[MOAB-dev] [Nek5000-users] MOAB partitioning
Popov, Emilian L.
popove at ornl.gov
Wed Nov 11 09:32:15 CST 2015
Vijay and all:
When I run: mbpart -m ML_KWAY 32 <file> the code exits with a segmentation fault. Any thoughts?
-emilian
-----Original Message-----
From: Vijay S. Mahadevan [mailto:vijay.m at gmail.com]
Sent: Monday, November 09, 2015 10:27 AM
To: Popov, Emilian L.
Subject: Re: [MOAB-dev] [Nek5000-users] MOAB partitioning
You can run "make check" to verify the build worked fine. Then run "make install", go to build/examples directory, use the makefile to compile an example. Update MOAB_DIR as needed in the makefile.
Let us know if you run into any other issues.
Vijay
On Mon, Nov 9, 2015 at 9:21 AM, Popov, Emilian L. <popove at ornl.gov> wrote:
> Yes, that was the problem, all looks OK now, appreciate the help. Moab seems to install fine as well. Is there any way I can test the Moab install?
> Thanks,
> -emilian
> Sent: Monday, November 09, 2015 10:11 AM
> To: Popov, Emilian L.; moab-dev at mcs.anl.gov
> You need to install metis (make install). This will install the header/libs under the prefix directory if you specified it during configuration.
> MOAB will NOT work with Metis source directory. Let me know if your installation went correctly.
> Vijay
> On Mon, Nov 9, 2015 at 9:06 AM, Popov, Emilian L. <popove at ornl.gov> wrote:
>> Hi Vijay,
>> I rebuilt metis, and it should be fine now. The library 'libmetis.a' is in ..../metis-5.1.0/build/Linux-x86_64/libmetis, there is no /lib directory.
>> Let me know pls whether I need to change the Moab configure script in one way or other.
>> Thanks,
>> -emilian
>> Sent: Thursday, November 05, 2015 5:42 PM
>> Hmm, I would say that your installation is screwed up for metis. Are you sure you configured Metis with a prefix ? MOAB can only work with the installed metis directory and not directly with the sources since these keep changing every version.
>> When you install Metis correctly, you should see something like this:
>> [ vijaysm at tachyon ~ ]> find /usr/software/metis-5.1.0/
>> /usr/software/metis-5.1.0/ /usr/software/metis-5.1.0/include
>> /usr/software/metis-5.1.0/include/metis.h
>> /usr/software/metis-5.1.0/bin
>> /usr/software/metis-5.1.0/bin/cmpfillin
>> /usr/software/metis-5.1.0/bin/ndmetis
>> /usr/software/metis-5.1.0/bin/graphchk
>> /usr/software/metis-5.1.0/bin/m2gmetis
>> /usr/software/metis-5.1.0/bin/gpmetis
>> /usr/software/metis-5.1.0/bin/mpmetis
>> /usr/software/metis-5.1.0/lib
>> /usr/software/metis-5.1.0/lib/libmetis.a
>> Vijay
>> On Thu, Nov 5, 2015 at 4:34 PM, Popov, Emilian L. <popove at ornl.gov> wrote:
>>> I'm not sure whether we look for a dynamic/static library or for bunch of files, but in /home/owp/METIS/metis-5.1.0 there is a folder 'libmetis' that contains several C files and headers.
>>> Thanks,
>>> -emilian
>>> Sent: Thursday, November 05, 2015 5:03 PM
>>> From your config.log
>>> METIS_INC_FLAGS='-I/home/owp/METIS/metis-5.1.0/include'
>>> METIS_LIBS='-L/home/owp/METIS/metis-5.1.0 -lmetis'
>>> Is the metis library not in /home/owp/METIS/metis-5.1.0 ? Is it in /home/owp/METIS/metis-5.1.0/lib ? Please verify and let me know. It configures fine on my local build and on our nightlies.
>>> Vijay
>>> On Thu, Nov 5, 2015 at 2:51 PM, Popov, Emilian L. <popove at ornl.gov> wrote:
>>>> See the end of make.log: from the patched version
>>>> Thanks,
>>>> -emilian
>>>> Sent: Thursday, November 05, 2015 3:33 PM
>>>> If you are still interested in a patched tarball, its available at
>>>> ftp://ftp.mcs.anl.gov/pub/fathom/moab-4.8.2p1.tar.gz
>>>> Let me know if this fixes your issues. Thanks.
