[MOAB-dev] mbconvert from abaqus to h5m
Jacob Hochhalter
Jacob.D.Hochhalter at nasa.gov
Mon Apr 27 09:29:26 CDT 2015
Hi Paul,
Ok, thanks. It is no problem for me to add the *PARTS and *INSTANCE
construct to the inp files from now on.
For me, the more important thing is to support common 3D element types.
After looking through ReadABAQUS.cpp I see that there are five 3D
element types supported: "DC3D8", "DCC3D8", "C3D8R", "C3D4", and
"DC3D4". However, "DC3D8", "DCC3D8", and "C3D8R" are all the same
element topology, 8-noded hexahedra (all set to MBHEX), and "C3D4" and
"DC3D4" are both 4-noded tetrahedra (all set to MBTET). "C3D8" is the
abaqus default for an 8-noded hexahedron, and it could be supported by
replicating what is already done for the other varieties of 8-noded
hexahedra.
I saw that the patran and exodus converters have a good layout for
supporting more element types. Could that layout be used for abaqus, in
which case we would just need to define the element connectivity mapping
from abaqus-to-moab (as is done in exodus_order.h and patran_order.h)?
If so, I can provide those mappings for the abaqus connectivities.
Iulian, in response to your previous message, yes, I will be reading the
converted files into a finite element code which uses moab as it's input
format for the mesh.
- Jake
On 04/22/2015 10:28 AM, Paul Wilson wrote:
> Hello Jacob,
> Since I was the main author of this (nearly 6 years ago), I'll add
> some comments.
> The use case I was working always had PARTs defined separately from
> ASSEMBLYs that were composed of INSTANCEs of those PARTs. I hope it
> won't be hard to support your use case, which doesn't seem to use any
> of those constructs.
> I was able to load it successfully without any changes to MOAB by
> adding PART and ASSEMBLY information, as in the attached file.
> For future reference, it also only currently supports a subset of the
> element types and metadata. It will definitely support the linear
> tets that are in your sample, but does not support many higher order
> elements.
> Paul
> On 04/21/2015 05:59 PM, Grindeanu, Iulian R. wrote:
>> thanks for reporting the problem.
>> this reader is not tested properly
>> moab is looking for *PART or *ASSEMBLY keywords.
>> Even if I modified the file, it is not read correctly
>> I am working on it
>> I will make a pull request
>> Thanks,
>> Iulian
>> ________________________________________
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>> behalf of Jacob Hochhalter [Jacob.D.Hochhalter at nasa.gov]
>> Sent: Tuesday, April 21, 2015 12:56 PM
>> To: moab-dev at mcs.anl.gov
>> Subject: [MOAB-dev] mbconvert from abaqus to h5m
>> Hello,
>> I would like to use the mbconvert tool to translate abaqus '.inp' files
>> to '.h5m' files. I have tried the following command:
>> mbconvert -g tet4.inp tet4.h5m
>> on moab 4.6 and 4.8 (tet4.inp is attached), but both return '.h5m' files
>> without any mesh data.
>> 'mbconvert -l' returns:
>> Format Description Read Write File Name Suffixes
>> Abaqus mesh ABAQUS INP mesh format yes no abq
>> which makes me think I should be able to run the conversion.
>> Am I missing something, or is this not yet functional?
>> Thanks,
>> - Jake
