[MOAB-dev] commit/MOAB: iulian07: add pcomm delete entities method
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Jul 14 16:10:24 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/6794c6023c0a/
Changeset:   6794c6023c0a
Branch:      iulian07/pcomm_delete
User:        iulian07
Date:        2014-07-14 23:00:35
Summary:     add pcomm delete entities method
the method checks if the entities to be deleted are shared, then informs the
other processors about the change
after entities are deleted, each local list sharedEnds is updated
Affected #:  2 files
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 886ef77..f660c0a 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -8791,7 +8791,77 @@ ErrorCode ParallelComm::settle_intersection_points(Range & edges, Range & shared
   return MB_SUCCESS;
   // end copy
+ErrorCode ParallelComm::delete_entities(Range & to_delete)
+  // will not look at shared sets yet, but maybe we should
+  // first, see if any of the entities to delete is shared; then inform the other processors
+  // about their fate (to be deleted), using a crystal router transfer
+  ErrorCode rval=MB_SUCCESS;
+  unsigned char pstat;
+  EntityHandle tmp_handles[MAX_SHARING_PROCS];
+  int tmp_procs[MAX_SHARING_PROCS];
+  unsigned int num_ps;
+  TupleList ents_to_delete;
+  ents_to_delete.initialize(1, 0, 1, 0, to_delete.size() * (MAX_SHARING_PROCS+1) );// a little bit of overkill
+  ents_to_delete.enableWriteAccess();
+  unsigned int i = 0;
+  for (Range::iterator it=to_delete.begin(); it!=to_delete.end(); it++)
+    EntityHandle eh=*it; // entity to be deleted
+    rval = get_sharing_data(eh, tmp_procs, tmp_handles,
+                                   pstat, num_ps);
+    if (rval!=MB_SUCCESS || num_ps==0)
+      continue;
+    // add to the tuple list the information to be sent (to the remote procs)
+    for (unsigned int p = 0; p < num_ps; p++)
+      ents_to_delete.vi_wr[i] = tmp_procs[p];
+      ents_to_delete.vul_wr[i] = (unsigned long)tmp_handles[p];
+      i++;
+      ents_to_delete.inc_n();
+  gs_data::crystal_data *cd = this->procConfig.crystal_router();
+  // all communication happens here; no other mpi calls
+  // also, this is a collective call
+  rval = cd->gs_transfer(1,ents_to_delete,0);
+  if (MB_SUCCESS!= rval)
+    std::cout << "error in tuple transfer\n";
+    return rval;
+  // add to the range of ents to delete the new ones that were sent from other procs
+  unsigned int received = ents_to_delete.get_n();
+  for (i=0; i< received; i++)
+    //int from = ents_to_delete.vi_rd[i];
+    unsigned long valrec = ents_to_delete.vul_rd[i];
+    to_delete.insert((EntityHandle)valrec);
+  rval = mbImpl->delete_entities(to_delete);
+    std::cout << "error in deleting actual entities\n";
+    return rval;
+  std::vector<EntityHandle> good_ents;
+  for (size_t j=0; j<sharedEnts.size(); j++)
+    int index=to_delete.index(sharedEnts[j]);
+    if (-1==index)
+      good_ents.push_back(sharedEnts[j]);
+  sharedEnts = good_ents;
+  // what about shared sets? who is updating them?
+  return MB_SUCCESS;
 void ParallelComm::print_pstatus(unsigned char pstat, std::string &ostr)
diff --git a/src/parallel/moab/ParallelComm.hpp b/src/parallel/moab/ParallelComm.hpp
index 3424c51..976236e 100644
--- a/src/parallel/moab/ParallelComm.hpp
+++ b/src/parallel/moab/ParallelComm.hpp
@@ -932,6 +932,12 @@ namespace moab {
     ErrorCode settle_intersection_points(Range & edges, Range & shared_edges_owned,
         std::vector<std::vector<EntityHandle> *> & extraNodesVec, double tolerance);
+    /* \brief delete entities from moab database
+     * will check the shared ents array, and clean it if necessary
+    ErrorCode delete_entities(Range & to_delete);
   private:
     ErrorCode reduce_void(int tag_data_type, const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
