[MOAB-dev] moab/ParallelComm.hpp include order
    Nico Schlömer
    nico.schloemer at gmail.com
    Tue Nov  3 03:59:49 CST 2015
Submitted a PR [1], tested and verified on two machines.
--Nico
[1]
https://bitbucket.org/fathomteam/moab/pull-requests/168/remove-old-netcdf-workaround-from/diff
On Tue, Nov 3, 2015 at 10:21 AM Nico Schlömer <nico.schloemer at gmail.com>
wrote:
> Well, perhaps removing just the workaround will do. I'll test it...
> --Nico
> On Tue, Nov 3, 2015 at 8:55 AM Nico Schlömer <nico.schloemer at gmail.com>
> wrote:
>> > MPI_INCLUDED is defined in mpi.h (easy to check)
>> Not in my installation. This
>> #include <iostream>
>> #include <mpi.h>
>> int main() {
>> #ifdef MPI_INCLUDED
>>   std::cout << "defined" << std::endl;
>> #else
>>   std::cout << "NOT defined" << std::endl;
>> #endif
>>   return 0;
>> Returns `NOT defined` on my machine (OpenMPI 1.6.3); check out [1].
>> I checked the history of `./src/parallel/moab_mpi.h` and found that it's
>> had it's first and last changes in 2010. Perhaps the issues it tried to
>> work around don't exist anymore nowadays.
>> I would suggest removing the file `./src/parallel/moab_mpi.h` and have
>> some people test it. Alright?
>> --Nico
>> [1] https://github.com/open-mpi/ompi/blob/master/ompi/include/mpi.h.in
>> On Tue, Nov 3, 2015 at 12:34 AM Vijay S. Mahadevan <vijay.m at gmail.com>
>> wrote:
>>> I cant seem to replicate the issue locally. Nevertheless, that file
>>> definitely looks quite strange since I don't think we hit many of the
>>> paths in moab_mpi.h as MB_SEEK*/MB_RESTORE* are not defined in
>>> configure (autotools) anymore. Certainly, not in CMake.
>>> MPI_INCLUDED is defined in mpi.h (easy to check) and this just checks
>>> if you have previously included the header already (note that it is
>>> ifndef and not ifdef). So I'm not worried about the undefs really
>>> unless your MPI version does not define MPI_INCLUDED
>>> (openmpi/intel-mpi ??).
>>> Now in your case, if all of the MPI variables are getting undefined,
>>> we need to track why that is the case. Looking at the history for that
>>> file didn't reveal much but let us know your configuration command for
>>> MOAB so that we can create a build that replicates the failure.
>>> Vijay
>>> On Mon, Nov 2, 2015 at 5:09 PM, Nico Schlömer <nico.schloemer at gmail.com>
>>> wrote:
>>> > @Iulian, oh yes, you're right. But the error remains the same:
>>> > MPI_Comm my = MPI_COMM_WORLD;
>>> > The reason lies `moab_mpi.h`. There we find
>>> > /* Work around brain-dead netcdf.h */
>>> > #ifndef MPI_INCLUDED
>>> > #  undef MPI_Comm
>>> > #  undef MPI_Info
>>> > #  undef MPI_COMM_WORLD
>>> > #  undef MPI_INFO_NULL
>>> > #endif
>>> > Whoops! All of MPI undefined. No idea what's going on here and why.
>>> > Any insight?
>>> > --Nico
>>> > On Tue, Nov 3, 2015 at 12:02 AM Grindeanu, Iulian R. <
>>> iulian at mcs.anl.gov>
>>> > wrote:
>>> >> this error has nothing to do with moab/ParallelComm.hpp
>>> >> MPI_COMM_WORLD is just a constant, not a type
>>> >> this should give compile errors too.
>>> >> Or I don't get what are you trying to do
>>> >> #include <mpi.h>
>>> >> int main() {
>>> >>   MPI_COMM_WORLD my;
>>> >> ________________________________
>>> >> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>>> >> behalf of Nico Schlömer [nico.schloemer at gmail.com]
>>> >> Sent: Monday, November 02, 2015 4:49 PM
>>> >> To: Vijay S. Mahadevan
>>> >> Cc: moab-dev at mcs.anl.gov
>>> >> Subject: Re: [MOAB-dev] moab/ParallelComm.hpp include order
>>> >> Alright. This
>>> >> #include <mpi.h>
>>> >> #include <moab/ParallelComm.hpp>
>>> >> int main() {
>>> >>   MPI_COMM_WORLD my;
>>> >> creates the same
>>> >>  error: ‘MPI_COMM_WORLD’ was not declared in this scope
>>> >> Can you reproduce?
>>> >> Cheers,
>>> >> Nico
>>> >> On Mon, Nov 2, 2015 at 11:38 PM Nico Schlömer <
>>> >> wrote:
>>> >>> Including <moab/MOABConfig.h> doesn't help. I'll see about creating a
>>> >>> minimal example...
>>> >>> --Nico
>>> >>> On Mon, Nov 2, 2015 at 10:05 PM Vijay S. Mahadevan <
>>> >>> wrote:
>>> >>>> Can you try including moab/MOABConfig.h directly in your test before
>>> >>>> ParallelComm and see if that resolves issues ?
>>> >>>> ParallelComm includes Interface.hpp which in turn includes
>>> >>>> MOABConfig.h. If you are including some other MOAB header before
>>> >>>> these, MOAB_HAVE_MPI might not be defined.
>>> >>>> Vijay
>>> >>>> On Mon, Nov 2, 2015 at 3:00 PM, Nico Schlömer <
>>> >>>> wrote:
>>> >>>> > It's a little convoluted with Trilinos includes right now, I'm
>>> trying
>>> >>>> > to
>>> >>>> > generate a minimal example.
>>> >>>> > --Nico
>>> >>>> > On Mon, Nov 2, 2015 at 10:00 PM Vijay S. Mahadevan <
>>> >>>> > wrote:
>>> >>>> >> Nico, can you give an example ? What else did you include before
>>> >>>> >> ParallelComm to get such an error ? I am guessing this has to do
>>> with
>>> >>>> >> how moab/MOABConfig.h gets included since that's where
>>> MOAB_HAVE_MPI
>>> >>>> >> is defined.
>>> >>>> >> Vijay
>>> >>>> >> On Mon, Nov 2, 2015 at 2:47 PM, Nico Schlömer
>>> >>>> >> wrote:
>>> >>>> >> > When playing with MOAB, I found that if I include the header
>>> >>>> >> > after something that's also using MPI, I'm getting strange
>>> >>>> >> > compilation
>>> >>>> >> > errors of the kind
>>> >>>> >> > Has anyone else experienced this?
>>> >>>> >> > Cheers,
>>> >>>> >> > Nico
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20151103/41db3bed/attachment-0001.html>
