>>>>> On Thu, Oct 25, 2018 at 1:58 PM Ryan O'Kuinghttons
>>>>>>>>>>>> Hi Vijay,
>>>>>>>>>>>> Thanks again for that explanation.
>>>>>>>>>>>> ESMF does use unique global ids for the vertices and set them
>>>>>>>>>>>> to the
>>>>>>>>>>>> GLOBAL_ID in the moab mesh. So I think we are good there.
>>>>>>>>>>>> I can't quite figure out how to use resolve_shared_entities
>>>>>>>>>>>> though.
>>>>>>>>>>>> There are three versions of the call in the documentation, and
>>>>>>>>>>>> I assume
>>>>>>>>>>>> that I should use the first and pass in a Range containing all
>>>>>>>>>>>> entities
>>>>>>>>>>>> for proc_ents:
>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a59e35d9906f2e33fe010138a144a5cb6
>>>>>>>>>>>> However, I'm not sure what the this_set EntityHandle should be.
>>>>>>>>>>>> lists 2
>>>>>>>>>>>> understanding
>>>>>>>>>>>> because I'm
>>>>>>>>>>>> Any example or explanation you give me for
>>>>>>>>>>>> resolve_shared_entities is
>>>>>>>>>>>> much appreciated!
>>>>>>>>>>>> Ryan
>>>>>>>>>>>> On 10/25/18 09:40, Vijay S. Mahadevan wrote:
>>>>>>>>>>>>> Hi Ryan,
>>>>>>>>>>>>> Glad the example helped.
>>>>>>>>>>>>>> The example shows the ghost exchange happening between shared
>>>>>>>>>>>>>> owned
>>>>>>>>>>>>> entities. In my experiments I've been unable to make the ghost
>>>>>>>>>>>>> exchange
>>>>>>>>>>>>> work, and I think that might be because my entities are not
>>>>>>>>>>>>> shared.
>>>>>>>>>>>>> You need to call resolve_shared_entities on the entities prior to
>>>>>>>>>>>>> doing ghost exchange. When we load the mesh from file, this
>>>>>>>>>>>>> happens
>>>>>>>>>>>>> automatically based on the read options but if you are forming
>>>>>>>>>>>>> a mesh
>>>>>>>>>>>>> in memory, you need to make sure that the shared vertices have
>>>>>>>>>>>>> the
>>>>>>>>>>>>> same GLOBAL_ID numbering consistently across processes. That
>>>>>>>>>>>>> is shared
>>>>>>>>>>>>> vertices are unique. Once that is set, shared entities
>>>>>>>>>>>>> resolution will
>>>>>>>>>>>>> work correctly out of the box and you will have shared
>>>>>>>>>>>>> edges/entities
>>>>>>>>>>>>> query working correctly. A call to get ghosted layers once
>>>>>>>>>>>>> this is
>>>>>>>>>>>>> done would be the way to go.
>>>>>>>>>>>>> I assume ESMF has a unique global numbering for the vertices ?
>>>>>>>>>>>>> Use
>>>>>>>>>>>>> that to set the GLOBAL_ID tag. Let us know if you are still
>>>>>>>>>>>>> having
>>>>>>>>>>>>> issues.
>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>> On Thu, Oct 25, 2018 at 11:17 AM Ryan O'Kuinghttons
>>>>>>>>>>>>>> Hi Vijay,
>>>>>>>>>>>>>> I've had some time to play with this now, and I have another
>>>>>>>>>>>>>> question.
>>>>>>>>>>>>>> Thank you for sending along the example code, it has been
>>>>>>>>>>>>>> extremely
>>>>>>>>>>>>>> helpful.
>>>>>>>>>>>>>> owned
>>>>>>>>>>>>>> ghost exchange
>>>>>>>>>>>>>> shared. The
>>>>>>>>>>>>>> situation I have is entities that are owned wholly on a single
>>>>>>>>>>>>>> processor, which need to be communicated to other processors
>>>>>>>>>>>>>> which
>>>>>>>>>>>>>> require them as part of a halo region for mesh based
>>>>>>>>>>>>>> computation. In
>>>>>>>>>>>>>> this situation would I need to "share" my entities across the
>>>>>>>>>>>>>> whole
>>>>>>>>>>>>>> processor space, before requesting a ghost exchange? I'm not
>>>>>>>>>>>>>> even really
>>>>>>>>>>>>>> sure what shared entities mean, is there a good place to look
>>>>>>>>>>>>>> in the
>>>>>>>>>>>>>> documentation to learn more about the terminology? Thanks,
>>>>>>>>>>>>>> Ryan
>>>>>>>>>>>>>> On 10/8/18 12:17, Vijay S. Mahadevan wrote:
>>>>>>>>>>>>>>> Ryan,
>>>>>>>>>>>>>>> You need to use the ParallelComm object in MOAB to call
>>>>>>>>>>>>>>> exchange_ghost_cells [1] with appropriate levels of ghost
>>>>>>>>>>>>>>> layers for
>>>>>>>>>>>>>>> your mesh. This needs to be done after the mesh is loaded,
>>>>>>>>>>>>>>> or you can
>>>>>>>>>>>>>>> pass this information also as part of the options when
>>>>>>>>>>>>>>> loading a file
>>>>>>>>>>>>>>> and MOAB will internally load the file with ghosted layers.
>>>>>>>>>>>>>>> Here's an
>>>>>>>>>>>>>>> example [2].
>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>> [1]
>>>>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a55dfa308f56fd368319bfb4244428878
>>>>>>>>>>>>>>> [2]
>>>>>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/HelloParMOAB_8cpp-example.html
>>>>>>>>>>>>>>> On Mon, Oct 8, 2018 at 1:23 PM Ryan O'Kuinghttons
>>>>>>>>>>>>>>>> Hi, I am wondering if there is a way to create ghost
>>>>>>>>>>>>>>>> elements in MOAB.
>>>>>>>>>>>>>>>> By this I mean a list of copies of elements surrounding a
>>>>>>>>>>>>>>>> specific MOAB
>>>>>>>>>>>>>>>> element, ghost elements may exist on a different processor
>>>>>>>>>>>>>>>> than the
>>>>>>>>>>>>>>>> source element. I see a ghost_elems class in the appData
>>>>>>>>>>>>>>>> namespace, but
>>>>>>>>>>>>>>>> there is not much documentation on how to use it.. Thank you,
>>>>>>>>>>>>>>>> Ryan O'Kuinghttons
>>>>>>>>>>>>>>>> Cherokee Nation Management and Consulting
>>>>>>>>>>>>>>>> NESII/NOAA/Earth System Research Laboratory
>>>>>>>>>>>>>>>> https://www.esrl.noaa.gov/gsd/nesii/
