[MOAB-dev] Matrix3 EigenDecomp Bug
Patrick Shriwise shriwise at wisc.edu
Tue Aug 18 20:48:21 CDT 2015
Cool! I hope it helps. We'll fine out soon. I actually found some time
to get the fix into a branch tonight but I'm actually having trouble
compiling with the develop branch.
Getting an error like:
In file included from
../../../src/test/dagmc/dagmc_pointinvol_test.cpp:10:0:
../../../src/tools/dagmc/DagMC.hpp:4:26: fatal error: dagmc_export.h: No
such file or directory
  #include "dagmc_export.h"
These export headers are new to me. Any ideas?
Cheers,
Patrick
On 08/18/2015 08:16 PM, Grindeanu, Iulian R. wrote:
> So it was a message from Steve Jackson, in March 2010 :)
> The link is not working anymore, but maybe someone still has that presentation.
> Anyway, GeomTopoTool is using obb tree, and FBEngine is using GeomTopoTool, so the implications of this bug are many.
> thanks for finding it!
> Iulian
> Cc:
>   fathom at lists.mcs.anl.gov
> Tuesday, March 02, 2010 10:44 AM
> I will be presenting some slides on OBB tree performance profiling at this meeting.  They can be found here: http://mywebspace.wisc.edu/stjackson/web/fathom_slides_march2.pdf
> ~S
> From: Patrick Shriwise [shriwise at wisc.edu]
> Sent: Tuesday, August 18, 2015 7:26 PM
> To: Paul Wilson; Grindeanu, Iulian R.; moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] Matrix3 EigenDecomp Bug
> Hi all,
> As Paul said, nothing for sure as to the improvement for scaling, but it
> would make sense. As the number of triangles goes up, deeper trees, more
> boxes.
> And you're right, this is only used in the OBB Tree. That makes sense as
> it's the only relatively complex linear algebra capability we need so
> far. Otherwise we'd be accessing a known library for that I assume.
> I'll submit a PR to fix the problem this week (my sister is visiting or
> I'd do it tomorrow) and report back on the scaling asap.
> Cheers,
> Patrick
> On 08/18/2015 05:47 PM, Paul Wilson wrote:
>> Hi Iulian,
>> On 08/18/2015 05:16 PM, Grindeanu, Iulian R. wrote:
>>> Ouch
>>> only obb tree is using it.
>>> So only obb tree is affected by it
>>> indeed, it is returning cartVect's as you said
>>> It should be returning the transpose
>>> strange nobody noticed
>>> I remember somebody did a study of our obb tree and it was not
>>> scaling properly
>>> Could this be the reason?
>> This is almost certainly true.  Patrick discovered this while trying
>> to understand why some DAGMC problems were so slow.  He visualized the
>> OBB trees from that problem and they didn't really make any sense.  It
>> was a problem with many long high aspect triangles that were aligned
>> to an axis, but the OBB was not aligned to that axis.
>> Early indications are that it will make an improvement - we'll know
>> more soon.
>> Paul
>>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>>> behalf of shriwise [shriwise at wisc.edu]
>>> Sent: Tuesday, August 18, 2015 3:56 PM
>>> To: moab-dev at mcs.anl.gov
>>> Subject: [MOAB-dev] Matrix3 EigenDecomp Bug
>>> Hey all,
>>> After a day or so of working on this, I found an error in the Eigenvalue
>>> decomposition function provided by Matrix3.
>>> I believe that its computation is correct, but the way that it returns
>>> the Eigenvectors is at the very least ambiguous, and I would argue that
>>> it is simply incorrect.
>>> Typically the matrix produced by this decomposition contains the vectors
>>> in a column-based manner, but the vectors are being returned in an array
>>> of CartVects where each CartVect contains a row of the resulting matrix.
>>> The problem being that the solution matrix in this case is indeed column
>>> based. So while the correct information is available, it is returned in
>>> such a way that leads one to believe each CartVect contains one of the
>>> EigenVectors when this is not the case.
>>> I found this by comparing the results of this function to that of a
>>> common linear algebra library, Armadillo.
>>> I've attached the test program I was using if anyone is curious.
>>> Normally, I would simply fix it and create a PR but I'm not quite
>>> certain how to proceed. I think probably the best way is to fix this at
>>> the source in Matrix3.hpp but I don't want any reliant functionality to
>>> be affected without notice. This is a long standing bug affecting the
>>> OBBTree. I'll start working on a fix tomorrow morning, perhaps by
>>> finding anywhere this is used and double checking the use of the
>>> returned Eigenvectors. Does that sound amenable to all?
>>> Cheers,
>>> Patrick C. Shriwise
>>> Research Fellow
>>> University of Wisconsin - Madison
>>> Engineering Research Building - Rm. 428
>>> 1500 Engineering Drive
>>> Madison, WI 53706
>>> (608) 446-8173
