[MOAB-dev] Is cubit now required by cgma
JR Cary
cary at txcorp.com
Sat Dec 19 17:39:18 CST 2015
Hi Vijay,
Thanks for responding. The configure command is
'/opt/contrib-clangcxx11/cmake-3.2.2-ser/bin/cmake' \
-DCMAKE_INSTALL_PREFIX:PATH=/opt/volatile-clangcxx11/cgm-master.r1494-sersh
-DCMAKE_BUILD_TYPE:STRING=Release \
-DCMAKE_COLOR_MAKEFILE:BOOL=FALSE \
-DCMAKE_VERBOSE_MAKEFILE:BOOL=TRUE \
-DBUILD_SHARED_LIBS='ON' \
-DCMAKE_C_COMPILER:FILEPATH='/usr/bin/clang' \
-DCMAKE_CXX_COMPILER:FILEPATH='/usr/bin/clang++' \
-DCMAKE_Fortran_COMPILER:FILEPATH='/opt/homebrew/bin/gfortran-4.9' \
-DCMAKE_C_FLAGS:STRING='-fPIC -pipe' \
-DCMAKE_CXX_FLAGS:STRING='-std=c++11 -stdlib=libc++ -fPIC -pipe' \
-DCMAKE_Fortran_FLAGS:STRING='-fPIC -pipe' \
-DCGM_OCC='ON' \
-DOCE_DIR:PATH='/opt/volatile-clangcxx11/oce-stable.r1462-sersh/OCE.framework/Versions/0.17/Resources'
/projdir/composerall/cgm
where
$ ls
OCE-libraries-release.cmake OCEConfig.cmake
OCE-libraries.cmake OCEConfigVersion.cmake
I have completely merged upstream/master to my master:
cgm$ git checkout upstream-master
Switched to branch 'upstream-master'
Your branch is up-to-date with 'upstream/master'.
cgm$ git remote -v | grep upstream
upstream https://jrobcary@bitbucket.org/fathomteam/cgm.git (fetch)
upstream https://jrobcary@bitbucket.org/fathomteam/cgm.git (push)
cgm$ git checkout master
Switched to branch 'master'
Your branch is up-to-date with 'origin/master'.
cgm$ git diff upstream-master
Thx....John
