[MOAB-dev] problem with pcomm
    Lorenzo Alessio Botti
    lorenzoalessiobotti at gmail.com
    Wed Dec  2 12:07:08 CST 2015
This is lldb
Process 485 launched: '/Users/ihabia/src/tools/bug/mbtestrun' (x86_64)
Process 485 stopped
* thread #1: tid = 0x1597, 0x000000010004ba06 mbtestrun`std::vector<char, std::allocator<char> >::begin(this=0x0000000000001030) const + 38 at stl_vector.h:340, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x1030)
    frame #0: 0x000000010004ba06 mbtestrun`std::vector<char, std::allocator<char> >::begin(this=0x0000000000001030) const + 38 at stl_vector.h:340
   337 	       */
   338 	      const_iterator
   339 	      begin() const
-> 340 	      { return const_iterator(this->_M_impl._M_start); }
   341
   342 	      /**
   343 	       *  Returns a read/write iterator that points one past the last
And moab compiled with hdf5-1.8.12
# The values below are for an un-installed copy of MOAB used directly
# from its build build directory.  These values will be overridden below
# for installed copies of MOAB.
MOAB_LIBDIR = /Users/ihabia/src2/moab-4.9.0/src/.libs
MOAB_INCLUDES = -I/Users/ihabia/src2/moab-4.9.0/src \
                -I/Users/ihabia/src2/moab-4.9.0/src/oldinc \
                -I/Users/ihabia/src2/moab-4.9.0/src/parallel \
                -I/Users/ihabia/src2/moab-4.9.0/src/LocalDiscretization \
                -I/Users/ihabia/src2/moab-4.9.0/src/RefineMesh
MOAB_INCLUDES +=
MOAB_CPPFLAGS =        -I/Users/ihabia/src2/hdf5-1.8.12/hdf5//include -isystem /Users/ihabia/src2/hdf5-1.8.12/hdf5//include
MOAB_CXXFLAGS =  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -Wno-variadic-macros -stdlib=libstdc++ -g -fstack-protector-all
MOAB_CFLAGS =  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -Wno-variadic-macros -g -fstack-protector-all
MOAB_FFLAGS =
MOAB_FCFLAGS =
MOAB_LDFLAGS =          -L/Users/ihabia/src2/hdf5-1.8.12/hdf5//lib  -stdlib=libstdc++  -fstack-protector-all   -L/Users/ihabia/src2/hdf5-1.8.12/hdf5//lib    -L/Users/ihabia/src2/hdf5-1.8.12/hdf5//lib   -L/Users/ihabia/src2/hdf5-1.8.12/hdf5//lib
MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB    -lhdf5    -lc++ -lz -ldl -lm -lm -lm       -lc++ -lz -ldl -lm -lm -lm
DAGMC_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR}  -lMOAB    -lhdf5    -lc++ -lz -ldl -lm -lm -lm       -lc++ -lz -ldl -lm -lm -lm
MOAB_CXX = /Users/ihabia/src2/mpich-3.2/mpich3//bin/mpicxx
MOAB_CC  = /Users/ihabia/src2/mpich-3.2/mpich3//bin/mpicc
MOAB_FC  =
MOAB_F77  =
# Feature list
MOAB_MPI_ENABLED = yes
MOAB_FORTRAN_ENABLED = no
MOAB_HDF5_ENABLED = yes
MOAB_NETCDF_ENABLED = no
MOAB_IGEOM_ENABLED = no
MOAB_IMESH_ENABLED = no
MOAB_IREL_ENABLED = no
# Override MOAB_LIBDIR and MOAB_INCLUDES from above with the correct
# values for the installed MOAB.
MOAB_LIBDIR=/Users/ihabia/src2/moab-4.9.0/moab/lib
MOAB_INCLUDES=-I/Users/ihabia/src2/moab-4.9.0/moab/include
> On 02 Dec 2015, at 18:58, Grindeanu, Iulian R. <iulian at mcs.anl.gov> wrote:
> Hi Lorenzo,
> This seems to be a problem on your system.
> Maybe gdb is broken?
