[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri May 13 13:53:30 CDT 2016
Jie,
We are looking into the failing tests and will update in case there is
a bug in the code. Our nightly tests are running cleanly and so I'm
curious to see if other tests are failing. Can you go to test/parallel
and run "make check" there to verify if the parallel job launch is
working correctly ? Also, can you verify if you can run MPI programs
with mpiexec ?
Vijay
Vijay
On Fri, May 13, 2016 at 1:31 PM, Jie Wu <jie.voo at gmail.com> wrote:
> Hi Vijay,
> Deleting the auto-installed packages under sandbox before issue new
> configurations works good! No error message emerged until I input the
> command make check, which is as following.
> Do you have any idea for this problem?
> Best,
> Jie
> PASS: reorder_test
> FAIL: test_prog_opt
> PASS: coords_connect_iterate
> PASS: elem_eval_test
> PASS: spatial_locator_test
> PASS: test_boundbox
> PASS: adj_moab_test
> PASS: uref_mesh_test
> PASS: verdict_test
> PASS: test_Matrix3
> PASS: mbfacet_test
> PASS: gttool_test
> PASS: cropvol_test
> FAIL: mergemesh_test
> PASS: mbground_test
> PASS: lloyd_smoother_test
> Testsuite summary for MOAB 4.9.2pre
> # TOTAL: 36
> # PASS:  34
> # SKIP:  0
> # XFAIL: 0
> # FAIL:  2
> # XPASS: 0
> # ERROR: 0
> See test/test-suite.log
> Please report to moab-dev at mcs.anl.gov
> make[4]: *** [test-suite.log] Error 1
> make[3]: *** [check-TESTS] Error 2
> make[2]: *** [check-am] Error 2
> make[1]: *** [check-recursive] Error 1
> make: *** [check-recursive] Error 1
> On May 13, 2016, at 1:08 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Jie, since you now changed the compilers used to configure the stack,
> I would advise deleting the auto-installed packages under sandbox
> directory and then re-configuring. This will force the rebuild of
> HDF5/NetCDF packages with the parallel MPI compilers and you should
> get the HDF5-parallel support enabled after that. Makes sense ?
> Vijay
> On Fri, May 13, 2016 at 11:27 AM, Jie Wu <jie.voo at gmail.com> wrote:
> Hi Vijay,
> Thank you for your reply. The new configuration do works. Here shows the
> command I inputed and the message while I input: make check.
> dyn-160-39-10-173:moab jiewu$ ./configure --with-mpi=/usr/local
> CC=/usr/local/bin/mpicc CXX=/usr/local/bin/mpic++ FC=/usr/local/bin/mpif90
> F77=/usr/local/bin/mpif77 --download-metis --download-hdf5 --download-netcdf
> --enable-docs --with-doxygen=/Applications/Doxygen.app/Contents/Resources/
> The results are
> configure: WARNING:
> *        MOAB has been configured with parallel and HDF5 support
> *     but the configured HDF5 library does not support parallel IO.
> *            Some parallel IO capabilities will be disabled.
> After that, I inputted the command, make -j4, and then command make check.
> Here are the results it shows
> /Applications/Xcode.app/Contents/Developer/usr/bin/make  check-TESTS
> PASS: elem_util_test
> PASS: element_test
> FAIL: datacoupler_test
> FAIL: mbcoupler_test
> FAIL: parcoupler_test
> # TOTAL: 5
> # PASS:  2
> # SKIP:  0
> # XFAIL: 0
> # FAIL:  3
> # XPASS: 0
> # ERROR: 0
> See tools/mbcoupler/test-suite.log
> Then I was trying to run the mbcouple_test with command
> dyn-160-39-10-173:mbcoupler jiewu$    mpiexec -np 2  mbcoupler_test -meshes
> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_1khex.h5m
> /Users/wujie/SourceCode/moab/MeshFiles/unittest/64bricks_12ktet.h5m -itag
> vertex_field -outfile dum.h5m
> Now the results look like,
> [0]MOAB ERROR: --------------------- Error Message
> [0]MOAB ERROR: MOAB not configured with parallel HDF5 support!
> [0]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
> [0]MOAB ERROR: NULL file handle.!
> [0]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
> [1]MOAB ERROR: --------------------- Error Message
> [1]MOAB ERROR: MOAB not configured with parallel HDF5 support!
> [1]MOAB ERROR: set_up_read() line 355 in src/io/ReadHDF5.cpp
> [1]MOAB ERROR: NULL file handle.!
> [1]MOAB ERROR: is_error() line 133 in src/io/ReadHDF5.hpp
> [0]MOAB ERROR: Failed to load file after trying all possible readers!
> [0]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
> [0]MOAB ERROR: Failed in step PARALLEL READ PART!
> [0]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
> [0]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
> [0]MOAB ERROR: load_file() line 515 in src/Core.cpp
> [1]MOAB ERROR: Failed to load file after trying all possible readers!
> [1]MOAB ERROR: serial_load_file() line 635 in src/Core.cpp
> [1]MOAB ERROR: Failed in step PARALLEL READ PART!
