[MOAB-dev] VTK structured mesh outpu
    Paul Wilson
    paul.wilson at wisc.edu
    Wed Sep 21 06:14:06 CDT 2016
Hello Iulian,
On 09/20/2016 11:12 AM, Grindeanu, Iulian R. wrote:
> Hello Paul,
> I am not sure I understand what dagmc needs
> (I should probably read the code in moab :)
This is not for DAGMC, but related to other ways that we use MOAB to
assist with visualization & analysis of mesh data.
> Moab SCD interface is aligned with VTK structured grid  (legacy format, we do not do anything with XML)
> ( DATASET STRUCTURED_GRID)
> in that, all points' coordinates are explicit, and in a specific order ( I think c style, need to check; need to check if it is the same convention in vtk)
> all cells are "implicit", their connectivity is never stored, it is just derived from the dimensions (2d or 3d)
> Moab's SCD interface allows all kinds of access. You can request neighbors, etc, and it works in parallel too, in the sense that each task has a very specific partition , it knows about neighbors, can do ghosting, etc. Pretty cool stuff, but rather verbose. Not sure if you need anything for parallel
> An SCDBox from moab will correspond to a DATASET STRUCTURED_GRID from vtk
> vtk has other "structured" meshes dataset types, that are simpler: STRUCTURED_POINTS and RECTILINEAR_GRID
> Which one of those 3 does dagmc need?
We are looking at the "DATASET RECTILINEAR_GRID" option, in which the
points are NOT explicitly stored.  Instead, the set of x, y, and z
locations are stored in separate lists and the connectivity is never
stored.  This change allows some of our larger files to go from 6GB to
<900MB!!
We're looking into the steps it will take to accomplish this, hopefully
as an addition to MOAB.
Paul
> Iulian
> http://www.vtk.org/Wiki/VTK/Writing_VTK_files_using_python
> http://www.vtk.org/wp-content/uploads/2015/04/file-formats.pdf
> From: Paul Wilson [paul.wilson at wisc.edu]
> Sent: Monday, September 19, 2016 4:13 PM
> To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] VTK structured mesh outpu
> Hi Iulian,
> We are much more interested in the writer, but might be convinced to
> support a reader as well :)
> We would want to explore the SCD interface to see how it could best
> support this.
> Our use case begins with MCNP mesh tally output files that are always
> structured mesh.  There is a native reader in MOAB for these files, but
> not as rich/robust as we'd like, and it does NOT use the scd interface,
> instead making an unstructured representation.  There is also a reader
> in the PyNE toolkit that does ultimately use the scd interface, but then
> also relies on MOAB's vtk writer which stores an unstructured
> representation.
> The key to a structured (Cartesian) mesh VTK writer is having access to
> the x,y,z bounds without having to infer them from the set of vertices.
> The rest is probably straightforward.
> Paul
> On 09/19/2016 03:22 PM, Grindeanu, Iulian R. wrote:
>> MOAB does not have a structured writer. Not even for h5m format
>> (it has the ability to create structured meshes)
>> even in that case, the mesh is written explicit (unstructured)
>> structured vtk format is relatively simpler, but do you plan to add reader and writer or just writer?
>> How do you create structured mesh, with scd interface?
>> thanks,
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Paul Wilson [paul.wilson at wisc.edu]
>> Sent: Monday, September 19, 2016 3:12 PM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] VTK structured mesh outpu
>> Hi all,
>> Does the MOAB VTK writer have a way to write structured mesh data using
>> VTK's structured mesh format?  For data that conforms to that, it saves
>> a substantial amount of disk space and also speeds up
>> processing/visualization times.
>> If not, we may be interested in helping add this...
>> Paul
>> Paul P.H. Wilson
>> Grainger Professor of Nuclear Engineering
>> 608-263-0807
>> 419 Engineering Research Bldg
>> 1500 Engineering Dr, Madison, WI 53706
>> calendar: http://go.wisc.edu/pphw-cal
>> Computational Nuclear Engineering Research Group
>> cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Initiative
>> aci.wisc.edu
> Paul P.H. Wilson
> 608-263-0807
> cnerg.engr.wisc.edu
> aci.wisc.edu
Paul P.H. Wilson
608-263-0807
cnerg.engr.wisc.edu
aci.wisc.edu