> http://stackoverflow.com/questions/33159172/unable-to-step-into-a-class-method-gdb <http://stackoverflow.com/questions/33159172/unable-to-step-into-a-class-method-gdb>
> Indeed, the message is not helpful in finding out what is the issue
> Maybe Vijay or Rajeev can help more, they do compile on macs.
> How did you configure hdf5? Did you use the same mpich version?
> Thanks,
> Iulian
> From: Lorenzo Alessio Botti [lorenzoalessiobotti at gmail.com]
> Sent: Wednesday, December 02, 2015 11:33 AM
> To: MOAB dev
> Cc: Grindeanu, Iulian R.
> Subject: Re: [MOAB-dev] problem with pcomm
> This is what I get with gdb
> Not very informative, is it?
> moab is compiled with —enable-debug
> Should I run with or compile with particular flags?
> Reading symbols for shared libraries ++++++++..............bfd_mach_o_scan_read_symtab_symbol: symbol "_bzero" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memccpy" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memchr" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memcmp" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memcpy" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memmove" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_memset" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_strchr" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_strcmp" is unsupported 'indirect' reference: setting to undefined
> bfd_mach_o_scan_read_symtab_symbol: symbol "_strncmp" is unsupported 'indirect' reference: setting to undefined
> ...warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Objects/coretls.build/coretls.build/Objects-normal/x86_64/system_coretls_vers.o" - no debug information available for "system_coretls_vers.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_ciphersuites.a(tls_ciphersuites.o)" - no debug information available for "tls_ciphersuites.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslSession.o)" - no debug information available for "sslSession.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslCipherSpecs.o)" - no debug information available for "sslCipherSpecs.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslDigests.o)" - no debug information available for "sslDigests.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslCrypto.o)" - no debug information available for "sslCrypto.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslChangeCipher.o)" - no debug information available for "sslChangeCipher.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslCert.o)" - no debug information available for "sslCert.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslKeyExchange.o)" - no debug information available for "sslKeyExchange.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslAlertMessage.o)" - no debug information available for "sslAlertMessage.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslHandshake.o)" - no debug information available for "sslHandshake.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslHandshakeFinish.o)" - no debug information available for "sslHandshakeFinish.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(tls1Callouts.o)" - no debug information available for "tls1Callouts.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(sslHandshakeHello.o)" - no debug information available for "sslHandshakeHello.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(tls_handshake.o)" - no debug information available for "tls_handshake.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_handshake.a(ssl3Callouts.o)" - no debug information available for "ssl3Callouts.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(tls1RecordCallouts.o)" - no debug information available for "tls1RecordCallouts.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(ssl3RecordCallouts.o)" - no debug information available for "ssl3RecordCallouts.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(tls_record.o)" - no debug information available for "tls_record.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(sslRc4Cipher.o)" - no debug information available for "sslRc4Cipher.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(sslMemory.o)" - no debug information available for "sslMemory.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(sslUtils.o)" - no debug information available for "sslUtils.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(symCipherParams.o)" - no debug information available for "symCipherParams.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(sslNullCipher.o)" - no debug information available for "sslNullCipher.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(symCipher.o)" - no debug information available for "symCipher.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(tls_digest.o)" - no debug information available for "tls_digest.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(tls_hashhmac.o)" - no debug information available for "tls_hashhmac.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_record.a(tls_hmac.o)" - no debug information available for "tls_hmac.c".
> warning: Could not find object file "/BinaryCache/coreTLS/coreTLS-35.40.1~1/Symbols/BuiltProducts/libcoretls_stream_parser.a(tls_stream_parser.o)" - no debug information available for "tls_stream_parser.c".
