[MOAB-dev] ghost/halo elements
Ryan O'Kuinghttons ryan.okuinghttons at noaa.gov
Mon Oct 29 11:42:24 CDT 2018
Hi Vijay,
I ran into another issue with the call to exchange_ghost_cells, but this
is probably just a misunderstanding on my part. I find that the tag
information that is part of the mesh before the the call does not
transfer to the newly created faces. Is there some way to ask moab to
transfer tags when creating ghost entities? (FWIW, I could not find this
in the example you sent me) Thanks,
Ryan
On 10/26/18 07:36, Ryan O'Kuinghttons wrote:
> Hi Vijay,
> I resolved the issue with not getting any shared, owned entities back
> by using the other version of resolve_shared_ents, as demonstrated in
> the example you indicated. I created a Range containing all elements
> (faces for moab), and used that as input.
>   Range range_ent;
> merr=mb->get_entities_by_dimension(0,this->sdim,range_ent);
>   MBMESH_CHECK_ERR(merr, localrc);
>   merr = pcomm->resolve_shared_ents(0, range_ent, this->sdim, 1);
> The first version of the interface (which does not use a Range input)
> does not work for me:
>   merr = pcomm->resolve_shared_ents(0, this->sdim, 1);
> Otherwise, everything else seems to be resolved with this issue,
> thanks again for all of your help!!
> Ryan
> On 10/25/18 15:13, Vijay S. Mahadevan wrote:
>> Ryan, I don't see anything obviously wrong in the code below. Does
>> your shared_ents not have any entities after parallel resolve ? If you
>> can replicate your issue in a small standalone test, we should be able
>> to quickly find out what's going wrong.
>> Look at the test_reduce_tag_explicit_dest routine in
>> test/parallel/parallel_unit_tests.cpp:1617. It has the workflow where
>> you create a mesh in memory, resolve shared entities, get shared
>> entities and even set/reduce tag data.
>> Vijay
>> On Thu, Oct 25, 2018 at 4:25 PM Ryan O'Kuinghttons
>> <ryan.okuinghttons at noaa.gov> wrote:
>>> OK, that allows the resolve_shared_ents routine to complete without
>>> error, but I still don't get any shared, owned entities back from the
>>> get_shared_entities/filter_pstatus calls:
>>>     Range shared_ents;
>>>     // Get entities shared with all other processors
>>>     merr = pcomm->get_shared_entities(-1, shared_ents);
>>>     // Filter shared entities with not not_owned, which means owned
>>>     Range owned_entities;
>>>     merr = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED,
>>> PSTATUS_NOT, -1, &owned_entities);
>>>     unsigned int nums[4] = {0}; // to store the owned entities per
>>> dimension
>>>     for (int i = 0; i < 4; i++)
>>>       nums[i] = (int)owned_entities.num_of_dimension(i);
>>>     vector<int> rbuf(nprocs*4, 0);
>>>     MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, mpi_comm);
>>>     // Print the stats gathered:
>>>     if (0 == rank) {
>>>       for (int i = 0; i < nprocs; i++)
>>>         cout << " Shared, owned entities on proc " << i << ": " <<
>>> rbuf[4*i] << " verts, " <<
>>>             rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces,
>>> rbuf[4*i + 3] << " elements" << endl;
>>> OUTPUT:
>>>    Shared, owned entities on proc 0: 0 verts, 0 edges, 0 faces, 0
>>> elements
>>>    Shared, owned entities on proc 1: 0 verts, 0 edges, 0 faces, 0
>>> elements
>>>    Shared, owned entities on proc 2: 0 verts, 0 edges, 0 faces, 0
>>> elements
>>>    Shared, owned entities on proc 3: 0 verts, 0 edges, 0 faces, 0
>>> elements
>>> Note: I also tried changing the -1 to 2 in the
>>> get_shared_entities/filter_pstatus calls to only retrieve elements.
>>> On 10/25/18 13:57, Vijay S. Mahadevan wrote:
>>>> No problem. Can you try 1 for the last argument to look for edges as
>>>> the shared_dim.
>>>> Vijay
>>>> On Thu, Oct 25, 2018 at 3:41 PM Ryan O'Kuinghttons
>>>>> OK, thanks again for that explanation, I never would have been
>>>>> able to figure out that this_set was the root set. I apologize for
>>>>> all the dumb questions, hopefully they are all getting me closer
>>>>> to self sufficiency..
