[MOAB-dev] ProgOptions recognizes negative positional arguments as options
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Tue Sep 1 16:42:13 CDT 2015
Looking at the code, there is another option you can use
It is definitely not documented :(
The option is --, to indicate the end of optional arguments,
(in the code, it turns the boolean "no_more_flags" to true)
Then all the rest arguments are treated as required positional arguments.
So, in your case, something like
./prog_opts_bug --o file.sat -- 1 -2 3 4 5 6 7 -8 9 10
would we processed correctly
This assumes that all optional arguments are in the beginning, and all required arguments are at the end
Optional arguments are followed by -- , which indicates the end of optional arguments
Iulian
Sent: Tuesday, September 01, 2015 2:35 PM
To: Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] ProgOptions recognizes negative positional arguments as options
Iulian,
Attached is a clip from this program which exemplifies the problem.
I have 10 required double options and I use the addRequiredArg method
for each.
There is one optional argument but its location/presence doesn't seem to
matter.
The error appears in parseCommandLine. As far as I can tell, this method
tries to filter out all of the options first and assumes the remaining
arguments are required positionals.
Negative arguments seem to get picked up as options, returning an error.
Cheers,
Patrick
On 09/01/2015 01:43 PM, Grindeanu, Iulian R. wrote:
> Hi
> I am not familiar with that class, I think someone in Madison developed it
> what is your test ?
> How many "required" double options do you have?
> Do you use addRequiredArg method? How many times?
> When does the error appear? (at parsing?) Can you put the "optional" one at the end of the arguments?
> If you use addOptionalArgs, do you still see that problem? (I understand you prefer "required", as it is simpler)
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of shriwise [shriwise at wisc.edu]
> Sent: Tuesday, September 01, 2015 12:43 PM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] ProgOptions recognizes negative positional arguments as options
> Hey all,
> Just noticed this when I was using this incredibly handy class to write
> a program today.
> I use it often, but just noticed this today. I have a series of required
> double arguments and a single option, but when I make one of the doubles
> negative, ProgOptions tries to evaluate the argument as an option and
> returns an error.
> In this case, I've registered one long option with the ProgOptions
> class. This error occurs whether I specify this option in the command
> line or not.
> I've made a few small changes so I can continue to use the class with
> negative double arguments, but it breaks many of the tests in MOAB.
> Is anyone more familiar with this class? If not, I can look more deeply
> into it today/tomorrow and submit a test&fix.
> Cheers,
> Patrick
> Patrick C. Shriwise
> Research Fellow
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
Patrick C. Shriwise
Research Fellow
Madison, WI 53706
(608) 446-8173
