[MOAB-dev] Problems with MOABConfig.cmake
Vijay S. Mahadevan vijay.m at gmail.com
Sun Nov 30 11:24:43 CST 2014
John,
Are you seeing the -n with MOAB master ? I can't seem to replicate
this. If you are working on a specific branch, let me know.
Vijay
On Sun, Nov 30, 2014 at 9:27 AM, JR Cary <cary at txcorp.com> wrote:
> Hi Vijay,
> Thanks for pushing the fix.
> I guess the point is that cmake has the convention of
> listing and using libraries by names without lib prefix nor any
> suffix.  So, for example, hdf5-config.cmake has
>   set (HDF5_LIBRARIES
> "hdf5;hdf5_f90cstub;hdf5_fortran;hdf5_hl_f90cstub;hdf5_hl_fortran;hdf5_tools;hdf5_hl")
> Then cmake converts these to the appropriate name
> for each OS.
> Thanks.......John
> On 11/29/14, 8:04 AM, Vijay S. Mahadevan wrote:
> Thanks for the bug report John. We will push a fix to the MOABConfig
> generation.
> We can split the directory and library as separate variables but this
> follows the autoconf based moab.make that uses the mixed convention. Is
> there a specific reason why you want them separately? Apps using MOAB should
> directly use that line to link anyway.
> Vijay
> On Nov 28, 2014 11:05 PM, "JR Cary" <cary at txcorp.com> wrote:
>> Dear moab folks,
>> I just configure moab with
>> '/Users/cary/projects/dagmcall/moab/configure'
>> --prefix=/volatile/moab-master.r5237-sersh --disable-static --enable-shared
>> CC='/usr/bin/clang' CXX='/usr/bin/clang++' FC='/usr/local/bin/gfortran'
>> F77='/usr/local/bin/gfortran' CXXFLAGS='-stdlib=libstdc++' FFLAGS='-pipe
>> -fPIC' FCFLAGS='-pipe -fPIC' --enable-dagmc --without-vtk
>> --with-hdf5='/contrib/hdf5-1.8.13-sersh'
>> on Darwin.  It built and installed, but at the end of the cmake
>> configuration file (lib/MOABConfig.cmake) I see many lines beginning
>> with '-n' and then 'n' at line endings:
>> # Library and include defs
>> SET(MOAB_INCLUDE_DIRS "/volatile/moab-master.r5237-sersh/include")
>> -n SET(MOAB_LIBRARIES "
>> -n          -L/contrib/hdf5-1.8.13-sersh/lib
>> -L/volatile/moab-master.r5237-sersh/lib -lMOAB  -lc++ -lpthread -lz -ldl -lm
>> -lhdf5")n
>> -n SET(DAGMC_LIBRARIES "
>> -L/volatile/moab-master.r5237-sersh/lib -ldagmc -lMOAB  -lc++ -lpthread -lz
>> -ldl -lm    -lhdf5")n
>> This causes any cmake project depending on moab to fail.
>> It is also a bit strange, in that in cmake-land, libraries are what
>> is after the -l, and LIBRARY_DIRS are what is after the -L.
>> ......John
