[MOAB-dev] problem with pcomm
Lorenzo Alessio Botti
bottilorenzo at gmail.com
Thu Dec 3 09:45:09 CST 2015
> 636 Clang:*)
> 637 FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -stdlib=libc++"
> 638 FATHOM_CXX_32BIT=-m32
> 639 FATHOM_CXX_64BIT=-m64
> 640 ;;
> 641 SunWorkshop:i?86|SunWorkshop:x86_64)
> 642 FATHOM_CXX_32BIT=-m32
> 643 FATHOM_CXX_64BIT=-m64
> 644 ;;
> 645 *)
> 646 ;;
> 647 esac
> 648 AC_MSG_RESULT([$cxx_compiler:$host_os:$host_cpu])
> 649
> 650 # Check for specific overrides
> 651 CXX_LDFLAGS=""
> 652 if (test "$cxx_compiler:${host_os:0:6}" == "Clang:darwin"); then
> 653 CXX_LDFLAGS="$CXX_LDFLAGS -stdlib=libc++"
> 654 LIBS="$LIBS -lc++”
I changed lines 637 and 653 of compilers.m4 as you suggested (libc++ instead of libstdc++).
My code runs fine (I’m on Mavericks with latests clang).
As opposite to the previous build make check now get suck at dual_test.
The other tests runs fine.
Thanks everybody for help!
As Vijay pointed out I thinks this is the way to go since it allows to use c++11.
Thanks again.
Bests.
Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151203/82a0c2b3/attachment.html>