>>>>> I'm getting an error that doesn't make sense to me. I specifying
>>>>> the resolve_dim and shared_dim in the call:
>>>>>     // Get the ParallelComm instance
>>>>>     ParallelComm* pcomm = new ParallelComm(mb, mpi_comm);
>>>>>     int nprocs = pcomm->proc_config().proc_size();
>>>>>     int rank = pcomm->proc_config().proc_rank();
>>>>>     // get the root set handle
>>>>>     EntityHandle root_set = mb->get_root_set();
>>>>>     merr = pcomm->resolve_shared_ents(root_set, 2, -1);
>>>>> but I'm getting this message:
>>>>> [0]MOAB ERROR: Unable to guess shared_dim or resolve_dim!
>>>>> what am i missing?
>>>>> On 10/25/18 12:51, Vijay S. Mahadevan wrote:
>>>>> It is your root set or fileset if you added entities to it. You
>>>>> can get the root set handle from Core object.
>>>>> Vijay
>>>>> On Thu, Oct 25, 2018, 14:38 Ryan O'Kuinghttons
>>>>>> Thanks again, Vijay. However, I still don't understand what this_set
>>>>>> should be, is it an output maybe?
>>>>>> Ryan
>>>>>> On 10/25/18 12:27, Vijay S. Mahadevan wrote:
>>>>>>> You can try either the first or the second variant instead [1] with
>>>>>>> following arguments.
>>>>>>> ErrorCode moab::ParallelComm::resolve_shared_ents(EntityHandle
>>>>>>> this_set,
>>>>>>> int resolve_dim = 2,
>>>>>>> int shared_dim = -1,
>>>>>>> const Tag * id_tag = 0
>>>>>>> That should resolve 2-dim entities with shared edges across
>>>>>>> partitions. You can leave id_tag pointer as zero since the
>>>>>>> default is
>>>>>>> GLOBAL_ID.
>>>>>>>> This brings up a more general question I've had about the moab
>>>>>>> documentation for a while. In the doc for this routine, it only
>>>>>>> lists 2
>>>>>>> parameters, proc_ents and shared_dim, even though in the function
>>>>>>> signature above it clearly shows more. I've had trouble
>>>>>>> understanding
>>>>>>> which parameters are relevant in the past, or what they do
>>>>>>> because I'm
>>>>>>> not quite sure how to read the documentation.
>>>>>>> This is an oversight. We will go through and rectify some of the
>>>>>>> inconsistencies in the documentation. We are preparing for an
>>>>>>> upcoming
>>>>>>> release and I'll make sure that routines in Core/ParallelComm have
>>>>>>> updated documentation that match the interfaces. Meanwhile, if you
>>>>>>> have questions, feel free to shoot an email to the list.
>>>>>>> Hope that helps.
>>>>>>> Vijay
>>>>>>> [1]
>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a29a3b834b3fc3b4ddb3a5d8a78a37c8a
>>>>>>> On Thu, Oct 25, 2018 at 1:58 PM Ryan O'Kuinghttons
>>>>>>>> Hi Vijay,
>>>>>>>> Thanks again for that explanation.
>>>>>>>> ESMF does use unique global ids for the vertices and set them
>>>>>>>> to the
>>>>>>>> GLOBAL_ID in the moab mesh. So I think we are good there.
>>>>>>>> I can't quite figure out how to use resolve_shared_entities
>>>>>>>> though.
>>>>>>>> There are three versions of the call in the documentation, and
>>>>>>>> I assume
>>>>>>>> that I should use the first and pass in a Range containing all
>>>>>>>> entities
>>>>>>>> for proc_ents:
>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a59e35d9906f2e33fe010138a144a5cb6
>>>>>>>> However, I'm not sure what the this_set EntityHandle should be.
>>>>>>>> lists 2
>>>>>>>> understanding
>>>>>>>> because I'm
>>>>>>>> Any example or explanation you give me for
>>>>>>>> resolve_shared_entities is
>>>>>>>> much appreciated!
>>>>>>>> Ryan
>>>>>>>> On 10/25/18 09:40, Vijay S. Mahadevan wrote:
>>>>>>>>> Hi Ryan,
>>>>>>>>> Glad the example helped.
>>>>>>>>>> The example shows the ghost exchange happening between shared
>>>>>>>>>> owned
>>>>>>>>> entities. In my experiments I've been unable to make the ghost
>>>>>>>>> exchange
>>>>>>>>> work, and I think that might be because my entities are not
>>>>>>>>> shared.
