[MOAB-dev] linking error on BlueGene?
Vijay S. Mahadevan vijay.m at gmail.com
Wed Apr 26 12:44:03 CDT 2017
Rajeev, he is working on MOAB 4.9.0 and not on MOAB master.
Vijay
On Wed, Apr 26, 2017 at 12:20 PM,  <jain at mcs.anl.gov> wrote:
> One quick pointer (might not solve the error below): I see your configure
> line:
> /configure --prefix=/home/rrahaman/sharp-libs/moab-4.9.0-ibmcmp-may2016
> --libdir=/home/rrahaman/sharp-libs/moab-4.9.0-ibmcmp-may2016/lib
> --enable-optimize=yes --enable-shared=no --enable-tools --with-mpi
> --with-hdf5=/home/rrahaman/sharp-libs/hdf5-1.8.12-ibmcmp-may2016/
> --with-metis=/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016/
> --with-parmetis=/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016/
> --with-netcdf=/home/rrahaman/sharp-libs/netdf-4.3.0-ibmcmp-may2016 CC=mpicc
> CXX=mpicxx FC=mpif90 F77=mpif77
> has no Eigen/Blas-lapack (required), just make sure whatever the configure
> picks up is compatible with compilers you are trying to use.
> Rajeev Jain
> Mathematics and Computer Science
> Argonne National Laboratory
> 1134, Bldg 240, Chicago IL USA 60439
> O: 630-252-3176 jain at mcs.anl.gov
> ________________________________
> From: Ron Rahaman <rahaman at mcs.anl.gov>
> To: Vijay S. Mahadevan <vijay.m at gmail.com>
> Cc: "moab-dev at mcs.anl.gov" <moab-dev at mcs.anl.gov>
> Sent: Wednesday, April 26, 2017 8:51 AM
> Subject: Re: [MOAB-dev] linking error on BlueGene?
> No problem, Vijay.  Looks like I fixed link-time error I originallly
> reported, but I'm seeing a new compile-time error later in the build.
> As you suggested, using /usr/bin/libtool seems to be working.  I copied
> /usr/bin/libtool to my build directory both before *and* after
> configuration.  I did that because it appeared that configuration overwrote
> libtool with its own version.  I'm not sure exactly what autotools is doing
> in this situation.  In any case, the link stage appears to succeed now.
> Instead of the error I reported, I now see this successful message, and the
> build continues:
> libtool: link: ar cru .libs/libMOABpar.a .libs/ParallelComm.o
> .libs/ProcConfig.o .libs/ParallelData.o .libs/ParallelMergeMesh.o
> .libs/ReadParallel.o .libs/SharedSetData.o .libs/gs.o
> .libs/WriteHDF5Parallel.o
> libtool: link: ranlib .libs/libMOABpar.a
> libtool: link: ( cd ".libs" && rm -f "libMOABpar.la" && ln -s
> "../libMOABpar.la" "libMOABpar.la" )
> However, after that and many other successfully-compiled objects, I see
> these compilation errors:
> libtool: compile:  mpicxx -DHAVE_CONFIG_H -I. -I../../src -I../src/moab
> -I../src/parallel
> -I/home/rrahaman/sharp-libs/netdf-4.3.0-ibmcmp-may2016/include
> -I/home/rrahaman/sharp-libs/hdf5-1.8.12-ibmcmp-may2016//include
> -I/soft/libraries/alcf/20130312/xl/ZLIB/include
> -I/home/rrahaman/sharp-libs/hdf5-1.8.12-ibmcmp-may2016//include -DBLUEGENE
> -I../../src/parallel -DIS_BUILDING_MB -DLOCDIR=src/ -I. -I../../src/io
> -I../../src/io/mhdf/include -I../../src/parallel
> -I../../src/LocalDiscretization -I../../src/verdict -I../../src/RefineMesh
> -I/home/rrahaman/sharp-libs/parmetis-4.0.2-ibmcmp-may2016//include -O2
> -DNDEBUG -c ../../src/SparseTag.cpp
> -Wp,-qmakedep=gcc,-MF.deps/SparseTag.TPlo  -fPIC -DPIC -o .libs/SparseTag.o
> /soft/compilers/ibmcmp-may2016/vacpp/bg/12.1/bin/.orig/bgxlC_r: 1501-216 (W)
> command option -fPIC is not recognized - passed to ld
> "/bgsys/drivers/toolchain/V1R2M2_base-efix014/gnu-linux/lib/gcc/powerpc64-bgq-linux/4.4.7/../../../../powerpc64-bgq-linux/include/c++/4.4.7/tr1_impl/type_traits",
> line 226.35: 1540-2935 (S) The current option settings have not enabled
> C++0x feature "variadic templates".  Use the C++0x langlvl, or langlvl
> "VariadicTemplates" to enable this feature.
