[MOAB-dev] Resolving shared entities on prisms
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Tue Apr 5 12:11:42 CDT 2016
Hello,
Yes, that is right quads are linear, and triangles are 6-nodes. That apply for first file. Second file has linear triangles and quads, I do it in such way, since I make prisms by extruding them from triangles. I forget about that initially, sorry for not writing about that in the first email.
For second file, with geometry is linear, I have still problem with BCAST_DELETE. You can use that file for initial testing.
Thank you anyway for looking at this so quickly.
Lukasz
> On 5 Apr 2016, at 17:52, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
> hmmm,
> I didn't realize you have higher order nodes for triangles and some edges
> Are all quads linear?
> Yes, I see multiple problems, and they are related to higher order nodes.
> the prisms are all linear, and in read_part, they are the primary entities, so the higher order nodes are ignored.
> (they are not part of the partition).
> So then the triangles are not read into the part, because they have nodes that are not in the local partition. (in read_part method)
> bcast_delete is reading all mesh from file, and then deleting the "non local" elements;
> Still need to understand what is going on
> Iulian
> From: Lukasz Kaczmarczyk [Lukasz.Kaczmarczyk at glasgow.ac.uk]
> Sent: Tuesday, April 05, 2016 11:13 AM
> To: Grindeanu, Iulian R.
> Subject: Re: Resolving shared entities on prisms
> Hello,
> File which I send you before is with mid-nodes on triangles. This is not working with PARALLEL=READ_PART.
> I created another file, with nodes only on corers. See attached file and this works with PARALLEL=READ_PART, however it is not working with BCAST_DELETE.
> It could be not one, but two separate problems. One with resolving ents when  BCAST_DELETE or READ_DELETE is used, another with mid-modes.
> Kind regards,
> Lukasz
>> On 5 Apr 2016, at 15:44, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
>> Hi Lukasz
>> If you load using PARALLEL=READ_PART, instead of BCAST_DELETE, it is fine
>> It is a bug somewhere, I am a little puzzled why it would show up only for BCAST_DELETE
>> Still looking ...
>> Thanks,
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>> Sent: Tuesday, April 05, 2016 9:20 AM
>> To: Lukasz Kaczmarczyk; moab-dev at mcs.anl.gov
>> Subject: Re: [MOAB-dev] Resolving shared entities on prisms
>> take that back; it is OK for hexas; so it may be related to prisms only
>> Sent: Tuesday, April 05, 2016 9:13 AM
>> Hi Lukasz,
>> Thank you for your example;
>> I think it is related to the way we look at the skin.
>> It would show the same problem for other elements (hexas, with more than one layer)
>> So, when we collect potential shared entities at the interface, for edges we should just collect by adjacencies, from the skin formed by 2d elements; we look at the 1d skin, which I think is wrong
>> I will try to fix it soon
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Lukasz Kaczmarczyk [Lukasz.Kaczmarczyk at glasgow.ac.uk]
>> Sent: Tuesday, April 05, 2016 6:51 AM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] Resolving shared entities on prisms
>> Hello,
>> I have created muli-layered shell from prisms elements. For attached partitioned mesh (3 partitions) for I check output for shared own entities, however internal edges, on shared quads, between layers (internal edges) are not resolved as a shared. Everything else is ok.
>> This is what I don’t understand, it could be error on my side, however I don;t see where. Could you pleas look at this and point me to potential error. It could be related to prisms? It works perfectly for single layer of prisms elements.
>> PS.
>> This is part of work on solid shell elements, for interested, pleas look here,
>> https://www.dropbox.com/s/zml82aj027hfsbb/solid_shell.pptx?dl=0
>> Kind regards,
>> Lukasz
>> const char *option;
>> option = “PARALLEL=BCAST_DELETE;"
>>       "PARALLEL_RESOLVE_SHARED_ENTS;"
>>       "PARTITION=PARALLEL_PARTITION;";
>> rval = moab.load_file(“tmp.h5m", 0, option); CHKERRQ_MOAB(rval);
>>       Range shared_ents;
>>       // Get entities shared with all other processors
>>       rval = pcomm->get_shared_entities(-1, shared_ents);
>>       Range owned_entities;
>>       rval = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_entities);
>>       EntityHandle meshset;
>>       rval = moab.create_meshset(MESHSET_SET,meshset); CHKERRQ_MOAB(rval);
>>       rval = moab.add_entities(meshset,owned_entities); CHKERRQ_MOAB(rval);
>>       ostringstream o1;
>>       o1 << "owned_" << pcomm->rank() << ".vtk";
>>       moab.write_file(o1.str().c_str(),"VTK","",&meshset,1);
>>       rval = moab.delete_entities(&meshset,1); CHKERRQ_MOAB(rval);
