[MOAB-dev] make check returns error when installing moab
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Mon Jul 21 17:48:42 CDT 2014
The log shows that the fortran compiler is invalid in your OpenMPI
installation. That is perfectly fine. We will have to disable fortran
support if an appropriate compiler is not found.
Can you try again with ./configure --with-mpi
--with-hdf5=/usr/local/hdf5
--prefix=/Users/lab/Documents/Code/moab-4.6.3/bld --disable-fortran
Let us know if configure still fails, along with config logs.
Vijay
On Mon, Jul 21, 2014 at 5:41 PM, the lily <the.1.lily at hotmail.com> wrote:
> Hi Grindeanu,
> Thank you for your help. Attached the config.log
> Thank you.
> ________________________________
> From: iulian at mcs.anl.gov
> To: the.1.lily at hotmail.com; moab-dev at mcs.anl.gov
> Subject: RE: [MOAB-dev] make check returns error when installing moab
> Date: Mon, 21 Jul 2014 14:12:47 +0000
> what version of moab did you try?
> checkout a fresh clone from master
> (git at bitbucket.org:fathomteam/moab.git)
> can you send your config.log ?
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf
> of the lily [the.1.lily at hotmail.com]
> Sent: Monday, July 21, 2014 3:07 AM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] make check returns error when installing moab
> Hi everyone,
> I keep getting an error when I try to install moab, here are the steps I did
> and the output for each step,
> Step1: ./configure
> output:
> configure: WARNING:
> *            MOAB has been configured w/out the HDF5 library.
> *              Support for native file format is disabled!
> configure: WARNING:
> *           MOAB has been configured w/out the NetCDF library.
> *     Support for ExodusII/Genesis and other file formats is disabled!
> Step2: make
> output:
> make[3]: Nothing to be done for `all-am'.
> Making all in io
> make[3]: Nothing to be done for `all'.
> Making all in dual
> Making all in obb
> Making all in perf
> Making all in point_location
> make[4]: Nothing to be done for `all'.
> make[4]: Nothing to be done for `all-am'.
> Making all in dagmc
> Making all in oldinc
> Making all in doc
> make[2]: Nothing to be done for `all'.
> ./config.status --version | \
>   sed -e 's/.*options "\(.*\)"/\1/p' -e 'd' | \
>   tr "'" "\n" | \
>   sed -e '/^ *$/d' > moab.config
> Step3: make check
> output:
> libtool: link: unrecognized option `-O2'
> libtool: link: Try `libtool --help' for more information.
> make[4]: *** [ScdMeshF90] Error 1
> make[3]: *** [check-am] Error 2
> make[2]: *** [check] Error 2
> make[1]: *** [check-recursive] Error 1
> make: *** [check-recursive] Error 1
> I do not know what exactly went wrong, do I need to install any libraries
> before installing moab?
> Thank you.
