[MOAB-dev] how to install mbpart in moab installation??
    Vegendla, Surya Narayana Prasad
    svegendla at anl.gov
    Wed Jul 16 08:59:55 CDT 2014
Yes Rajeev, I configured with mpi. Did I miss anything in the following commands?
#MOAB##
git clone https://bitbucket.org/fathomteam/moab
cd moab
autoreconf -fi
./configure --with-mpi --with-hdf5=/home/svegendla/install/hdf5 --prefix=/home/svegendla/install/moab/bld
make
make install
Prasad
Sent: Tuesday, July 15, 2014 8:51 PM
To: Vegendla, Surya Narayana Prasad
Cc: MOAB Dev
Subject: Re: how to install mbpart in moab installation??
MOAB must be configured with MBZoltan for mbpart tool.
The .h5m file in Nek repo already has two partitions and it should work well with two processors.
The error line you mention is a call to "iMeshP_loadAll" function are you using parallel MOAB?
==> mbsize -t moab_conjht.h5m
File moab_conjht.h5m:
          Tag Name   Vertex      Hex EntitySet
      MATERIAL_SET        0        0         3
       NEUMANN_SET        0        0         6
     DIRICHLET_SET        0        0         0
    GEOM_DIMENSION        0        0         0
         GLOBAL_ID       99        5        11
     HAS_MID_NODES        0        0         3
PARALLEL_PARTITION        0        0         2
        distFactor        0        0         6
          qaRecord        0        0         0
Rajeev
From: "Vegendla, Surya Narayana Prasad" <svegendla at anl.gov<mailto:svegendla at anl.gov>>
To: "Jain, Rajeev" <jain at mcs.anl.gov<mailto:jain at mcs.anl.gov>>
Sent: Tuesday, July 15, 2014 3:56 PM
Subject: how to install mbpart in moab installation??
Hi Rajeev,
How to install mbpart in MOAB bin directory as similar to mbconvert?
And also following errors are seen while running on multi processors blues account, here I used the partition grid from MCS account where mbpart installed your directory (it works well in a single processor).
Number of processors:           2
REAL    wdsize      :           8
INTEGER wdsize      :           4
  Beginning session:
  /home/svegendla/nekFiles/moab_conjhtOld/moab_conjht.rea
timer accuracy:   9.5367432E-08 sec
read .rea file
ASSERT ERROR:           21 in moab.f  line         477
call exitt: dying ...
Prasad
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140716/9ada7c54/attachment-0001.html>
