[MOAB-dev] h5m format
JR Cary
cary at txcorp.com
Tue Jun 2 12:49:16 CDT 2015
interesting.....J
On 6/2/15 12:56 PM, John Loverich wrote:
> Does Moab have the machinery to write both mesh and simulation data?
> Obviously I can write the mesh, but I'm wondering if I need to create
> my own writers for simulation data or do they already exist in moab?
> Simulation data is just referring to fluid densities on the grid, etc...
> Thanks,
> John
> On Wed, May 20, 2015 at 1:52 PM, Vijay S. Mahadevan <vijay.m at gmail.com
> <mailto:vijay.m at gmail.com>> wrote:
> You can directly output to vtk in serial or use mbconvert tool
> under bin directory in your installation to convert the format.
> mbconvert test.h5m test.vtk
> That should work for any files. If there are issues let us know.
> You can also look at all supported formats by running
> mbconvert -l
> Vijay
> On May 20, 2015 8:27 PM, "John Loverich" <john.loverich at gmail.com
> <mailto:john.loverich at gmail.com>> wrote:
> Thanks Vijay, also is there a moab format for simulation
> results? There is a moab mesh and it's natural to write out
> data (density for example) corresponding to grid elements
> (vertices or cell centers for example). If there is a
> standard way of doing this, then one can get the commercial
> visualization tools (like tecplot) to support it.
> John
> On Tue, May 19, 2015 at 9:24 AM, Vijay S. Mahadevan
> <vijay.m at gmail.com <mailto:vijay.m at gmail.com>> wrote:
> > Hi all, sorry for sending to this address, but couldn't find the
> proper
> > place to send questions.
> John, no need to apologize. This is the right place to
> send these questions.
> > Is there any visualization tool that supports the native
> Moab mesh format
> > (h5m)?
> Both Paraview and Visit need to be built from source to
> visualize the
> native h5m MOAB format. There are some instructions in [1]
> but I'm
> unsure if this is outdated since we've not built the
> plugin on recent
> version I think.
> Paraview is a bit easier i.e., compile Paraview from
> source, configure
> MOAB using --with-vtk option and install it to a prefix, go to
> tools/vtkMOABReader and use the CMake configuration to
> specify both
> PARAVIEW_DIR and MOAB_DIR to compile the plugin. You can
> then load the
> plugin from Paraview and utilize it to natively visualize
> h5m files.
> We are planning to also make this workflow easier in the
> coming
> months. Rajeev, does CMB take care of this right now as it
> stands ?
> Vijay
> [1] http://sigma.mcs.anl.gov/moab/visualization-with-moab/
> On Tue, May 19, 2015 at 10:09 AM, John Loverich
> <john.loverich at gmail.com <mailto:john.loverich at gmail.com>>
> find the proper
> Moab mesh format
> > (h5m)? It seems neither Paraview nor VisIt can read
> this format, though I
> > may be mistaken. On top of that, I'm interested in a
> standard way to store
> > field data for a given Moab mesh. Though Moab simply
> defines the mesh,
> > suppose I have electric field values stored in a
> different file linking to
> > the mesh file. Obviously I can use vtk or some other
> format, but would
> > rather use the Moab HDF5 format directly if possible.
> > Thanks,
> > John
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150602/7af8215e/attachment.html>
