[MOAB-dev] file formats
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri Apr  8 08:13:35 CDT 2016
Yes this is an interesting extension and we can certainly add something
natively in MOAB.
Jacob, if you can point us to your code and/or want to submit a PR for new
reader/writer, we would happy to add the capability for xdmf.
Vijay
On Apr 8, 2016 7:49 AM, "Nico Schlömer" <nico.schloemer at gmail.com> wrote:
> > The xml file very generation is very quick with a simple python script
> > (we have written to general python classes for this, if you're
> interested).
> Very much so; where do I find the code? Perhaps this could even be
> included in MOAB itself.
> Cheers,
> Nico
> On Fri, Apr 8, 2016 at 2:43 PM Jacob Hochhalter <
> Jacob.D.Hochhalter at nasa.gov> wrote:
>> All,
>> We have had this issue come up too.  Our solution, which we have been
>> very happy with so far, is to use the .h5m file as part of the XDMF
>> concept (see http://www.xdmf.org/index.php/Main_Page).  With that
>> approach, we simply 'wrap' the .h5m file with a xml file, which
>> describes which data we want to visualize (and how).  There is no
>> duplication of the mesh or results data, since the xml file simply
>> 'points' to datasets in the h5m file.  The xml file very generation is
>> very quick with a simple python script (we have written to general
>> python classes for this, if you're interested).  An added bonus is that
>> both VisIt and Paraview support XDMF inherently.
>> - Jake
>> On 04/08/2016 03:31 AM, Nico Schlömer wrote:
>> > Thanks for the comment!
>> > To be able to do I/O from a visualizable format directly (without
>> > mbconvert or any other tool) is in fact more important to me than not
>> > wasting space on storing a mesh more than once (although also
>> > interesting). Perhaps these two things can be aligned.
>> > Cheers,
>> > Nico
>> > On Thu, Apr 7, 2016 at 11:06 PM Vijay S. Mahadevan <vijay.m at gmail.com
>> > <mailto:vijay.m at gmail.com>> wrote:
>> >     Nico, if the time series data are stored as separate tags, like
>> >     [SOLUTION_STEP0, SOLUTION_STEP1, .., SOLUTION_STEPN], any of the
>> >     conversion tools should provide the right data output that can be
>> >     visualized easily.
>> >     You should be able to use mbconvert that gets installed with MOAB
>> for
>> >     the conversion. Of course, if you want exodus output, you will need
>> >     the NetCDF dependency enabled. VTK is available out of the box
>> though.
>> >     We can also discuss more about the time series data and not writing
>> >     the mesh more than once, especially for static non-AMR simulations.
>> We
>> >     should be able to find some time in the summer or a little later to
>> >     implement this functionality within MOAB.
>> >     Vijay
>> >     On Wed, Apr 6, 2016 at 2:46 PM, Nico Schlömer
>> >     <nico.schloemer at gmail.com <mailto:nico.schloemer at gmail.com>> wrote:
>> >     > Thanks for the comments!
>> >     >> the visualization is the tricky bit tere since none of the main
>> >     tools
>> >     >> (VisIt, Paraview) understand the
>> >     >> details of the layout explicitly
>> >     >>  if we understand your needs better.
>> >     > The question I have to answer the most is how to visualize H5M
>> >     files. I
>> >     > usually tell people to grab meshio [1] and convert to a format
>> >     they use. I
>> >     > guess I could extend meshio such that it can translate h5m's tag
>> >     time series
>> >     > data into another format with native series. Anyhow, more work
>> >     for me and
>> >     > for the users (to convert), so I'm not so happy with that yet.
>> >     > Cheers,
>> >     > Nico
>> >     > [1] https://pypi.python.org/pypi/meshio
>> >     > On Wed, Apr 6, 2016 at 4:49 PM Vijay S. Mahadevan
>> >     <vijay.m at gmail.com <mailto:vijay.m at gmail.com>> wrote:
>> >     >> Hi NIco,
>> >     >> Our current HDF5-based I/O workflow supports adding arbitrary
>> >     tags if
>> >     >> you want to store time-stepping data. This is what Lukasz is
>> >     doing for
>> >     >> his needs and should extend arbitrarily to other applications
>> using
>> >     >> MOAB. As Lukasz also mentioned, the visualization is the tricky
>> bit
>> >     >> here since none of the main tools (VisIt, Paraview) understand
>> the
>> >     >> details of the layout explicitly and so only expose part of the
>> >     data
>> >     >> available in h5m files. I've also been think about enhancements
>> to
>> >     >> support multiple HDF5 files, where the mesh is written out only
>> >     >> initially and when it changes. But this is a little more
>> >     involved for
>> >     >> the book-keeping to remain general.
