[MOAB-dev] Writing a tag
Vijay S. Mahadevan
vijay.m at gmail.com
Tue Aug 19 14:38:17 CDT 2014
You can load a file with few tags already defined, create a new tag on
a range of entities and write it back out with write_file to see the
additional tag also. Use mbsize -t option to see the tags.
If this is still related to DMMoab, are you looking for a way to
define an auxillary (derived) variable, that is not part of the
original linear system (containing only primary variables) and the
dump out all the data with DMMoabOutput ? Currently, DMMoabOutput
explicitly only loops over the primary fields and writes out the tags
in the file. If there is a need to define auxillary variables, I can
certain add that capability since I can see several different use
cases that would benefit.
Vijay
On Tue, Aug 19, 2014 at 2:08 PM, Gerd Heber <gheber at hdfgroup.org> wrote:
> How can I append a tag to an existing MOAB file (which has a few other tags already)?
> Maybe this is so obvious that the documentation doesn't talk about it, but it's
> unclear to me. I don't see, for example, how to sell this to write_file. Maybe that's
> not the right call anyway...
> Thanks for your help.
> G.
