[MOAB-dev] coverity
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Wed Sep  2 13:16:59 CDT 2015
Hi Nico,
Thanks for setting up a Coverity instance for MOAB. This will be very
useful in finding more issues in the code base.
We currently do static analysis with cppcheck [1], valgrind runs for memory
errors and test coverage with lcov [2]. There are also several outstanding
fixes in branches (valgrind_fixes, cppcheck_fixes), which will be merged to
master soon.
I will send you a separate email once I register.
Vijay
[1] http://gnep.mcs.anl.gov:8010/static_analysis.html
[2] http://gnep.mcs.anl.gov:8010/coverage.html
On Wednesday, September 2, 2015, Nico Schlömer <nico.schloemer at gmail.com>
wrote:
> Hi everyone,
> I recently set up a Coverity instance for MOAB [1] which helps finding
> coding errors that the compiler won't catch (resource leaks, missing
> `break` in `switch`es and so forth).
> [image: leak.png]
> For security, not everyone can view the details of the errors, but if you
> sign up at [1] I'll be happy to approve you.
> Cheers,
> Nico
> [1] https://scan.coverity.com/projects/moab?tab=overview
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150902/c493a8a3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150902/c493a8a3/attachment-0001.png>
