[MOAB-dev] Setting connectivity for single vertex
Paul Wilson
ppwilson at wisc.edu
Mon Feb 2 19:33:34 CST 2015
Hi Vijay,
I had the same thought and took a quick look. Much of the
infrastructure is there, namely, that the VTK writer appears to already
know how to write out nodes as 1-vertex elements.
What is missing is to include the list of vertices among the list of
elements to be written. This happens near lines 144 & 180 in
src/io/WriteVTK.cpp. I think it would need very few changes to make it
serve Michael's needs, but a little more work and testing to be
implemented as an option.
There would also emerge questions about how to implement the option:
* when invoked, always write all vertices as 1-vertex elements, or
* when invoked, only write vertices that lack higher-dimension
connectivity as 1-vertex elements
The former is quick and easy, but only serves the special case when a
model has only unconnected vertices.
Paul
On 02/02/2015 04:49 PM, Vijay S. Mahadevan wrote:
> Michael,
> If the intent is just to visualize these point clouds and data on
> them, we can certainly add some specific functionality for this when
> we output the data to vtk. If you want to contribute some code for
> this, we will be happy to take a PR directly on our bitbucket repo.
> Querying connectivity of the point cloud is not currently supported
> and unless you do create a higher dimensional element using sets of
> vertices, we cannot compute the one ring vertex neighbors (which
> involves find the element adjacencies and performing a union on the
> connectivity of these entities). Depicting a point as a traditional
> element (0-D element) can possibly be done but this is not supported
> now and am not sure how easy it will be without few involved changes
> in some parts including the I/O writers.
> Vijay
> On Sun, Feb 1, 2015 at 9:39 AM, CORTIS M. <michael.cortis at durham.ac.uk> wrote:
>> Hi,
>> So if you save points on vtk you have such thing where no connectivity and
>> no cell definition.
>> POINTS 2 double
>> 10.0 0 0
>> -10.0 0 0
>> CELLS 0 0
>> CELL_TYPES 0
>> but if you want to can include connectivities and cel definition as follows
>> POINTS 2 double
>> 10.0 0 0
>> -10.0 0 0
>> CELLS 2 4
>> 1 0
>> 1 1
>> CELL_TYPES 2
>> 1
>> 1
>> This way, Paraview and VisIt can recognise points as elements and
>> consequently can visualise them.
>> Michael
>> On 1 Feb 2015, at 15:34, Paul Wilson <ppwilson at wisc.edu>
>> wrote:
>> Hello again,
>> On 02/01/2015 09:31 AM, CORTIS M. wrote:
>> Hello Paul,
>> In fact you can create vertices and use them and store data on tag.
>> The only problem was that if there is no connectivity,
>> ParaView and VisIT does not visualise them unless you plot the points using
>> glyphs.
>> So I had to create a function which read the points from a mesh file and
>> insert their individual connectivities and save them as vtk.
>> Now I see! Thanks for the clarification.
>> So are you connecting the vertices to themselves? What is the element type
>> in VTK for such an element?
>> Paul
>> Problem solved. But may be MOAB would consider this problem and do something
>> about it.
>> Thanks for your input,
>> Michael
>> On 1 Feb 2015, at 15:24, Paul Wilson <ppwilson at wisc.edu>
>> wrote:
>> Hello Michael,
>> On 01/29/2015 05:08 PM, CORTIS M. wrote:
>> Hi Iulian,
>> Yes I am trying to create an element made from single vertex.
>> I want to used these for Material Point Method.
>> So there is a way of creating the vertices, but not adding connectivity to
>> themselves only?
>> Or may be another way round?
>> Perhaps, I'm not fully understanding your questions, but it is certainly
>> possible to create vertices in MOAB and then use them directly in your
>> analysis. There is no need to create an element if, in fact, all you need
>> are the vertices. Each vertex can be tagged with data in the same way that
>> an element can be.
>> I hope that is helpful,
>> Paul
>> If not, don't worry about. Will create a vtk writer to do this and hopefully
>> moab can use the vertices.
>> Any assistance is really appreciated.
>> Kind regards
>> Michael
>> On 29 Jan 2015, at 17:24, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
>> Hello,
>> Moab does not have elements with a single vertex. Is this what you are
>> trying to do?
>> A vertex (node) is represented with an entity handle of type MBVERTEX, and
>> you can get coordinates for it
>> I am not sure what are you trying to do.
>> Best Regards,
>> Iulian
>> ________________________________
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
>> of CORTIS M. [michael.cortis at durham.ac.uk]
>> Sent: Thursday, January 29, 2015 10:18 AM
>> To: moab-dev at mcs.anl.gov
>> Cc: Tautges, Timothy J.
>> Subject: Re: [MOAB-dev] Setting connectivity for single vertex
>> Thanks Tim,
>> I am still having a problem, may be the guys at Argonne can help with this.
>> I've tried a simpler one and trying to crete the vertex from point.
>> double points[9]={0.5,0,0};
>> EntityHandle vertex;
>> rval=moab2.create_vertex(points,vertex);CHKERR_PETSC(rval);
>> EntityHandle dummy;
>> rval = moab2.create_element(MBVERTEX,&vertex,1,dummy); CHKERR_PETSC(rval);
>> But I am getting Error code 2, MB_TYPE_OUT_OF_RANGE !
>> Is it possible to use MBVERTEX here?
>> Thanks,
>> Michael
>> On 29 Jan 2015, at 15:04, Tim Tautges <tautges at mcs.anl.gov> wrote:
>> [cc'ng moab-dev list, since I've left Argonne.]
>> dummy is 0, which is an invalid handle, but should be the handle(s) of the
>> entities whose connectivity you're setting; I suspect what you want there is
>> *vertices.begin(). And you can't set connectivity until you make an
>> element, so you need to call create_element, probably with the number of
>> verts per element as 1 and the connectivity just the single vertex defining
>> the point element.
>> - tim
>> On 01/29/2015 03:34 AM, CORTIS M. wrote:
>> Dear Tim,
>> I've got the following problem:
>> I want to create vertex entities, ie create the points and vertex entities
>> using those points.
>> So I've create a set of vertices from an array of coordinates.
>> And If you try to set the connectivity for every point you get Error code 4
>> (MB_ENTITY_NOT_FOUND).
>> This is my code:
>> double points[6]={1,0,0, 0,1,0, 0,0,1};
>> Range vertices;
>> rval = moab.create_vertices(points,2,vertices); CHKERR_PETSC(rval);
>> EntityHandle dummy=0;
>> rval = moab.set_connectivity(dummy,vertexlist,1); CHKERR_PETSC(rval);
>> //Error code 4
>> Any suggestions how to overcome this problem.
>> Kind regards,
>> Michael
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure ~ http://aci.wisc.edu
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150202/ceb9dca1/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150202/ceb9dca1/attachment-0001.bin>
