[MOAB-dev] Range contiguity method
Vijay S. Mahadevan
vijay.m at gmail.com
Wed Aug 9 17:38:15 CDT 2017
Patrick, you are looking for something like Range::psize() [1], which
returns the number of non-contiguous sequences in the object. Does
that help ? If this is not what you are asking, them I'm unclear what
you mean by "rapidly check that a Range object contains a set of
contiguous values".
Vijay
[1] ftp://ftp.mcs.anl.gov/pub/fathom/moab-docs/classmoab_1_1Range.html#a04d1b55838117d5ef4ba3c4dfb4d2df0
On Tue, Aug 8, 2017 at 11:30 PM, Patrick Shriwise <shriwise at wisc.edu> wrote:
> Hi all,
> I'm wondering if there is a way to rapidly check that a Range object
> contains a set of contiguous values.
> Naively, it seems that this can be done by checking that it is made up of
> only one pair_node by looking at the mNext & mPrev pointers to verify this
> is the case.
> This would allow some MOAB interfaces (such as the GeomTopoTool) to rapidly
> determine if they are working only with contiguous EntitySets and take
> advantage of this fact.
> Cheers,
> Patrick
