[MOAB-dev] GLOBAL_IDs, building map from moab mesh
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Mon Dec 7 17:27:13 CST 2015
OK,
this file did not have global ids before
"default" for global id is 0, so all global ids are filled with 0
maybe we should change the default.
We have some methods to assign global ids, if they are not present; maybe it should be part of converting (actually reading from vtk format?)
we need to discuss about this
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Nico Schlömer [nico.schloemer at gmail.com]
Sent: Monday, December 07, 2015 5:11 PM
To: Vijay S. Mahadevan
Cc: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] GLOBAL_IDs, building map from moab mesh
Nope, not playing around with anything. Simply run
mbconvert pacman.vtk pacman.h5m
on [1] and find the GLOBAL_IDs all zeroed out. Can you confirm? If yes, I'll be happy to file a bug.
Cheers,
Nico
[1] http://chunk.io/f/ea2a0f63adf04a2bb57338fe853ab05b
On Mon, Dec 7, 2015 at 10:29 PM Vijay S. Mahadevan <vijay.m at gmail.com<mailto:vijay.m at gmail.com>> wrote:
Using GLOBAL_ID for finding matching entities is the simplest way to
address your use case.
> I now bumped into a bug in serial execution. I noticed that the output of
> `mbconvert somefile.vtk somefile.h5m` generates GLOBAL_ID list full of 0s,
> as opposed to the nice list of 1, 2, 3,... as generated by `mbpart`.
> Apparently you're not supposed to rely on GLOBAL_ID after all? Is there a
> better approach that also works in serial?
This seems fishy. Are you overwriting the GLOBAL_ID or setting it
yourselves in memory ?
Vijay
On Mon, Dec 7, 2015 at 4:13 PM, Nico Schlömer <nico.schloemer at gmail.com<mailto:nico.schloemer at gmail.com>> wrote:
> Hi everyone,
> To build a map for multi-process meshes, I need to be able to identify that
> node N on proc 0 is the same as node M on proc 1. For this, I'm using the
> GLOBAL_ID property. I know that this list isn't necessarily contiguous or
> 1-based, but that's fine.
> Cheers,
> Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151207/9c0b7239/attachment-0001.html>