> line 226.35: 1540-2955 (I) SUGGESTION: Try using
> "-qlanglvl=variadictemplates". It looks like you are trying to use the
> associated C++0x feature.
> line 230.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
> found.
> line 236.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
> found.
> line 242.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
> found.
> line 248.41: 1540-0064 (S) Syntax error:  ")" was expected but "..." was
> found.
> make[3]: *** [SparseTag.lo] Error 1
> The only things in my .soft file are:
> +mpiwrapper-xl
> +python
> +cmake
> @default
> I'm using my own installations of HDF5, NetCDF, and Parmetis.  You can see
> them in /home/rrahaman/sharp-libs/.
> Thanks again,
> Ron
> On Tue, Apr 25, 2017 at 2:25 PM Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
> Ron,
> We apologize about the delay. I haven't seen such an error before. Can
> you provide the exact modules you are using for this configuration ?
> Looks like libtool is screwing up. Can you copy /usr/bin/libtool to
> your build folder and re-try configuration ?
> Meanwhile, we will try to replicate the issue and find a fix.
> Vijay
> On Mon, Apr 24, 2017 at 11:46 AM, Ron Rahaman <rahaman at mcs.anl.gov> wrote:
>> Hi all,
>> I'm building MOAB 4.9.0 Cetus at ANL and I'm getting these errors at link
>> time (see below).  I've also attached my config.log.  Thanks in advance
>> for
>> your help.
>> Best,
>> Ron Rahaman
>> libtool: link: ar -X 32_64 cru .libs/libMOABpar.a  ParallelComm.o
>> ProcConfig.o ParallelData.o ParallelMergeMesh.o ReadParallel.o
>> SharedSetData.o gs.o WriteHDF5Parallel.o
>> ar: illegal option -- X
>> Usage: ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV] [member-name]
>> [count] archive-file file...
>>        ar -M [<mri-script]
>>  commands:
>>   d            - delete file(s) from the archive
>>   m[ab]        - move file(s) in the archive
>>   p            - print file(s) found in the archive
>>   q[f]         - quick append file(s) to the archive
>>   r[ab][f][u]  - replace existing or insert new file(s) into the archive
>>   t            - display contents of archive
>>   x[o]         - extract file(s) from the archive
>>  command specific modifiers:
>>   [a]          - put file(s) after [member-name]
>>   [b]          - put file(s) before [member-name] (same as [i])
>>   [D]          - use zero for timestamps and uids/gids
>>   [N]          - use instance [count] of name
>>   [f]          - truncate inserted file names
>>   [P]          - use full path names when matching
>>   [o]          - preserve original dates
>>   [u]          - only replace files that are newer than current archive
>> contents
>>  generic modifiers:
>>   [c]          - do not warn if the library had to be created
>>   [s]          - create an archive index (cf. ranlib)
>>   [S]          - do not build a symbol table
>>   [T]          - make a thin archive
>>   [v]          - be verbose
>>   [V]          - display the version number
>>   @<file>      - read options from <file>
>>  emulation options:
>>   No emulation specific options
>> ar: supported targets: elf64-powerpc elf64-powerpcle elf32-powerpc
>> elf32-powerpcle aixcoff-rs6000 aixcoff64-rs6000 elf64-little elf64-big
>> elf32-little elf32-big elf32-spu srec symbolsrec verilog tekhex binary
>> ihex
>> make[3]: *** [libMOABpar.la] Error 1
