[MOAB-dev] Configuring cgm with cmake without CUBIT?
JR Cary
cary at txcorp.com
Wed Jan 18 14:34:07 CST 2017
Is this possible? And use OpenCascade?
(When last I checked, it was not.)
I am getting link errors:
[100%] Linking CXX shared library ../lib/libiGeom.dylib
cd /Users/cary/projects/composerall-test/builds/cgm/ser/itaps &&
/opt/test/contrib-clangcxx11/cmake-3.7.1-ser/bin/cmake -E
cmake_link_script CMakeFiles/iGeom.dir/link.txt --verbose=1
/usr/bin/clang++ -std=c++11 -stdlib=libc++ -fPIC -pipe
-stdlib=libstdc++ -O3 -DNDEBUG -dynamiclib
-Wl,-headerpad_max_install_names -o ../lib/libiGeom.dylib -install_name
@rpath/libiGeom.dylib CMakeFiles/iGeom.dir/CATag.cpp.o
CMakeFiles/iGeom.dir/iGeomError.cc.o
CMakeFiles/iGeom.dir/iGeom_CGMA.cc.o
-Wl,-rpath,/Users/cary/projects/composerall-test/builds/cgm/ser/lib
../lib/libcgm_init.dylib ../lib/libcgm_geom.dylib ../lib/libcgm_util.dylib
clang: warning: libstdc++ is deprecated; move to libc++
Undefined symbols for architecture x86_64:
"CubitCompat_export_solid_model(DLIList<RefEntity*>&, char const*,
char const*, int&, CubitString const&, char const*)", referenced from:
_iGeom_save in iGeom_CGMA.cc.o
"CubitCompat_import_solid_model(char const*, char const*, char const*,
bool, bool, bool, bool, bool, bool, DLIList<RefEntity*>*)", referenced from:
_iGeom_load in iGeom_CGMA.cc.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
Thx....John
