[MOAB-dev] PETSc/MOAB/mbpart
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri Mar 27 12:29:35 CDT 2015
Gerd,
> I use MOAB with PETSc (and DMMoab) and build it as PETSc external package (via '--download-moab=1').
> This works fine, however, not all MOAB tools are built in the process. Unfortunately, the
> Zoltan external package is broken and as a result mbpart is not being built.
The PETSc configuration with --download-moab currently only uses HDF5
and NetCDF is PETSc has been configured with these packages also
through either --download-PACKAGE or --with-PACKAGE-DIR semantics. I
don't believe there is currently a configuration setting that
accomodates the Zoltan linkage through this workflow.
You could however configure/compile MOAB with HDF5/NetCDF/Zoltan
separately, install that somewhere and specify
--with-moab-dir=/PATH/TO/MOAB. This is what I usually do since our
development efforts use feature branches in both MOAB and PETSc
simultaneously.
> Could someone clarify the Zoltan dependence of mbpart and if there's a way to build it
> with just Parmetis?
Currently, mbpart depends on Zoltan interfaces to link against
Metis/Parmetis and it is one of our top priority items to directly
create an interface to at least Metis in the coming month so that
building Zoltan for mbpart is not a requirement. Unfortunately until
then, there isn't an elegant way to make this happen.
Vijay
> with just Parmetis?
> Thanks for your help.
> G.
