[MOAB-dev] h5m format
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Wed May 20 14:52:23 CDT 2015
You can directly output to vtk in serial or use mbconvert tool under bin
directory in your installation to convert the format.
mbconvert test.h5m test.vtk
That should work for any files. If there are issues let us know. You can
also look at all supported formats by running
mbconvert -l
Vijay
On May 20, 2015 8:27 PM, "John Loverich" <john.loverich at gmail.com> wrote:
> Thanks Vijay, also is there a moab format for simulation results?  There
> is a moab mesh and it's natural to write out data (density for example)
> corresponding to grid elements (vertices or cell centers for example).  If
> there is a standard way of doing this, then one can get the commercial
> visualization tools (like tecplot) to support it.
> John
> On Tue, May 19, 2015 at 9:24 AM, Vijay S. Mahadevan <vijay.m at gmail.com>
> wrote:
>> > Hi all, sorry for sending to this address, but couldn't find the proper
>> > place to send questions.
>> John, no need to apologize. This is the right place to send these
>> questions.
>> > Is there any visualization tool that supports the native Moab mesh
>> format
>> > (h5m)?
>> Both Paraview and Visit need to be built from source to visualize the
>> native h5m MOAB format. There are some instructions in [1] but I'm
>> unsure if this is outdated since we've not built the plugin on recent
>> version I think.
>> Paraview is a bit easier i.e., compile Paraview from source, configure
>> MOAB using --with-vtk option and install it to a prefix, go to
>> tools/vtkMOABReader and use the CMake configuration to specify both
>> PARAVIEW_DIR and MOAB_DIR to compile the plugin. You can then load the
>> plugin from Paraview and utilize it to natively visualize h5m files.
>> We are planning to also make this workflow easier in the coming
>> months. Rajeev, does CMB take care of this right now as it stands ?
>> Vijay
>> [1] http://sigma.mcs.anl.gov/moab/visualization-with-moab/
>> On Tue, May 19, 2015 at 10:09 AM, John Loverich <john.loverich at gmail.com>
>> format
>> > (h5m)?  It seems neither Paraview nor VisIt can read this format,
>> though I
>> > may be mistaken.  On top of that, I'm interested in a standard way to
>> store
>> > field data for a given Moab mesh.  Though Moab simply defines the mesh,
>> > suppose I have electric field values stored in a different file linking
>> to
>> > the mesh file.  Obviously I can use vtk or some other format, but would
>> > rather use the Moab HDF5 format directly if possible.
>> > Thanks,
>> > John
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150520/f8885635/attachment.html>
