[MOAB-dev] make check returns error when installing moab
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Wed Jul 23 18:26:29 CDT 2014
You need autotools installed for your mac for autoreconf to work. If
you have macports, this should be easy.
Meanwhile, you can try the nightly from here:
ftp://ftp.mcs.anl.gov/pub/fathom/moab-nightly.tar.gz
Vijay
On Wed, Jul 23, 2014 at 4:52 PM, the lily <the.1.lily at hotmail.com> wrote:
> Hi
> I tried before cloning moab from the git repository but it does not have a
> configure file and when I run autoreconf -fi I get the following
> bash: autoreconf: command not found
> thanks.
>> From: vijay.m at gmail.com
>> Date: Tue, 22 Jul 2014 22:19:29 -0500
>> Subject: Re: [MOAB-dev] make check returns error when installing moab
>> To: the.1.lily at hotmail.com
>> CC: iulian at mcs.anl.gov; moab-dev at mcs.anl.gov
>> These error messages are incomplete. Please use make check | tee
>> make.log and send us the make logs for us to help you better. Also I
>> notice that you are using 4.6.3.
>> We are on the verge of the next big release and so if you want to work
>> off the repository directly, we can make the appropriate fixes for
>> clang 3.3 + OSX Mavericks and push those as part of the upcoming
>> release. We haven't tested with this combination of compiler + OS and
>> so its been hard to replicate so far.
>> Use:
>> git clone https://bitbucket.org/fathomteam/moab.git moab
>> autoreconf -fi
>> ./configure --options
>> make all | tee make.log
>> make check
>> Then send us your config.log, make.log and test/test-suite.log
>> appropriately as things fail.
>> Vijay
>> On Tue, Jul 22, 2014 at 8:36 PM, the lily <the.1.lily at hotmail.com> wrote:
>> > Hi Vijya,
>> > 1) Can you check if you can run some simple MPI programs first. This
>> > will
>> > verify your MPI installation is correct
>> > I checked running a simple example and it is working.
>> > 2) Configure MOAB without MPI (with --disable-fortran). See if make
>> > check
>> > passes
>> > This is what I tried ./configure --with-hdf5=/usr/local/hdf5
>> > --disable-fortran
>> > I get the following when I do make check
>> > Making check in doc
>> > make[1]: Nothing to be done for `check'.
>> > 3) Specify the MPI installation directory when specifying
>> > --with-mpi=<MPI_DIR> and try again
>> > ./configure --with-mpi=/usr/local --with-hdf5=/usr/local/hdf5
>> > --prefix=/Users/lab/Documents/Code/moab-4.6.3 --disable-fortran
>> > a(iMesh_MOAB.o)
>> > _iMesh_save in libiMesh.a(iMesh_MOAB.o)
>> > _iMesh_getEntitiesRec in libiMesh.a(iMesh_MOAB.o)
>> > _iMesh_getVtxArrCoords in libiMesh.a(iMesh_MOAB.o)
>> > _iMesh_getEntArrAdj in libiMesh.a(iMesh_MOAB.o)
>> > ld: symbol(s) not found for architecture x86_64
>> > clang: error: linker command failed with exit code 1 (use -v to see
>> > invocation)
>> > make[1]: *** [example] Error 1
>> > make: *** [check] Error 2
>> > 4) Add HDF5 dependency -- make sure HDF5 is configured with
>> > --enable-parallel
>> > ./configure --with-hdf5=/usr/local/hdf5 --enable-parallel
>> > --disable-fortran
>> > The output of make check:
>> > Making check in doc
>> > thank you.
>> >> Date: Tue, 22 Jul 2014 19:26:36 -0500
>> >> Couple of things for your to check:
>> >> will verify your MPI installation is correct
>> >> check
>> >> passes
>> >> --enable-parallel
>> >> Let us know which of these steps fail.
