[MOAB-dev] DMMoabLoadFromFile
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Sat Nov 22 19:33:07 CST 2014
Gerd, sorry about the late reply. You need to call DMSetUp before
using all the real functionality in DMMoab. Are you calling the setup
already ? If so, please send a small piece of code that replicates the
issue. Thanks.
Vijay
On Fri, Nov 21, 2014 at 7:04 AM, Gerd Heber <gheber at hdfgroup.org> wrote:
> Hi there, I'm using DMMoabLoadFromFile to read a mesh and create a DM instance.
> A subsequent call to  DMMoabGetSize tells me there are no global elements or
> vertices (which is not true).
> What am I missing?
> Thanks, G.
