[MOAB-dev] Memory continuity
Kanaev A.A.
kanaev at ibrae.ac.ru
Wed Dec 17 20:20:31 CST 2014
Sorry if the scheme is broken, the point was:
- to get contiguous memory for 2d and 3d entities
- to arrange memory for different subsets in a certain order
Sent: Thursday, December 18, 2014 5:16 AM
To: moab-dev at mcs.anl.gov
Subject: Memory continuity
Hello MOAB-dev,
I read .h5m file in parallel with resolving shared entities and exchanging 1 layer of ghost cells+ faces
cells and faces are Ranges of all 3d and 2d entities corresp.
i get different subgroups of cells (owned cells, gost cells) and faces(skin faces, inner faces, interface faces, ghost faces) into different Ranges
I have loops over that Ranges inside main iterations loop
Can i get the following contiguous memory map for 2d and 3d entities' tags by using ReorderTool?
ghost cells start
|____________________________________________||_______________|
cells start, owned cells start owned cells end ghost_cells_end,
cells end
inner faces start interface faces start ghost faces start
|___________________________||__________________________________________||_____________________||___________________________|
skin faces start, skin faces end inner faces end, interface faces end ghost faces end
non ghost faces start, non ghost faces end faces end
faces start
Thanks
Anton
