[MOAB-dev] DMMoabOutput
Gerd Heber gheber at hdfgroup.org
Wed Dec 17 10:35:56 CST 2014
Vijay, thanks a lot for the update. It's not a problem
between now and early January 2015, but it would quickly
turn into an "existential crisis" after that.
(And it wasn't clear, if it was just my mistake or a deeper
issue.)
Thanks for all the hard work.
G.
From: Vijay S. Mahadevan [mailto:vijay.m at gmail.com]
Sent: Wednesday, December 17, 2014 10:17 AM
To: Gerd Heber
Cc: MOAB dev
Subject: Re: [MOAB-dev] DMMoabOutput
Gerd, sorry about the delay. We have an upcoming release and so I haven't had time to push a clean fix for this. I will be looking at this today and will let you know when the branch is ready.
Thanks for your patience.
Vijay
On Dec 17, 2014 9:14 AM, "Gerd Heber" <gheber at hdfgroup.org<mailto:gheber at hdfgroup.org>> wrote:
Any other thoughts? (This is a real showstopper for me...)
G.
-----Original Message-----
From: moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov> [mailto:moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov>] On Behalf Of Gerd Heber
Sent: Monday, December 15, 2014 6:59 AM
To: MOAB dev
No iMesh here. The tags are created as dense tags via get_tag_handle/tag_set_data.
G.
From: Grindeanu, Iulian R. [mailto:iulian at mcs.anl.gov<mailto:iulian at mcs.anl.gov>]
Sent: Saturday, December 13, 2014 9:14 AM
To: Vijay S. Mahadevan; Gerd Heber
Cc: MOAB dev
Subject: RE: [MOAB-dev] DMMoabOutput
The problem is the type of the tags
Probably the new tags are created with iMesh_createTag() method from iMesh This method creates sparse tags (I don't remember why it is not sparse by default; maybe to be more general) In order to create a dense tag with iMesh, you need to use iMesh extensions method
iMesh_createTagWithOptions
something like
 iBase_TagHandle tagh;
  iMesh_createTagWithOptions(mesh, "dum", "moab:TAG_STORAGE_TYPE=DENSE", 1, iBase_DOUBLE, &tagh, &err, 3, 27);
With the right options, the tag will be dense, and saved in the entities portion of the h5m file
Iulian
From: moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov> [moab-dev-bounces at mcs.anl.gov<mailto:moab-dev-bounces at mcs.anl.gov>] on behalf of Vijay S. Mahadevan [vijay.m at gmail.com<mailto:vijay.m at gmail.com>]
Sent: Friday, December 12, 2014 10:31 PM
To: Gerd Heber
Cc: MOAB dev
Gerd, this is possibly a bug in MOAB writer. I'll test your input file and see if I can replicate the issue on output. DMMoabOutput does not do anything else explicitly other than calling save on the Core object itself.
Iulian, can you also take a look at this to see if you can replicate the issue. I want to make sure that the problem is not just due to mixed elements + element tag combinations.
Vijay
On Fri, Dec 12, 2014 at 7:24 AM, Gerd Heber <gheber at hdfgroup.org<mailto:gheber at hdfgroup.org>> wrote:
> Maybe I'm doing something stupid, but I see some weird behavior from
> DMMoabOutput. My input mesh is feawd.3.h5m. It has a mixture of Hex8
> and Prism6 elements. I create a few nodal and element tags and call
> DMMoabOutput to create feawd.out.h5m. The nodal tags look fine, but
> the element tags get written correctly only for the prisms.
> Something gets written for the hex elements, but it gets written in
> the wrong place (under /tstt/tags/ instead of /tstt/elements/Hex8/tags).
> Another indicator that something fishy is going on is that the
> GLOBAL_ID tag has disappeared from Hex8 in the output file.
> Maybe another "protocol error"?
> Thanks for your help.
> G.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141217/cc29da08/attachment.html>
