[MOAB-dev] get_vertex_coordinates()
    Nico Schlömer
    nico.schloemer at gmail.com
    Thu Nov  5 18:28:43 CST 2015
Thanks, that does the trick!
--Nico
On Thu, Nov 5, 2015 at 5:41 PM Grindeanu, Iulian R. <iulian at mcs.anl.gov>
wrote:
> you can use
> http://www.mcs.anl.gov/~fathom/moab-docs/html/classmoab_1_1Interface.html#a30ecd0d51554763a820513f637f09df0
> you will have to get vertices first in a range
> *From:* moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of Nico Schlömer [nico.schloemer at gmail.com]
> *Sent:* Wednesday, November 04, 2015 6:32 PM
> *To:* moab-dev at mcs.anl.gov
> *Subject:* [MOAB-dev] get_vertex_coordinates()
> Hi everyone,
> I'm just looking into how I can extract the vertex coordinates from a
> mesh, and found [1]. Curiously, the functions returns a single vector of
> length 3*N (N being the number of vertices), arranged like
> x0 x1 ... xN y0 y1 ... yN z0 ... zN.
> This I find a little weird, since typically you'll be interested inall
> coordinates of a single point, (xK, yK, zK), and given the above memory
> arrangement, you have to jump around the vector, completely eliminating the
> chances for cache hits. If you really have to return a single vector, a
> better layout appears to be
> x0 y0 z0 x1 y1 z1 ...
> Perhaps there is a reason behind the above output though. What do you
> think?
> Cheers,
> Nico
> [1]
> http://www.mcs.anl.gov/~fathom/moab-docs/html/classmoab_1_1Interface.html#aa25d4dcabd4fb5eb0db2b7f5c3b3d6d2
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151106/0454cf15/attachment.html>