>>>> Vijay
>>>> On Thu, Nov 5, 2015 at 2:27 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>>>>> Ah I see. I recently merge a PR to fix precisely this issue.
>>>>> https://bitbucket.org/fathomteam/moab/pull-requests/157/fix-metis-
>>>>> p
>>>>> a
>>>>> r
>>>>> t
>>>>> itioner-for-serial-builds/diff
>>>>> I can backport the fix to moab-4.8.2 if you prefer that. Or you
>>>>> could directly use MOAB master from Bitbucket
>>>>> (https://bitbucket.org/fathomteam/moab/overview).
>>>>> Vijay
>>>>> On Thu, Nov 5, 2015 at 2:00 PM, Popov, Emilian L. <popove at ornl.gov> wrote:
>>>>>> Apparently I've sent you the config log instead of make log. Here it is, complains form 'mpi.h'
>>>>>> Thanks,
>>>>>> -emilian
>>>>>> Sent: Thursday, November 05, 2015 12:49 PM
>>>>>> Cc: moab-dev at mcs.anl.gov
>>>>>> Emilian, I don't see what is the problem anymore. MOAB successfully configured according to your logs and mbpart will be built with Metis support. From your output:
>>>>>> #define HAVE_METIS 1
>>>>>> So I don't see any issues here. Send us the error output from make ?
>>>>>> Vijay
>>>>>> On Thu, Nov 5, 2015 at 11:39 AM, Popov, Emilian L. <popove at ornl.gov> wrote:
>>>>>>> Hello Vijay,
>>>>>>> Is there any resolution on the below.
>>>>>>> Thanks,
>>>>>>> -emilian
>>>>>>> From: nek5000-users-bounces at lists.mcs.anl.gov
>>>>>>> [mailto:nek5000-users-bounces at lists.mcs.anl.gov] On Behalf Of
>>>>>>> nek5000-users at lists.mcs.anl.gov
>>>>>>> Sent: Tuesday, October 27, 2015 2:59 PM
>>>>>>> To: nek5000-users at lists.mcs.anl.gov; moab-dev at mcs.anl.gov
>>>>>>> Subject: Re: [Nek5000-users] MOAB partitioning
>>>>>>> Emilian,
>>>>>>> Let's fix the MOAB related issues first on the MOAB mailing list.
>>>>>>> Please send us your config.log file so that we can provide
>>>>>>> pointers to fix the configuration problems. Once this is done, we can revisit NEK-MOAB.
>>>>>>> Vijay
>>>>>>> On Monday, October 26, 2015, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>> Vijay,
>>>>>>> I downloaded moab-4.8.2 and configured and then ran ‘make’, but
>>>>>>> am getting errors from missing ‘mpi.h’ and metis.h, perhaps the
>>>>>>> configuration is not OK?
>>>>>>> Thanks,
>>>>>>> -emilian
>>>>>>> Sent: Friday, October 23, 2015 12:24 PM
>>>>>>> What version of MOAB are you using ? It should be available with
>>>>>>> the last MOAB 4.8.2 release [1] I think. Let us know if you have problems.
>>>>>>> Vijay
>>>>>>> [1] http://ftp.mcs.anl.gov/pub/fathom/moab-4.8.2.tar.gz
>>>>>>> On Friday, October 23, 2015, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>>>> Thanks Vijay, however the option ‘—with-metis’ does not seem to
>>>>>>> exist, please advice.
>>>>>>> -emilian
>>>>>>> Sent: Friday, October 23, 2015 11:35 AM
>>>>>>> Emilian,
>>>>>>> If you want the partitioner tools, you need to configure MOAB
>>>>>>> with either metis (--with-metis=DIR) or with zoltan and
>>>>>>> optionally parmetis. Let us know if you have questions. The
>>>>>>> metis installation route is extremely straightforward and you should not encounter any issues.
>>>>>>> Vijay
>>>>>>> Dear Nek/Moab users,
>>>>>>> I built Moab, but in the bin folder the ‘mbpart’ code is missing
>>>>>>> and I need it to partition an .h5m mesh file for Nek.
>>>>>>> Any suggestions?
>>>>>>> Thanks,
>>>>>>> -emilian
