[MOAB-dev] a bug in Coupler::locate_points
Vijay S. Mahadevan
vijay.m at gmail.com
Tue Jul 21 12:49:31 CDT 2015
Huayi,
Thank you for this bug report. We didn't have a test case that caught
this particular call tree and so we appreciate the pointer to
inconsistencies.
I'll push a patch to the repo in the next couple of days along with a unit test.
Vijay
On Mon, Jul 13, 2015 at 7:55 PM, Huayi Wei <weihuayi at xtu.edu.cn> wrote:
> Hi, Moab Dev,
> In the following member function, I think it is a bug for line ` tl = new
> TupleList(3, 0, 0, 0, num_points);`.
> Here create new TupleList which address will cover the address tl passed by
> user, and then user can not accsess
> it.
> I think it should be ' tl->initialize(3, 0, 0, 0, num_points)`,
> ErrorCode Coupler::locate_points(double *xyz, unsigned int num_points,
> double rel_eps,
> double abs_eps,
> TupleList *tl,
> bool store_local)
> // Copy into tl if passed in and storing locally
> if (tl && store_local) {
> tl = new TupleList(3, 0, 0, 0, num_points);
> tl->enableWriteAccess();
> memcpy(tl->vi_wr, tl_tmp->vi_rd, 3 * tl_tmp->get_n() * sizeof(int));
> tl->set_n(tl_tmp->get_n());
> tl->disableWriteAccess();
> Best
> Huayi
