[MOAB-dev] linking error on BlueGene?
Vijay S. Mahadevan vijay.m at gmail.com
Tue May 2 14:38:36 CDT 2017
As the compiler error suggests, can you try adding
CXXFLAGS="-qlanglvl=variadictemplates" and run make ? If that builds
fine, we will update configure to add this flag.
Vijay
On Tue, May 2, 2017 at 2:14 PM, Ron Rahaman <rahaman at mcs.anl.gov> wrote:
> Hi guys,
> I just wanted to check in on this.  Any suggestions?
> Thanks,
> Ron
> On Wed, Apr 26, 2017 at 12:44 PM Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
>> Rajeev, he is working on MOAB 4.9.0 and not on MOAB master.
>> Vijay
>> On Wed, Apr 26, 2017 at 12:20 PM,  <jain at mcs.anl.gov> wrote:
>> > One quick pointer (might not solve the error below): I see your
>> > configure
>> > line:
>> > /configure --prefix=/home/rrahaman/sharp-libs/moab-4.9.0-ibmcmp-may2016
>> > --libdir=/home/rrahaman/sharp-libs/moab-4.9.0-ibmcmp-may2016/lib
>> > --enable-optimize=yes --enable-shared=no --enable-tools --with-mpi
>> > --with-hdf5=/home/rrahaman/sharp-libs/hdf5-1.8.12-ibmcmp-may2016/
>> > --with-metis=/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016/
>> > --with-parmetis=/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016/
>> > --with-netcdf=/home/rrahaman/sharp-libs/netdf-4.3.0-ibmcmp-may2016
>> > CC=mpicc
>> > CXX=mpicxx FC=mpif90 F77=mpif77
>> > has no Eigen/Blas-lapack (required), just make sure whatever the
>> > configure
>> > picks up is compatible with compilers you are trying to use.
>> > Rajeev Jain
>> > Mathematics and Computer Science
>> > Argonne National Laboratory
>> > 1134, Bldg 240, Chicago IL USA 60439
>> > O: 630-252-3176 jain at mcs.anl.gov
>> > ________________________________
>> > From: Ron Rahaman <rahaman at mcs.anl.gov>
>> > To: Vijay S. Mahadevan <vijay.m at gmail.com>
>> > Cc: "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
>> > Sent: Wednesday, April 26, 2017 8:51 AM
>> > Subject: Re: [MOAB-dev] linking error on BlueGene?
>> > No problem, Vijay.  Looks like I fixed link-time error I originallly
>> > reported, but I'm seeing a new compile-time error later in the build.
>> > As you suggested, using /usr/bin/libtool seems to be working.  I copied
>> > /usr/bin/libtool to my build directory both before *and* after
>> > configuration.  I did that because it appeared that configuration
>> > overwrote
>> > libtool with its own version.  I'm not sure exactly what autotools is
>> > doing
>> > in this situation.  In any case, the link stage appears to succeed now.
>> > Instead of the error I reported, I now see this successful message, and
>> > the
>> > build continues:
>> > libtool: link: ar cru .libs/libMOABpar.a .libs/ParallelComm.o
>> > .libs/ProcConfig.o .libs/ParallelData.o .libs/ParallelMergeMesh.o
>> > .libs/ReadParallel.o .libs/SharedSetData.o .libs/gs.o
>> > .libs/WriteHDF5Parallel.o
>> > libtool: link: ranlib .libs/libMOABpar.a
>> > libtool: link: ( cd ".libs" && rm -f "libMOABpar.la" && ln -s
>> > "../libMOABpar.la" "libMOABpar.la" )
>> > However, after that and many other successfully-compiled objects, I see
>> > these compilation errors:
>> > libtool: compile:  mpicxx -DHAVE_CONFIG_H -I. -I../../src -I../src/moab
>> > -I../src/parallel
>> > -I/home/rrahaman/sharp-libs/netdf-4.3.0-ibmcmp-may2016/include
>> > -I/home/rrahaman/sharp-libs/hdf5-1.8.12-ibmcmp-may2016//include
>> > -I/soft/libraries/alcf/20130312/xl/ZLIB/include
>> > -DBLUEGENE
>> > -I../../src/parallel -DIS_BUILDING_MB -DLOCDIR=src/ -I. -I../../src/io
>> > -I../../src/io/mhdf/include -I../../src/parallel
>> > -I../../src/LocalDiscretization -I../../src/verdict
>> > -I../../src/RefineMesh
>> > -I/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016//include -O2
>> > -DNDEBUG -c ../../src/SparseTag.cpp
>> > -Wp,-qmakedep=gcc,-MF.deps/SparseTag.TPlo  -fPIC -DPIC -o
>> > .libs/SparseTag.o
>> > /soft/compilers/ibmcmp-may2016/vacpp/bg/12.1/bin/.orig/bgxlC_r: 1501-216
>> > (W)
>> > command option -fPIC is not recognized - passed to ld
>> > "/bgsys/drivers/toolchain/V1R2M2_base-efix014/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.7/../../../../powerpc64-bgq-linux/include/c++/4.4.7/tr1_impl/type_traits",
>> > line 226.35: 1540-2935 (S) The current option settings have not enabled
>> > C++0x feature "variadic templates".  Use the C++0x langlvl, or langlvl
>> > "VariadicTemplates" to enable this feature.
