[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri May 13 10:52:41 CDT 2016
Please use --with-mpi=/usr/local as the configure option. If you have
MPI pre-installed, either through PETSc or natively in your system,
always try to re-use that to maintain consistency. This will help
avoid mix-up of MPI implementations when you try to launch a parallel
job later.
Let us know if the new configuration works.
Vijay
On Thu, May 12, 2016 at 6:32 PM, Jie Wu <jie.voo at gmail.com> wrote:
> Thank you very much for your reply. I search in my src/moab/MOABConfig.h
> file, and I did not find the MOAB_HAVE_MPI. So I think the MOAB on my laptop
> cannot run in parallel yet.
> I have this from my terminal.
> dyn-160-39-10-173:moab jiewu$ which mpic++
> /usr/local/bin/mpic++
> But I cannot get anything by inputing which mpi. So I don’t know where the
> mpi is in my laptop.
> I have petsc installed which has mpich, and linking that directory to the
> MOAB configure option also did not work.
> Should I install mpi solely? I am afraid it might conflict with the one
> installed in petsc.
> Is there any method that the mpi could be installed with MOAB automatically,
> or maybe other proper manner? Thanks a lot!
> Best,
> Jie
> On May 12, 2016, at 6:11 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Can you send the config.log. Looks like MPI is not getting enabled
> (possibly), even with --dowload-mpich. Or you can check
> src/moab/MOABConfig.h in your build directory and grep for
> MOAB_HAVE_MPI.
> Vijay
> On Thu, May 12, 2016 at 4:46 PM, Jie Wu <jie.voo at gmail.com> wrote:
> Hi Iulian,
> Thanks for your reply. I think my configure is with mpi. Here is my
> configure command
> dyn-160-39-10-173:moab jiewu$    ./configure --download-metis
> --download-hdf5 --download-netcdf --download-mpich --enable-docs
> --with-doxygen=/Applications/Doxygen.app/Contents/Resources/
> Best,
> Jie
> On May 12, 2016, at 5:43 PM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
> wrote:
> Hi Jie,
> Did you configure with mpi? What is your configure command?
> Iulian
> ________________________________
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
> of Jie Wu [jie.voo at gmail.com]
> Sent: Thursday, May 12, 2016 4:23 PM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] Error message when compiling the mbcoupler_test.cpp
> Hi all,
> My name is Jie and I am part of computational mechanics group at civil
> engineering dept. of Columbia university.
> I am working on large deformation problems which may lead mesh distortions
> and a re-meshing become necessary.
> I would like to compile mbcoupler_test.cpp to learn how it transfer the
> variables from old to the new mesh.
> Now I can successfully compile the codes in build/examples and they works
> good! But I cannot compile the codes in folder build/tools/mbcoupler by
> following the instructions in build/tools/readme.tools, which shows error
> message like following.
> Do you have any idea for this problem? Thanks a lot!
> Best,
> Jie
> DataCoupler.cpp:136:25: error: member access into incomplete
>      type 'moab::ParallelComm'
>  if (myPcomm && myPcomm->size() > 1) {
> ./DataCoupler.hpp:34:7: note: forward declaration of
> class ParallelComm;
> DataCoupler.cpp:161:12: error: member access into incomplete
>    myPcomm->proc_config().crystal_router()->gs_tran...
> class ParallelComm;
> DataCoupler.cpp:187:12: error: member access into incomplete
> class ParallelComm;
> 3 errors generated.
> make[2]: *** [DataCoupler.lo] Error 1
> make[2]: *** Waiting for unfinished jobs....
> Coupler.cpp:344:45: error: no member named 'gs_transfer' in
>      'moab::gs_data::crystal_data'
>    (myPc->proc_config().crystal_router())->gs_trans...
> Coupler.cpp:388:45: error: no member named 'gs_transfer' in
> Coupler.cpp:611:45: error: no member named 'gs_transfer' in
> Coupler.cpp:638:43: error: no member named 'gs_transfer' in
>    myPc->proc_config().crystal_router()->gs_transfe...
> 4 errors generated.
> make[2]: *** [Coupler.lo] Error 1
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
