[MOAB-dev] DMMoabCreateVector
    Gerd Heber
    gheber at hdfgroup.org
    Tue Nov 25 09:21:02 CST 2014
I'm a little confused about the use of DMMoabCreateVector.
I create a tag like this:
Field default_value = { 0.0, 0.0, 0.0 };
size_t u_tag_size = sizeof(Field)/sizeof(PetscScalar);
Tag u_tag;
merr = mbiface->tag_get_handle("u", u_tag_size,
				     MB_TYPE_DOUBLE, u_tag,
				     MB_TAG_DENSE|MB_TAG_CREAT,
				     &default_value);
Let N be the number of entities. If I then go on to create a PETSc Vec via
ierr = DMMoabCreateVector(dm, u_tag, owned, PETSC_TRUE, PETSC_FALSE, &u);
and retrieve the (global) size of the Vec
ierr = VecGetSize(u, &size);
I get N as the answer. Why is it N rather than 3*N?
Should it be 3*N and I'm doing something stupid, or is it supposed to be N, which
I'd find somewhat counterintuitive. (What would be the relationship between that
Vec and the tag data?)
Thanks, G.