>> >> Vijay
>> >> On Tue, Jul 22, 2014 at 7:23 PM, the lily <the.1.lily at hotmail.com>
>> >> wrote:
>> >> > Hi Everyone,
>> >> > I'm trying to install moab to use it with DIY
>> >> > http://www.mcs.anl.gov/~tpeterka/
>> >> > I tried the following commands to install moab
>> >> > ./configure --with-mpi --with-hdf5=/usr/local/hdf5
>> >> > --prefix=/Users/lab/Documents/Code/moab-4.6.3/bld --disable-fortran
>> >> > make
>> >> > make check but until now I was not able to install moab and Im
>> >> > getting
>> >> > the
>> >> > following errors
>> >> > invocation)
>> >> > make[4]: *** [testc_cbind] Error 1
>> >> > make[3]: *** [check-am] Error 2
>> >> > make[2]: *** [check] Error 2
>> >> > make[1]: *** [check-recursive] Error 1
>> >> > make: *** [check-recursive] Error 1
>> >> > and now even diy is not working and I think it is something has to do
>> >> > with
>> >> > mpi because I'm trying to run a code that include some mpi call
>> >> > and I'm getting the following errors
>> >> > MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype
>> >> > const&),
>> >> > bool) in merge.o
>> >> > invocation)
>> >> > make: *** [merge] Error 1
>> >> > I hope someone call help me to fix this
>> >> > ________________________________
>> >> > From: the.1.lily at hotmail.com
>> >> > To: vijay.m at gmail.com
>> >> > Subject: RE: [MOAB-dev] make check returns error when installing moab
>> >> > Date: Tue, 22 Jul 2014 02:11:45 +0300
>> >> > when I run config I do not get any errors but when I do make and make
>> >> > check
>> >> > I get the following
>> >> > invocation)
>> >> > Thanks.
>> >> >> Date: Mon, 21 Jul 2014 17:48:42 -0500
>> >> >> moab
>> >> >> The log shows that the fortran compiler is invalid in your OpenMPI
>> >> >> installation. That is perfectly fine. We will have to disable
>> >> >> fortran
>> >> >> support if an appropriate compiler is not found.
>> >> >> Can you try again with ./configure --with-mpi
>> >> >> Let us know if configure still fails, along with config logs.
>> >> >> Vijay
>> >> >> On Mon, Jul 21, 2014 at 5:41 PM, the lily <the.1.lily at hotmail.com>
>> >> >> wrote:
>> >> >> > Hi Grindeanu,
>> >> >> > Thank you for your help. Attached the config.log
>> >> >> > Thank you.
>> >> >> > From: iulian at mcs.anl.gov
>> >> >> > To: the.1.lily at hotmail.com; moab-dev at mcs.anl.gov
>> >> >> > moab
>> >> >> > Date: Mon, 21 Jul 2014 14:12:47 +0000
>> >> >> > what version of moab did you try?
>> >> >> > checkout a fresh clone from master
>> >> >> > (git at bitbucket.org:fathomteam/moab.git)
>> >> >> > can you send your config.log ?
>> >> >> > Iulian
>> >> >> > From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov]
>> >> >> > on
>> >> >> > behalf
>> >> >> > of the lily [the.1.lily at hotmail.com]
>> >> >> > Sent: Monday, July 21, 2014 3:07 AM
>> >> >> > To: moab-dev at mcs.anl.gov
>> >> >> > Subject: [MOAB-dev] make check returns error when installing moab
>> >> >> > Hi everyone,
>> >> >> > I keep getting an error when I try to install moab, here are the
>> >> >> > steps I
>> >> >> > did
>> >> >> > and the output for each step,
>> >> >> > Step1: ./configure
>> >> >> > output:
>> >> >> > configure: WARNING:
>> >> >> > * MOAB has been configured w/out the HDF5 library.
>> >> >> > * Support for native file format is disabled!
>> >> >> > configure: WARNING:
>> >> >> > * MOAB has been configured w/out the NetCDF library.
>> >> >> > * Support for ExodusII/Genesis and other file formats is disabled!
>> >> >> > Step2: make
>> >> >> > output:
>> >> >> > make[3]: Nothing to be done for `all-am'.
>> >> >> > Making all in io
>> >> >> > make[3]: Nothing to be done for `all'.
>> >> >> > Making all in dual
>> >> >> > Making all in obb
>> >> >> > Making all in perf
>> >> >> > Making all in point_location
>> >> >> > make[4]: Nothing to be done for `all'.
>> >> >> > make[4]: Nothing to be done for `all-am'.
>> >> >> > Making all in dagmc
>> >> >> > Making all in oldinc
>> >> >> > Making all in doc
>> >> >> > make[2]: Nothing to be done for `all'.
>> >> >> > ./config.status --version | \
>> >> >> > sed -e 's/.*options "\(.*\)"/\1/p' -e 'd' | \
>> >> >> > tr "'" "\n" | \
>> >> >> > sed -e '/^ *$/d' > moab.config
>> >> >> > Step3: make check
>> >> >> > output:
>> >> >> > libtool: link: unrecognized option `-O2'
>> >> >> > libtool: link: Try `libtool --help' for more information.
>> >> >> > make[4]: *** [ScdMeshF90] Error 1
>> >> >> > I do not know what exactly went wrong, do I need to install any
>> >> >> > libraries
>> >> >> > before installing moab?
>> >> >> > Thank you.