>>>>>>>>> You need to call resolve_shared_entities on the entities prior to
>>>>>>>>> doing ghost exchange. When we load the mesh from file, this
>>>>>>>>> happens
>>>>>>>>> automatically based on the read options but if you are forming
>>>>>>>>> a mesh
>>>>>>>>> in memory, you need to make sure that the shared vertices have
>>>>>>>>> the
>>>>>>>>> same GLOBAL_ID numbering consistently across processes. That
>>>>>>>>> is shared
>>>>>>>>> vertices are unique. Once that is set, shared entities
>>>>>>>>> resolution will
>>>>>>>>> work correctly out of the box and you will have shared
>>>>>>>>> edges/entities
>>>>>>>>> query working correctly. A call to get ghosted layers once
>>>>>>>>> this is
>>>>>>>>> done would be the way to go.
>>>>>>>>> I assume ESMF has a unique global numbering for the vertices ?
>>>>>>>>> Use
>>>>>>>>> that to set the GLOBAL_ID tag. Let us know if you are still
>>>>>>>>> having
>>>>>>>>> issues.
>>>>>>>>> Vijay
>>>>>>>>> On Thu, Oct 25, 2018 at 11:17 AM Ryan O'Kuinghttons
>>>>>>>>>> Hi Vijay,
>>>>>>>>>> I've had some time to play with this now, and I have another
>>>>>>>>>> question.
>>>>>>>>>> Thank you for sending along the example code, it has been
>>>>>>>>>> extremely
>>>>>>>>>> helpful.
>>>>>>>>>> owned
>>>>>>>>>> ghost exchange
>>>>>>>>>> shared. The
>>>>>>>>>> situation I have is entities that are owned wholly on a single
>>>>>>>>>> processor, which need to be communicated to other processors
>>>>>>>>>> which
>>>>>>>>>> require them as part of a halo region for mesh based
>>>>>>>>>> computation. In
>>>>>>>>>> this situation would I need to "share" my entities across the
>>>>>>>>>> whole
>>>>>>>>>> processor space, before requesting a ghost exchange? I'm not
>>>>>>>>>> even really
>>>>>>>>>> sure what shared entities mean, is there a good place to look
>>>>>>>>>> in the
>>>>>>>>>> documentation to learn more about the terminology? Thanks,
>>>>>>>>>> Ryan
>>>>>>>>>> On 10/8/18 12:17, Vijay S. Mahadevan wrote:
>>>>>>>>>>> Ryan,
>>>>>>>>>>> You need to use the ParallelComm object in MOAB to call
>>>>>>>>>>> exchange_ghost_cells [1] with appropriate levels of ghost
>>>>>>>>>>> layers for
>>>>>>>>>>> your mesh. This needs to be done after the mesh is loaded,
>>>>>>>>>>> or you can
>>>>>>>>>>> pass this information also as part of the options when
>>>>>>>>>>> loading a file
>>>>>>>>>>> and MOAB will internally load the file with ghosted layers.
>>>>>>>>>>> Here's an
>>>>>>>>>>> example [2].
>>>>>>>>>>> Vijay
>>>>>>>>>>> [1]
>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/classmoab_1_1ParallelComm.html#a55dfa308f56fd368319bfb4244428878
>>>>>>>>>>> [2]
>>>>>>>>>>> http://ftp.mcs.anl.gov/pub/fathom/moab-docs-develop/HelloParMOAB_8cpp-example.html
>>>>>>>>>>> On Mon, Oct 8, 2018 at 1:23 PM Ryan O'Kuinghttons
>>>>>>>>>>>> Hi, I am wondering if there is a way to create ghost
>>>>>>>>>>>> elements in MOAB.
>>>>>>>>>>>> By this I mean a list of copies of elements surrounding a
>>>>>>>>>>>> specific MOAB
>>>>>>>>>>>> element, ghost elements may exist on a different processor
>>>>>>>>>>>> than the
>>>>>>>>>>>> source element. I see a ghost_elems class in the appData
>>>>>>>>>>>> namespace, but
>>>>>>>>>>>> there is not much documentation on how to use it.. Thank you,
>>>>>>>>>>>> Ryan O'Kuinghttons
>>>>>>>>>>>> Cherokee Nation Management and Consulting
>>>>>>>>>>>> NESII/NOAA/Earth System Research Laboratory
>>>>>>>>>>>> https://www.esrl.noaa.gov/gsd/nesii/
