[MOAB-dev] Reset pcomm
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Tue Nov 28 06:07:29 CST 2017
Thanks Vijay,
Only to report, deleting and creating new pcomm, solved the problem.
Lukasz
On 27 Nov 2017, at 22:15, Lukasz Kaczmarczyk <Lukasz.Kaczmarczyk at glasgow.ac.uk<mailto:Lukasz.Kaczmarczyk at glasgow.ac.uk>> wrote:
Hello,
See attached figure. You can see red surface with is imprinted on the mesh. Surface is imprinted by edge splitting.  With this, I create  good quality mesh with node merging and flips. The surface is evolving and I solve PDE on it.
What would you suggest, to create new pcomm on cloned mpi comm?
Lukasz
On 27 Nov 2017, at 22:06, Vijay S. Mahadevan <vijay.m at gmail.com<mailto:vijay.m at gmail.com>> wrote:
You could try calling the remove_pcomm to delete it from the global
tag/internal set. Now calling add_pcomm should return a ParallelComm
object with the same ID, potentially. This should theoretically help
what you want to do, but I still don't entirely see the use of
recreating the PComm object on the same MPI_Comm.
Vijay
On Mon, Nov 27, 2017 at 4:58 PM, Lukasz Kaczmarczyk
Hello,
Thanks for fast response. Yes, changes are in the original file set. On some subset of entities and new create new entities. I do mesh cutting with the arbitrary surface.
Currently I resolve ents on that meshset, but before I reset tags, pstatus_tag(), sharedp_tag(), sharedps_tag(), sharedh_tag(), sharedhs_tag(), and in principle it works.  I do that on the same pcomm.
I create pcomm like this
ParallelComm *pcomm =
       ParallelComm::get_pcomm(&moab, MYPCOMM_INDEX, &moab_comm_world);
Is it a way to delete this and create a new pcomm on the same index?
Lukasz
On 27 Nov 2017, at 21:38, Vijay S. Mahadevan <vijay.m at gmail.com<mailto:vijay.m at gmail.com>> wrote:
Lukasz,
Are the topological changes still part of the original file_set ? If
yes, have you tried to just call resolve_shared_ents on that file set
again ? Does this not solve the issue ? There is no global way to
reset all the ParallelComm tags currently I think, but you could
potentially create a new ParallelComm object spanning the same
communicator as before and redo your operations on the older or a new
file set containing the entity changes.
Also, when you say repartition, do you mean dynamically load balance
and redistribute entities ? If not, please explain.
If neither of these suggestions are helpful, it would be useful if you
can provide an example use case for us to better understand your
workflow.
Vijay
On Mon, Nov 27, 2017 at 4:02 PM, Lukasz Kaczmarczyk
Hello,
I do intense topological changes and need to keep precisely the same mesh an all procs, at least is the simplest solution.  I partition mesh and resolve shared entities. All calculations are distributed, and I build approx. fields only on partitions. It works great.
However, I am not clear what is the best way to reset whole ParallelComm and ParallelComm tags, etc. and once again resolve shared entities. I repartition problem to balance mesh after some topological changes on the mesh. Can you give me any guidance and advice?
Kind regards,
Lukasz
[University of Glasgow: The Times Scottish University of the Year 2018]
<cut_sylinedr_with_holes.png>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20171128/3140f704/attachment.html>
