[MOAB-dev] AdaptiveKDTree and point search
Vijay S. Mahadevan
vijay.m at gmail.com
Wed Nov 15 09:55:23 CST 2017
Lukasz,
Any chance you can isolate it to a small test ? Looks like the LD code
for LinearTet is hitting an assertion. We need to see why would nverts
for a LinearTet element not be 4. What kind of mesh are you using ?
We've been refining and adding many new capabilities in the coupler
and LD recently. I just want to make sure that the issue below is not
something in the setup of the mesh, but a regression from the new
changes before we spend a lot of time finding the exact problem here.
Vijay
On Wed, Nov 15, 2017 at 10:36 AM, Lukasz Kaczmarczyk
<Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> Hello,
> I switch recently to MOAB 5.0.0 and I encounter some problems with point search. This is for tet mesh, I expecting that I doing something wrong. It was working with older MOAB. I can work with leaf, but will be nice to have this ok.
> myTree = boost::shared_ptr<AdaptiveKDTree>(new AdaptiveKDTree(&mwlsMoab));
> PetscPrintf(mField.get_comm(),"Build tree ... ");
> rval = myTree->build_tree(levelTets,&treeRoot); CHKERRQ_MOAB(rval);
> boost::shared_ptr<ElemEvaluator> elemEval(myTree,new ElemEvaluator(&mwlsMoab));
> myTree->set_eval(elemEval.get());
> PetscPrintf(mField.get_comm(),"done\n”);
> and using it like that
> rval = myTree->point_search(
> material_coords,leaf_out,maxEdgeL*1e-5,maxEdgeL*1e-3,NULL,NULL,¶ms
> I get following error,
> ssertion failed: (nverts == 4 && verts), function initFcn, file LocalDiscretization/LinearTet.cpp, line 21.
> [likask:32071] *** Process received signal ***
> [likask:32071] Signal: Abort trap: 6 (6)
> [likask:32071] Signal code: (0)
> [likask:32071] [ 0] 0 libsystem_platform.dylib 0x00007fff9d14f52a _sigtramp + 26
> [likask:32071] [ 1] 0 ??? 0x00007fff5acbdea0 0x0 + 140734716698272
> [likask:32071] [ 2] 0 libsystem_c.dylib 0x00007fff8aca76df abort + 129
> [likask:32071] [ 3] 0 libsystem_c.dylib 0x00007fff8ac6edd8 basename + 0
> [likask:32071] [ 4] 0 libMOAB.0.dylib 0x000000010a4fc1ec _ZN4moab9LinearTet7initFcnEPKdiRPd + 108
> [likask:32071] [ 5] 0 libMOAB.0.dylib 0x000000010a1f5cad _ZN4moab13ElemEvaluator14set_ent_handleEm + 1309
> [likask:32071] [ 6] 0 libMOAB.0.dylib 0x000000010a4f6e45 _ZN4moab13ElemEvaluator22find_containing_entityERNS_5RangeEPKdddRmPdPj + 197
> [likask:32071] [ 7] 0 libMOAB.0.dylib 0x000000010a19c033 _ZN4moab13ElemEvaluator22find_containing_entityEmPKdddRmPdPj + 371
> [likask:32071] [ 8] 0 libMOAB.0.dylib 0x000000010a18ef65 _ZN4moab14AdaptiveKDTree12point_searchEPKdRmddPbPmPNS_8CartVectE + 2069
> [likask:32071] [ 9] 0 mwls 0x00000001051a8035 _ZN17FractureMechanics10MWLSApprox17getInfluenceNodesEPdb + 1077
> [likask:32071] [10] 0 mwls 0x0000000104f47913 main + 22179
> [likask:32071] [11] 0 libdyld.dylib 0x00007fff904af5ad start + 1
> [likask:32071] [12] 0 ??? 0x000000000000000b 0x0 + 11
> Can you pleas advise me how I can fix this?
> Kind regards,
> Lukasz
> [University of Glasgow: The Times Scottish University of the Year 2018]
