[MOAB-dev] Resolving shared entities on prisms
Lukasz Kaczmarczyk Lukasz.Kaczmarczyk at glasgow.ac.uk
Tue Apr 5 06:51:26 CDT 2016
Hello,
I have created muli-layered shell from prisms elements. For attached partitioned mesh (3 partitions) for I check output for shared own entities, however internal edges, on shared quads, between layers (internal edges) are not resolved as a shared. Everything else is ok.
This is what I don’t understand, it could be error on my side, however I don;t see where. Could you pleas look at this and point me to potential error. It could be related to prisms? It works perfectly for single layer of prisms elements.
PS.
This is part of work on solid shell elements, for interested, pleas look here,
https://www.dropbox.com/s/zml82aj027hfsbb/solid_shell.pptx?dl=0
Kind regards,
Lukasz
const char *option;
option = “PARALLEL=BCAST_DELETE;"
	"PARALLEL_RESOLVE_SHARED_ENTS;"
        "PARTITION=PARALLEL_PARTITION;";
 rval = moab.load_file(“tmp.h5m", 0, option); CHKERRQ_MOAB(rval);
        Range shared_ents;
        // Get entities shared with all other processors
        rval = pcomm->get_shared_entities(-1, shared_ents);
        Range owned_entities;
        rval = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_entities);
        EntityHandle meshset;
        rval = moab.create_meshset(MESHSET_SET,meshset); CHKERRQ_MOAB(rval);
        rval = moab.add_entities(meshset,owned_entities); CHKERRQ_MOAB(rval);
        ostringstream o1;
        o1 << "owned_" << pcomm->rank() << ".vtk";
        moab.write_file(o1.str().c_str(),"VTK","",&meshset,1);
        rval = moab.delete_entities(&meshset,1); CHKERRQ_MOAB(rval);
Desc: tmp.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160405/20ca62f6/attachment-0001.obj>