>> > line 226.35: 1540-2955 (I) SUGGESTION: Try using
>> > "-qlanglvl=variadictemplates". It looks like you are trying to use the
>> > associated C++0x feature.
>> > line 230.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
>> > found.
>> > line 236.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
>> > found.
>> > line 242.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
>> > found.
>> > line 248.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
>> > found.
>> > make[3]: *** [SparseTag.lo] Error 1
>> > The only things in my .soft file are:
>> > +mpiwrapper-xl
>> > +python
>> > +cmake
>> > @default
>> > I'm using my own installations of HDF5, NetCDF, and Parmetis.  You can
>> > see
>> > them in /home/rrahaman/sharp-libs/.
>> > Thanks again,
>> > Ron
>> > On Tue, Apr 25, 2017 at 2:25 PM Vijay S. Mahadevan <vijay.m at gmail.com>
>> > wrote:
>> > Ron,
>> > We apologize about the delay. I haven't seen such an error before. Can
>> > you provide the exact modules you are using for this configuration ?
>> > Looks like libtool is screwing up. Can you copy /usr/bin/libtool to
>> > your build folder and re-try configuration ?
>> > Meanwhile, we will try to replicate the issue and find a fix.
>> > Vijay
>> > On Mon, Apr 24, 2017 at 11:46 AM, Ron Rahaman <rahaman at mcs.anl.gov>
>> > wrote:
>> >> Hi all,
>> >> I'm building MOAB 4.9.0 Cetus at ANL and I'm getting these errors at
>> >> link
>> >> time (see below).  I've also attached my config.log.  Thanks in advance
>> >> for
>> >> your help.
>> >> Best,
>> >> Ron Rahaman
>> >> libtool: link: ar -X 32_64 cru .libs/libMOABpar.a  ParallelComm.o
>> >> ProcConfig.o ParallelData.o ParallelMergeMesh.o ReadParallel.o
>> >> SharedSetData.o gs.o WriteHDF5Parallel.o
>> >> ar: illegal option -- X
>> >> Usage: ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV]
>> >> [member-name]
>> >> [count] archive-file file...
>> >>        ar -M [<mri-script]
>> >>  commands:
>> >>   d            - delete file(s) from the archive
>> >>   m[ab]        - move file(s) in the archive
>> >>   p            - print file(s) found in the archive
>> >>   q[f]         - quick append file(s) to the archive
>> >>   r[ab][f][u]  - replace existing or insert new file(s) into the
>> >> archive
>> >>   t            - display contents of archive
>> >>   x[o]         - extract file(s) from the archive
>> >>  command specific modifiers:
>> >>   [a]          - put file(s) after [member-name]
>> >>   [b]          - put file(s) before [member-name] (same as [i])
>> >>   [D]          - use zero for timestamps and uids/gids
>> >>   [N]          - use instance [count] of name
>> >>   [f]          - truncate inserted file names
>> >>   [P]          - use full path names when matching
>> >>   [o]          - preserve original dates
>> >>   [u]          - only replace files that are newer than current archive
>> >> contents
>> >>  generic modifiers:
>> >>   [c]          - do not warn if the library had to be created
>> >>   [s]          - create an archive index (cf. ranlib)
>> >>   [S]          - do not build a symbol table
>> >>   [T]          - make a thin archive
>> >>   [v]          - be verbose
>> >>   [V]          - display the version number
>> >>   @<file>      - read options from <file>
>> >>  emulation options:
>> >>   No emulation specific options
>> >> ar: supported targets: elf64-powerpc elf64-powerpcle elf32-powerpc
>> >> elf32-powerpcle aixcoff-rs6000 aixcoff64-rs6000 elf64-little elf64-big
>> >> elf32-little elf32-big elf32-spu srec symbolsrec verilog tekhex binary
>> >> ihex
>> >> make[3]: *** [libMOABpar.la] Error 1
