[MOAB-dev] how to install mbpart in moab installation??
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Jul 16 10:01:25 CDT 2014
The mesh files are already partitioned for the Nek examples you're trying to run.
Let's try to see if it fails loading on multiple processors:
/homes/jain/nek5_svn/examples/moab
 mpiexec -n 2 mbconvert -O PARALLEL=READ_PART -O
PARTITION=PARALLEL_PARTITION -O PARALLEL_RESOLVE_SHARED_ENTS -O
PARTITION_DISTRIBUTE -o PARALLEL=WRITE_PART pipe00.h5m t.h5m
If this fails then your moab installation has problems.
Rajeev
 From: "Grindeanu, Iulian R." <iulian at mcs.anl.gov>
To: "Vegendla, Surya Narayana Prasad" <svegendla at anl.gov>; "Jain, Rajeev" <jain at mcs.anl.gov>
Cc: MOAB Dev <moab-dev at mcs.anl.gov>
Sent: Wednesday, July 16, 2014 9:11 AM
Subject: RE: how to install mbpart in moab installation??
you need zoltan, too
http://sigma.mcs.anl.gov/?p=409
when you configure with zoltan, mbpart will be compiled, too
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Vegendla, Surya Narayana Prasad [svegendla at anl.gov]
Sent: Wednesday, July 16, 2014 8:59 AM
To: Jain, Rajeev
Cc: MOAB Dev
Subject: Re: [MOAB-dev] how to install mbpart in moab installation??
Yes Rajeev, I configured with mpi. Did I miss anything in the following commands?
#MOAB##
git clone https://bitbucket.org/fathomteam/moab
cd moab
autoreconf -fi
./configure --with-mpi --with-hdf5=/home/svegendla/install/hdf5 --prefix=/home/svegendla/install/moab/bld
make
make install
Prasad
Sent: Tuesday, July 15, 2014 8:51 PM
To: Vegendla, Surya Narayana Prasad
Cc: MOAB Dev
Subject: Re: how to install mbpart in moab installation??
MOAB must be configured with MBZoltan for mbpart tool.
The .h5m file in Nek repo already has two partitions and it should work well with two processors.
The error line you mention is a call to "iMeshP_loadAll" function are you using parallel MOAB?
==> mbsize -t moab_conjht.h5m
File moab_conjht.h5m:
          Tag Name   Vertex      Hex EntitySet
      MATERIAL_SET        0        0         3
       NEUMANN_SET        0        0         6
     DIRICHLET_SET        0        0         0
    GEOM_DIMENSION        0        0         0
         GLOBAL_ID       99        5        11
     HAS_MID_NODES        0        0         3
PARALLEL_PARTITION        0        0         2
        distFactor        0        0         6
          qaRecord        0        0         0
Rajeev
From:"Vegendla, Surya Narayana Prasad" <svegendla at anl.gov>
To: "Jain, Rajeev" <jain at mcs.anl.gov>
Sent: Tuesday, July 15, 2014 3:56 PM
Subject: how to install mbpart in moab installation??
Hi Rajeev,
How to install mbpart in MOAB bin directory as similar to mbconvert?
And also following errors are seen while running on multi processors blues account, here I used the partition grid from MCS account where mbpart installed your directory (it works well in a single processor).
Number of processors:           2
REAL    wdsize      :           8
INTEGER wdsize      :           4
  Beginning session:
  /home/svegendla/nekFiles/moab_conjhtOld/moab_conjht.rea
timer accuracy:   9.5367432E-08 sec
read .rea file
ASSERT ERROR:           21 in moab.f  line         477
call exitt: dying ...
Prasad
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140716/c243d990/attachment-0001.html>
