[MOAB-dev] Problems with MOABConfig.cmake
JR Cary cary at txcorp.com
Fri Nov 28 23:05:10 CST 2014
Dear moab folks,
I just configure moab with
'/Users/cary/projects/dagmcall/moab/configure'
--prefix=/volatile/moab-master.r5237-sersh --disable-static
--enable-shared CC='/usr/bin/clang' CXX='/usr/bin/clang++'
FC='/usr/local/bin/gfortran' F77='/usr/local/bin/gfortran'
CXXFLAGS='-stdlib=libstdc++' FFLAGS='-pipe -fPIC' FCFLAGS='-pipe -fPIC'
--enable-dagmc --without-vtk --with-hdf5='/contrib/hdf5-1.8.13-sersh'
on Darwin.  It built and installed, but at the end of the cmake
configuration file (lib/MOABConfig.cmake) I see many lines beginning
with '-n' and then 'n' at line endings:
# Library and include defs
SET(MOAB_INCLUDE_DIRS "/volatile/moab-master.r5237-sersh/include")
-n SET(MOAB_LIBRARIES "
-n          -L/contrib/hdf5-1.8.13-sersh/lib
-L/volatile/moab-master.r5237-sersh/lib -lMOAB  -lc++ -lpthread -lz -ldl
-lm    -lhdf5")n
-n SET(DAGMC_LIBRARIES "
-L/volatile/moab-master.r5237-sersh/lib -ldagmc -lMOAB  -lc++ -lpthread
-lz -ldl -lm    -lhdf5")n
This causes any cmake project depending on moab to fail.
It is also a bit strange, in that in cmake-land, libraries are what
is after the -l, and LIBRARY_DIRS are what is after the -L.
......John
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141128/3130c439/attachment.html>