> ...................... done
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: KERN_INVALID_ADDRESS at address: 0x0000000000001030
> std::vector<char, std::allocator<char> >::begin (this=0x1030) at stl_vector.h:340
>> On 02 Dec 2015, at 18:29, Grindeanu, Iulian R. <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>> Dear Lorenzo,
>> you just configure moab with --enable-debug
>> something like this:
>> ./configure --disable-fortran --disable-imesh --with-mpi=/Users/ihabia/src2/mpich-3.2/mpich3/ --with-hdf5=/Users/ihabia/src2/hdf5-1.8.16/hdf5/ --prefix=/Users/ihabia/src2/moab-4.8.2/moab  --enable-debug
>> I see now that you use hdf5 1.8.16, the make check error you see could be related to this
>> (we test regularly with 1.8.12)
>> Still, your crash with pcomm is unrelated to hdf5 version
>> Iulian
>> From: Lorenzo Alessio Botti [lorenzoalessiobotti at gmail.com <mailto:lorenzoalessiobotti at gmail.com>]
>> Sent: Wednesday, December 02, 2015 11:11 AM
>> To: MOAB dev
>> Dear Iulian, how do I enable debug mode?
>> I want to be sure compile with the right flags…
>> Thanks
>> Lorenzo
>>> On 02 Dec 2015, at 18:03, Grindeanu, Iulian R. <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>>> Hi Lorenzo,
>>> Your code works on my linux machine.
>>> It could be something specific to OSX,
>>> Sometimes we find that OSX uncovers bugs
>>> You mentioned that there is a seg fault at pcomm_tag(mbImpl, true)
>>> It just creates there a sparse tag with name __PARALLEL_COMM, which will be used to store ParallelComm objects on the root (entity handle = 0)
>>> Can you compile in debug mode and give more trace info?
>>> Thanks,
>>> Iulian
>>> Sent: Wednesday, December 02, 2015 10:20 AM
>>> To: MOAB dev
>>> Cc: Grindeanu, Iulian R.; Vijay S. Mahadevan
>>>    MOAB 4.8.2: test/test-suite.log
>>> # TOTAL: 35
>>> # PASS:  35
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  0
>>> # XPASS: 0
>>> # ERROR: 0
>>> .. contents:: :depth: 2
>>> This is the sole failure.
>>>    MOAB 4.8.2: test/parallel/test-suite.log
>>> # TOTAL: 11
>>> # PASS:  10
>>> # SKIP:  0
>>> # XFAIL: 0
>>> # FAIL:  1
>>> # XPASS: 0
>>> # ERROR: 0
>>> FAIL: parallel_hdf5_test
>>> Running test_write_elements ...
>>> Warning: acis file has sequence numbers!
>>> Running test_write_shared_sets ...
>>> Running test_var_length_parallel ...
>>> Running test_read_elements ...
>>> Running test_read_elements_by_rank ...
>>> Running test_read_tags ...
>>> Running test_read_global_tags ...
>>> Running test_read_sets ...
>>> Running test_read_sets_bcast_dups ...
>>> Running test_read_sets_read_dups ...
>>> Running test_read_bc_sets ...
>>> Fatal error in MPI_Reduce: Invalid datatype, error stack:
>>> MPI_Reduce(1258): MPI_Reduce(sbuf=0x7fff533896d4, rbuf=0x7fff533896c8, count=3, MPI_DATATYPE_NULL, MPI_SUM, root=0, MPI_COMM_WORLD) failed
>>> MPI_Reduce(1168): Datatype for argument datatype is a null datatype
>>> FAIL parallel_hdf5_test (exit status: 3)
>>> The whole code, without any MPI initialisation,
>>> #include "moab/ParallelComm.hpp"
>>> #include "MBParallelConventions.h"
>>> #include "MBTagConventions.hpp"
>>> #include "moab/Core.hpp"
>>> #include "moab_mpi.h"
>>> using namespace moab;
>>> int main(int argc, char **argv)
>>>   Core moab;
>>>   Interface& imoab = moab;
>>>   ParallelComm* pcomm = ParallelComm::get_pcomm(&moab, 0);
>>>   if (0 == pcomm)
>>>     pcomm = new ParallelComm(&imoab, MPI_COMM_WORLD);