> [1]MOAB ERROR: load_file() line 553 in src/parallel/ReadParallel.cpp
> [0]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
> [1]MOAB ERROR: load_file() line 252 in src/parallel/ReadParallel.cpp
> [1]MOAB ERROR: load_file() line 515 in src/Core.cpp
> [1]MOAB ERROR: main() line 172 in mbcoupler_test.cpp
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 16.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> [dyn-160-39-11-172.dyn.columbia.edu:26361] 1 more process has sent help
> message help-mpi-api.txt / mpi-abort
> [dyn-160-39-11-172.dyn.columbia.edu:26361] Set MCA parameter
> "orte_base_help_aggregate" to 0 to see all help / error messages
> The other excitable file in mbcoupler folder, like ./element_test now can
> run successfully.
> Any direction for this was deeply appreciated!
> Best,
> Jie
> On May 13, 2016, at 11:54 AM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> I also forgot to mention that you can be more explicit in the
> specification of compilers during configuration, if you really want.
> This would avoid headaches since the user specified wrappers will
> directly be used. For example:
> ./configure --with-mpi=/usr/local CC=/usr/local/bin/mpicc
> F77=/usr/local/bin/mpif77 <OTHER_CONFIGURE_OPTIONS>
> Vijay
> On Fri, May 13, 2016 at 10:52 AM, Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
> Please use --with-mpi=/usr/local as the configure option. If you have
> MPI pre-installed, either through PETSc or natively in your system,
> always try to re-use that to maintain consistency. This will help
> avoid mix-up of MPI implementations when you try to launch a parallel
> job later.
> Let us know if the new configuration works.
> Vijay
> On Thu, May 12, 2016 at 6:32 PM, Jie Wu <jie.voo at gmail.com> wrote:
> Thank you very much for your reply. I search in my src/moab/MOABConfig.h
> file, and I did not find the MOAB_HAVE_MPI. So I think the MOAB on my laptop
> cannot run in parallel yet.
> I have this from my terminal.
> dyn-160-39-10-173:moab jiewu$ which mpic++
> But I cannot get anything by inputing which mpi. So I don’t know where the
> mpi is in my laptop.
> I have petsc installed which has mpich, and linking that directory to the
> MOAB configure option also did not work.
> Should I install mpi solely? I am afraid it might conflict with the one
> installed in petsc.
> Is there any method that the mpi could be installed with MOAB automatically,
> or maybe other proper manner? Thanks a lot!
> Best,
> Jie
> On May 12, 2016, at 6:11 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Can you send the config.log. Looks like MPI is not getting enabled
> (possibly), even with --dowload-mpich. Or you can check
> src/moab/MOABConfig.h in your build directory and grep for
> MOAB_HAVE_MPI.
> Vijay
> On Thu, May 12, 2016 at 4:46 PM, Jie Wu <jie.voo at gmail.com> wrote:
> Hi Iulian,
> Thanks for your reply. I think my configure is with mpi. Here is my
> configure command
> dyn-160-39-10-173:moab jiewu$    ./configure --download-metis
> --download-hdf5 --download-netcdf --download-mpich --enable-docs
> Best,
> Jie
> On May 12, 2016, at 5:43 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
> wrote:
> Hi Jie,
> Did you configure with mpi? What is your configure command?
> Iulian
> ________________________________
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
> of Jie Wu [jie.voo at gmail.com]
> Sent: Thursday, May 12, 2016 4:23 PM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
> Hi all,
> My name is Jie and I am part of computational mechanics group at civil
> engineering dept. of Columbia university.
> I am working on large deformation problems which may lead mesh distortions
> and a re-meshing become necessary.
> I would like to compile mbcoupler_test.cpp to learn how it transfer the
> variables from old to the new mesh.
> Now I can successfully compile the codes in build/examples and they works
> good! But I cannot compile the codes in folder build/tools/mbcoupler by
> following the instructions in build/tools/readme.tools, which shows error
> message like following.
> Do you have any idea for this problem? Thanks a lot!
> Best,
> Jie
> DataCoupler.cpp:136:25: error: member access into incomplete
>    type 'moab::ParallelComm'
> if (myPcomm && myPcomm->size() > 1) {
> ./DataCoupler.hpp:34:7: note: forward declaration of
> class ParallelComm;
> DataCoupler.cpp:161:12: error: member access into incomplete
>  myPcomm->proc_config().crystal_router()->gs_tran...
> class ParallelComm;
> DataCoupler.cpp:187:12: error: member access into incomplete
> class ParallelComm;
> 3 errors generated.
> make[2]: *** [DataCoupler.lo] Error 1
> make[2]: *** Waiting for unfinished jobs....
> Coupler.cpp:344:45: error: no member named 'gs_transfer' in
>    'moab::gs_data::crystal_data'
>  (myPc->proc_config().crystal_router())->gs_trans...
> Coupler.cpp:388:45: error: no member named 'gs_transfer' in
> Coupler.cpp:611:45: error: no member named 'gs_transfer' in
> Coupler.cpp:638:43: error: no member named 'gs_transfer' in
>  myPc->proc_config().crystal_router()->gs_transfe...
> 4 errors generated.
> make[2]: *** [Coupler.lo] Error 1
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
