[MOAB-dev] synchronisation of ranges
    Lukasz Kaczmarczyk
    Lukasz.Kaczmarczyk at glasgow.ac.uk
    Wed Apr  1 06:43:05 CDT 2015
Hello,
It is quick method to synchronise ranges.
1) Range on each processor keeps entities, some of those entities are shared between one or more processors.
2) I need collectively synchronise that ranges, such that if entity is in range on one of processors is as well in range on other processors (only if it is shared).
3) I do not need to send entity, only synchronise entities in range which are shared.
This is needed for collective operations on tags, instead of exchanging tags values, I need to synchronise range and then collectively set tags.
Kind regards,
Lukasz Kaczmarczyk