>>>   delete pcomm;
>>>   return EXIT_SUCCESS;
>>> This is the Makefile
>>> MOAB_LIB_DIR = /Users/ihabia/src2/moab-4.8.2/moab/
>>> include $(MOAB_LIB_DIR)/lib/moab.make
>>> %.o : %.cpp
>>>         @echo "Compiling ("$(CXX)") "$<" "
>>>         @$(CXX) ${MOAB_INCLUDES} -c $< -o $@
>>> CXX = mpicxx -O2 -DNDEBUG
>>> objects := $(patsubst %.cpp,%.o,$(wildcard ./*.cpp))
>>> mbtestrun : $(objects)
>>>         @echo "Linking "$(CURDIR)"/"$@
>>>         @$(CXX) $(objects) -o $@ $(MOAB_LIBS_LINK)
>>> .PHONY : clean
>>> clean :
>>>         @rm $(objects)
>>> and this is mob.make
>>> MOAB_LIBDIR = /Users/ihabia/src2/moab-4.8.2/src/.libs
>>> MOAB_INCLUDES = -I/Users/ihabia/src2/moab-4.8.2/src \
>>>                 -I/Users/ihabia/src2/moab-4.8.2/src/oldinc \
>>>                 -I/Users/ihabia/src2/moab-4.8.2/src/parallel \
>>> MOAB_INCLUDES +=
>>> MOAB_CPPFLAGS =        -I/Users/ihabia/src2/hdf5-1.8.16/hdf5//include -isystem /Users/ihabia/src2/hdf5-1.8.16/hdf5//include
>>> MOAB_CXXFLAGS =  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -stdlib=libstdc++ -O2 -DNDEBUG
>>> MOAB_CFLAGS =  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG
>>> MOAB_FFLAGS =
>>> MOAB_FCFLAGS =
>>> MOAB_LDFLAGS =          -L/Users/ihabia/src2/hdf5-1.8.16/hdf5//lib  -stdlib=libstdc++
>>> MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB    -lhdf5    -lc++ -lz -ldl -lm       -lc++ -lz -ldl -lm
>>> DAGMC_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR}  -lMOAB    -lhdf5    -lc++ -lz -ldl -lm       -lc++ -lz -ldl -lm
>>> MOAB_FC  =
>>> MOAB_F77  =
>>> MOAB_LIBDIR=/Users/ihabia/src2/moab-4.8.2/moab/lib
>>> MOAB_INCLUDES=-I/Users/ihabia/src2/moab-4.8.2/moab/include
>>>> On 02 Dec 2015, at 16:17, Grindeanu, Iulian R. <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
>>>> Hi Lorenzo,
>>>> Do you initialize MPI before using moab?
>>>> Iulian
>>>> ________________________________________
>>>> From: moab-dev-bounces at mcs.anl.gov <mailto:moab-dev-bounces at mcs.anl.gov> [moab-dev-bounces at mcs.anl.gov <mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Vijay S. Mahadevan [vijay.m at gmail.com <mailto:vijay.m at gmail.com>]
>>>> Sent: Wednesday, December 02, 2015 9:08 AM
>>>> To: Lorenzo Alessio Botti
>>>> Cc: MOAB dev
>>>> Lorenzo, we test your configuration very regularly (on buildbot and on
>>>> linux machines) and I haven't seen any issues with ParallelComm. Does
>>>> "make check" pass cleanly ?
>>>> I'll see if I can replicate this on my Mac.
>>>> Vijay
>>>> On Wed, Dec 2, 2015 at 8:49 AM, Lorenzo Alessio Botti
>>>> <lorenzoalessiobotti at gmail.com <mailto:lorenzoalessiobotti at gmail.com>> wrote:
>>>>> Dear All,
>>>>> I have a problem with the latest moab builds (both 4.8.2 and 4.9)…
>>>>> I cannot run the following code in an application linked to moab
>>>>>  Core moab;
>>>>>  if (0 == pcomm)
>>>>>  delete pcomm;
>>>>> It seems that a segmentation fault is triggered during the initialization of
>>>>> the pcomm in particular in this function
>>>>>  Tag ParallelComm::pcomm_tag(Interface *impl,
>>>>>                              bool create_if_missing)
>>>>> with create_if_missing = true.
>>>>> I’m building on OS X.
>>>>> Have you ever experienced this issue? What can I do?
>>>>> I attach the config.log below
>>>>> Bests
>>>>> Lorenzo
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151202/6e9b9350/attachment-0001.html>