>> >     >> On a related note, we are working with LLNL to add a native MOAB
>> >     >> plugin to VisIt, that directly uses MOAB underneath, in
>> >     parallel, to
>> >     >> query and visualize solution. Once that is in place, adding
>> >     capability
>> >     >> to show time-series data can be added out of the box. Note that
>> >     MOAB
>> >     >> already supports only loading partial sets and tags, if you are
>> >     >> concerned about the data movement with I/O for large simulation
>> >     runs.
>> >     >> However, we have also been considering alternatives that support
>> >     >> parallel I/O. Yes, from our discussions, I believe we converged
>> on
>> >     >> XDMF and Exodus/Nemesis. Currently, this is a bottleneck on the
>> >     >> resources available to us and so has been in the back burner.
>> >     There is
>> >     >> native support for time-series data with the pure NetCDF route
>> >     >> already, written more focused on climate applications [1, 2].
>> >     We can
>> >     >> also talk about extending this to more general use cases, if we
>> >     >> Thoughts ?
>> >     >> Vijay
>> >     >> [1] https://www.ncl.ucar.edu/ParVis.shtml
>> >     >> [2]
>> >     https://cfwebprod.sandia.gov/cfdocs/CompResearch/docs/template.pdf
>> >     >> On Wed, Apr 6, 2016 at 6:34 AM, Lukasz Kaczmarczyk
>> >     >> <Lukasz.Kaczmarczyk at glasgow.ac.uk
>> >     <mailto:Lukasz.Kaczmarczyk at glasgow.ac.uk>> wrote:
>> >     >> > Hello,
>> >     >> > I am not convinced that this is the best approach, however I
>> >     can tell
>> >     >> > how I
>> >     >> > do it.
>> >     >> > I create meshset with number of contained meshsets equal to
>> >     number of
>> >     >> > time
>> >     >> > steps. Each of contained meshsets has tag, which data on all
>> >     entities on
>> >     >> > meshset which I store for time step. That can be saved in
>> >     native HD5
>> >     >> > file
>> >     >> > and read  back if needed without data redundancies and allow
>> >     to add time
>> >     >> > steps. However is a issue of post-processing, that will need
>> >     some proper
>> >     >> > reader for post-procssor which I not currently have.
>> >     >> > There are additional complexities, when you store multiple
>> >     fields and
>> >     >> > you
>> >     >> > store data for variable number of entities for each step. In
>> >     may case I
>> >     >> > implemented it like tape recorder, that I have different
>> >     tapes for which
>> >     >> > I
>> >     >> > record and play tapes depending on need. If this will be any
>> >     use for you
>> >     >> > pleas look at example,
>> http://mofem.eng.gla.ac.uk/mofem/html/record__series__atom_8cpp_source.html
>> >     >> > In example I have two tapes there and two moab instances, one
>> >     use for
>> >     >> > recording another for reading for testing proposes. This
>> >     works ok, but
>> >     >> > is
>> >     >> > missing proper reader for paraview and at the end I produce
>> >     series of
>> >     >> > VTKs
>> >     >> > for paraview. This is very specific to my development by you
>> >     can use it
>> >     >> > as
>> >     >> > idea if you like it.
>> >     >> > I would be great to have some common interface to record and
>> >     read time
>> >     >> > series of tags for moab. That if one will write reader for
>> >     paraview it
>> >     >> > could
>> >     >> > be used by several developers woking on different codes.
>> >     >> > Regards,
>> >     >> > Lukasz
>> >     >> > On 6 Apr 2016, at 10:02, Nico Schlömer
>> >     >> > Hi everyone,
>> >     >> > I'll start tackling a time-series problem rather soon and I'm
>> >     wondering
>> >     >> > about file formats here. Ideally, I'd have one time series
>> >     per file
>> >     >> > (particularly since the mesh isn't changing over time,
>> >     perhaps that
>> >     >> > could be
>> >     >> > made use of), but I'm not sure if MOAB's custom HDF5 supports
>> >     that yet.
>> >     >> > Thinking of which, I faintly remember there had been talk about
>> >     >> > switching to
>> >     >> > a better-supported format in the future (xdmf and exodus came
>> >     to mind).
>> >     >> > Is
>> >     >> > this still a thing?
>> >     >> > Cheers,
>> >     >> > Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160408/f14fa632/attachment.html>
