[MOAB-dev] Load Multiple Geometries into MOAB Instance
    Chelsea D'Angelo
    cdangelo27 at gmail.com
    Fri Mar 18 12:02:49 CDT 2016
Mesh based geometry files.  Specifically, I produced several cubes, loaded
the h5m files (each containing one cube) into the same MOAB instance and
wrote out a single file.  All global ids (for volumes and surfaces)  in the
file I wrote out were equal to 1.
I want to load two mesh geometries that each have multiple volumes into the
same instance.  I'm trying to find a way to rename the global ids so each
volume has a unique id.
On Fri, Mar 18, 2016 at 11:49 AM, Grindeanu, Iulian R. <iulian at mcs.anl.gov>
wrote:
> what geometry files?
> cubit files or occ files, or mesh based geometry files?
> I don't think we can avoid collision, as global ids are just tags.
> Maybe programmatically
> what is the workflow?
> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of Chelsea D'Angelo [cdangelo27 at gmail.com]
> *Sent:* Friday, March 18, 2016 11:41 AM
> *To:* moab-dev at mcs.anl.gov
> *Subject:* [MOAB-dev] Load Multiple Geometries into MOAB Instance
> Hi everyone,
> Is it possible to load multiple geometries into the same MOAB instance and
> avoid collision of the global ID space?
> Thanks!
Chelsea D'Angelo
Research Assistant
University of Wisconsin-Madison
Engineering Research Bldg. - Rm. 434
1500 Engineering Drive
Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20160318/42da5c53/attachment.html>
