[MOAB-dev] error when install moab on Ubuntu 14.04 LTS 64
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Sat Aug 16 14:05:26 CDT 2014
This looks like an error due to incompatible static and dynamic builds for
dependencies. For your static builds, use - -with-pic or CXXFLAGS="-fPIC
-DPIC". Reconfigure CGM and install first. Then try moab build again. Let
us know if there are still problems.
Vijay
On Aug 16, 2014 10:30 AM, "Huayi Wei" <huayiwei1984 at gmail.com> wrote:
> Hi, Moab dev,
> I configure moab like following:
>  ./configure --prefix=/home/why/software/sigma/tmp --enable-shared
> --enable-debug --enable-igeom --enable-tools --enable-docs
> --disable-qvdual  --without-cgns --with-mpi --with-netcdf=/usr --with-hdf5
> --with-zoltan=/usr/local/sigma/thirdparty/Zoltan --with-parmetis=/usr
> --with-cgm=/usr/local/sigma/1.0 --with-vtk=/usr/local/sigma/thirdparty/VTK
> --with-vtk-lib-suffix=-6.0 CPPFLAGS="-I/usr/local/sigma/thirdparty/Zoltan/include
> " LIBS="-lzoltan -lparmetis -lmetis -lptscotch  -lptscotcherr
> -lptscotcherrexit"
> When make, I met an error as following :
> Making all in mbzoltan
> make[3]: Entering directory `/home/why/software/sigma/src/
> moab/tools/mbzoltan'
>   CXX      mbpart.o
> In file included from MBZoltan.hpp:27:0,
>                  from mbpart.cpp:1:
> /usr/local/sigma/thirdparty/Zoltan/include/zoltan_cpp.h:151:7: warning:
> unused parameter 'iperm' [-Wunused-parameter]
>    int Order    ( int num_gid_entries,
>   CXXLD    mbpart
> /usr/bin/ld: mbpart.o: undefined reference to symbol '_ZN11CubitStringD1Ev'
> /usr/local/sigma/1.0/lib/libcgm.so.0: error adding symbols: DSO missing
> from command line
> collect2: error: ld returned 1 exit status
> make[3]: *** [mbpart] Error 1
> make[3]: Leaving directory `/home/why/software/sigma/src/
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/home/why/software/sigma/src/moab/tools'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/why/software/sigma/src/moab'
> make: *** [all] Error 2
> Does the problem come from libcgm.so.0. Please help me to fixed it. Thanks
> very much.
> Best
> Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140816/e3ff3db2/attachment.html>
