[MOAB-dev] Error message when compiling the mbcoupler_test.cpp
    Jie Wu
    jie.voo at gmail.com
    Thu May 12 16:23:46 CDT 2016
Hi all,
My name is Jie and I am part of computational mechanics group at civil engineering dept. of Columbia university.
I am working on large deformation problems which may lead mesh distortions and a re-meshing become necessary.
I would like to compile mbcoupler_test.cpp to learn how it transfer the variables from old to the new mesh.
Now I can successfully compile the codes in build/examples and they works good! But I cannot compile the codes in folder build/tools/mbcoupler by following the instructions in build/tools/readme.tools, which shows error message like following.
Do you have any idea for this problem? Thanks a lot!
Best,
Jie
DataCoupler.cpp:136:25: error: member access into incomplete
      type 'moab::ParallelComm'
  if (myPcomm && myPcomm->size() > 1) {
./DataCoupler.hpp:34:7: note: forward declaration of
class ParallelComm;
DataCoupler.cpp:161:12: error: member access into incomplete
    myPcomm->proc_config().crystal_router()->gs_tran...
class ParallelComm;
DataCoupler.cpp:187:12: error: member access into incomplete
class ParallelComm;
3 errors generated.
make[2]: *** [DataCoupler.lo] Error 1
make[2]: *** Waiting for unfinished jobs....
Coupler.cpp:344:45: error: no member named 'gs_transfer' in
      'moab::gs_data::crystal_data'
    (myPc->proc_config().crystal_router())->gs_trans...
Coupler.cpp:388:45: error: no member named 'gs_transfer' in
Coupler.cpp:611:45: error: no member named 'gs_transfer' in
Coupler.cpp:638:43: error: no member named 'gs_transfer' in
    myPc->proc_config().crystal_router()->gs_transfe...
4 errors generated.
make[2]: *** [Coupler.lo] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160512/e28f6cc5/attachment.html>
