[MOAB-dev] mbconvert from abaqus to h5m
Grindeanu, Iulian R. iulian at mcs.anl.gov
Tue Apr 21 17:59:40 CDT 2015
thanks for reporting the problem.
this reader is not tested properly
moab is looking for *PART or *ASSEMBLY keywords.
Even if I modified the file, it is not read correctly
I am working on it
I will make a pull request
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Jacob Hochhalter [Jacob.D.Hochhalter at nasa.gov]
Sent: Tuesday, April 21, 2015 12:56 PM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] mbconvert from abaqus to h5m
Hello,
I would like to use the mbconvert tool to translate abaqus '.inp' files
to '.h5m' files.  I have tried the following command:
mbconvert -g tet4.inp tet4.h5m
on moab 4.6 and 4.8 (tet4.inp is attached), but both return '.h5m' files
without any mesh data.
'mbconvert -l' returns:
Format  Description                    Read  Write  File Name Suffixes
Abaqus mesh  ABAQUS INP mesh format    yes     no  abq
which makes me think I should be able to run the conversion.
Am I missing something, or is this not yet functional?
- Jake
