[MOAB-dev] Digging into ray_intersect_* in the OBBTreeTool - proposing an interface change
Paul Wilson
paul.wilson at wisc.edu
Fri Dec 9 16:44:28 CST 2016
Hello all,
I have been spending a lot of quality time with the ray_intersect_*
methods of the OrientedBoxTreeTool over the last few weeks. I think I
have (re)learned all the subtleties of the additional code that exists
in RayIntersectSets::leaf() (invoked with API function ray_intersect_sets).
In general, these are all additional tests that make sense only in the
context of a call from DagMC:
* is this facet in a list of previous facets intersected by this ray
prior to this call
* is this facet in a list of previous facets (or their neighborhood)
encountered during this call
* is this intersection a piercing or glancing intersection as defined
by notions of surface sense known to DagMC
There is then a complex logic related to how many intersections to keep
based on three quantities: two are a "window" in which the distance to
distance to intersection must fall and the third is a count of how many
intersections to keep.
The logic for ray_intersect_triangles() includes none of this. I was
contemplating an interface change to ray_intersect_triangles() that
would add enough information to include the same tests, and modularizing
those tests to reuse code in both places. However, (a) the interface
for that would be awkward and (b) it would be imposing DagMC conventions
on even more code.
Instead I propose the reduce the interface of all ray_intersect_*
methods to include only the following:
* const EntityHandle root_set: points to the root of the OBB Tree
* const double tolerance: for use in searching for intersections
(largely unused at the moment, I think)
* const double ray_point[3]: starting point of ray
* const double unit_vector[3]: direction of ray
* std::pair<double*, double*> window: window to narrow search for
interesting intersections
* std::pair<double*, double*> register_intersection(...): call back
function to perform application specific filtering/disambiguation of
possible intersection, returning an updated window
These methods would no longer return lists of intersections, but would
return them one at a time for consideration by the calling application.
Since this is such a major interface change, I thought I'd solicit
feedback before embarking upon it. It won't necessarily bee that much
code change, but who knows how it impacts other possible users of this
code???
Paul
Paul P.H. Wilson
Grainger Professor of Nuclear Engineering
608-263-0807
419 Engineering Research Bldg
1500 Engineering Dr, Madison, WI 53706
calendar: http://go.wisc.edu/pphw-cal
Computational Nuclear Engineering Research Group
cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Initiative
aci.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20161209/793c6ede/attachment.html>
